Old 24th April 2010, 19:27   #16
regnex's Avatar
Cool
Originally Posted by gigy View Post
if he wants power when car is parked then upgrading alternator will not work until engine is not running.
then a second bigger deep discharge battery(which will be powering the amplifiers atleast) will be needed or entire ice will have to be rewired to the second one. along with a higher rated alternator to support more load.
Gigly, you are somewhat right in what I’m looking for in a two battery setup. Long hours of usage outdoors when parked,engine 'OFF' and doors/boot open, Music/Video 'ON', Party Mode .
This way I wouldn’t have to bother even if the second battery runs low or ultimately flat. Will save me the trouble of push-starting the car and hence the embarrassment.
regnex is offline   Reply With Quote
Old 24th April 2010, 23:47   #17
Thanked: 294 Times
I have seen all the comments, but I would recommend not to running the setup without the engine running. The amp might get damage with low voltage from the battery without alternator charging it.
Old 25th April 2010, 00:42   #18
nitrous's Avatar
Thanked: 285 Times
+1
Its like running an engine lean.
Can't you just let the engine idle when you're stationary and in 'party mode'?
Old 25th April 2010, 01:47   #19
ramie2400's Avatar
Thanked: 58 Times
This is something which i would not let it happen as it may cause alot damage if done frequently.
+1 for LBM's post,mostly no ICE'd cars are put off when blasting the system after all ICE with FFE you see "Dhamm Dhoom fir Vroom Vroom"
Old 25th April 2010, 02:46   #20
regnex's Avatar
A lesson well learnt for me, thanks guys, I'll stick to a powerful single battery and keep the engine runing when in "Parked Party Mode"
Old 25th April 2010, 20:47   #21
gigy's Avatar
Thanked: 41 Times
I cant get how running engine lean and amplifier in low voltage are same. in that case low voltage protection should have been a must in all amplifiers, it not the case though.most of them have input/output short and over voltage protection. i think mtx and rockford have undervoltage cutoff.
I will recommend keep the exhaust out of the dance area
Old 28th April 2010, 00:03   #22
regnex's Avatar
Gigly, you do have a point and that was my concern right from the beginning, my FFE sounds great but is not so favorable when in party mode. also the exhaust, although no visible smoke would have a bad affect in some way.
hey, what if i fit a battery isolator? would that help?
guess the case is re-opened
Old 28th April 2010, 00:20   #23
ramie2400's Avatar
Thanked: 58 Times
@Regnar this is what you can look into for,hi-performance yellow top battery for car audio+electricals OPTIMA
Old 28th April 2010, 10:38   #24
Thanked: 294 Times
http://www.team-bhp.com/forum/techni...-top-died.html (My Optima Yellow Top died!)
I have used the above brand and would not recommend it to anyone !!!!
Old 28th April 2010, 12:19   #25
Invinsible's Avatar
Thanked: 60 Times
There are Kinetik Batteries that are available on sonicelectronix.com, they seem to be better than the Optima, have a look at it.
Invinsible is offline   Reply With Quote
Old 28th April 2010, 15:04   #26
blueraven316's Avatar
Instead of wasting on Dry cell batteries (which I have done earlier, though while it lasted it was good as I had a Stinger Sp1000) as they dont really last proportional to their cost.
after I was on a position when I could not source a Stinger battery again after mine went kaput, I bought a 80 Amps base terminal battery and that lasted a severe pounding for 1.5 years, costed 1/5th of the Stinger.
for those who dont know I was running about 1800 RMS coming out of 3 amps using a stock alternator.
What you probably need is a good Battery charging system like a Deltran Battery Tender or a CTEK battery charger. This will charge your car battery on the go, and really enhances life and for the big Audio boys will let you avoid the trouble of dipping charge and above all pushing the car.
Some links for your reference
Deltran Battery tender
Battery Tender Plus - Batterytender.com
Why Batterytender - Batterytender.com
CTEK XS3600
CTEK battery charger - US 800, MULTI US 3300, MULTI US 7000
Cheers.
blueraven316 is offline   Reply With Quote
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 14 30th June 2018 18:32
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
