Old 6th May 2010, 02:56   #16
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by slayer87 View Post
hi guys, thanks invisible for the suggestion. But, there is another hickup in Audison that the power output per channel is lesser than HK. The carbons i believe are rated at 100 rms and HK gives out 85 and Audison pumps out 70 rms, AFAIK. so wouldn't it better to feed them with more power. Audio gurus need your suggestion. Though i still have around 2 weeks to finalize my decision.
Between 70RMS and 100RMS there would be difference of about 1db or so, which wouldn't be much of difference. However it's the signal to noise ratio and efficiency along with stronger power supply that matters more, which would result in much cleaner power. Though Audison is a bit less rated in terms of power, it would produce a bit more clean power compared to the HK.
You could also bi-amp the comps if it's crossover has the feature.
HK is again a great amp, sounds great but against the Audison which would also produce bit more power for the sub and is stable at 2ohm under bridge mode, I would choose the Audison.
Invinsible is offline   Reply With Quote
i20 Asta 1.2L Petrol : 1st i20 2011 model on Team-BHP Forum Suess Test-Drives & Initial Ownership Reports 30 29th May 2013 12:15
All i10 & i20 owners, I need feedback EDIT - Booked i10 AT Asta Tejas@perioimpl Hatchbacks 89 12th October 2011 14:58
My i20 asta(o) 1.2 ICE quest slayer87 In-Car Entertainment 12 20th May 2010 09:38
