Old 1st May 2010, 04:49   #1
Default ICE for i20 Asta(o)
hi,
I have narrowed down on the following ICE equipment for my soon to come i20.
Front - Illusion Carbon Nd6.1 compos (Already Bought)
Rear - No spkrs or DLS classic 426( From Previous car)
Amp - Harman Kardon CA470
Sub- IDv3 12" (In my previous car but sold it off, now buying a new one)
Amp mono - Kenwood 8104d or kenwood X10d
Now, Do u think the above equipment list is fine or changes can be made to make it better. i mainly need suggestions for the 4 channel amp and mono amp, that can i get better stuff in the same price bracket ?
I had ID sub and kenwood mono 9103d in my previous car and was very happy with the performance. So this time again planning to go in for similar combo but confused on the kenny amp front. Which one of the above 2 is better ? though i am inclined towards the x10d as it has bass boost remote , but is there any other difference. What are the current prices of both the kenny amps with bill.
Is there a better 4 channel amp in the price range of the HK CA470, or should i go ahead with it ?
slayer87 is offline   Reply With Quote
Old 1st May 2010, 09:27   #2
navin's Avatar
Thanked: 4,286 Times
the x10should be better. having not heard either the paper specs are what we have to depend on. the x10 is rated to work at 1ohms. the 8104d is not. a subwoofer is a very inductive device and the impedance of a 4 ohm sub can swing from 2 ohms to 30 ohms. so getting an amp that can operate at low impedances means it has a lot of current dumping capability to muscle the woofer around.
besides I believe both these amps are discontinued. I dont know which amp replaced the x10 (X1 maybe?) but the 8104d was replaced by the 8105d.
Old 1st May 2010, 09:35   #3
Invinsible's Avatar
Thanked: 60 Times
X10D has better specs and can put out close to the rated power and 8105d would be better pick. WHere are you buying the amp from? Whats your budget on amp and sub ?
For 4 channel you can have a look at the Infinity Kappa four, has better review compared to the HK.
Invinsible is offline   Reply With Quote
Old 1st May 2010, 13:53   #4
hi, thanks for the suggestions. what is the price of the Infinity amp? I would be getting the system installed at Gyro, so most probably i'll be buying rest of the stuff from them itself.
Old 2nd May 2010, 00:55   #5
hi,
i have another question, Instead of an HK CA470 and Kenny mono should i go for the Audison Lrx 6.9 amp. Would this amp have enough juice to power the illusion carbons, DLS coax and IDv3 12". Which is a better option ?
Old 2nd May 2010, 09:36   #6
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by slayer87 View Post
hi,
Audison is a good choice always, plays extremely clean and has a regulated power supply. 6.9k will give out 70 x 4 and rest 2 ch can be bridged to put out 450RMS at 2 ohms. If you getting the Carbons I would suggest you bi-amp them with the 4 channel. Look for something cheaper(amp) to run rear coax.
Old 2nd May 2010, 16:27   #7
Default HK CA470 + Kenny mono or Audison lrx 6.9
hey, thanks for the suggestions. I know all about Audison as i have used an Audison Lrx 4.5 earlier. The thing is if the total amount comes out to be the same for an audison lrx6.9 or HK Ca470 + Kenny mono, then which is a better option. Would the 2 channels of Audison be as good or better than the kenny monoblock to power the ID sub or not ? I havent bought any amp, i am looking at all the options.
Old 2nd May 2010, 16:34   #8
i have another questions, what is the latest ongoing price of the ID v3 12" sub. I had bought one 2 yrs back for 10.5k and i believe its much expensive now. If i want to run the sub on 2 ohms/1 ohm then would i need a d2 or a d4. Is it advisable to buy one from US, as there is a friend who is coming to india soon and price there is around 8k.
Old 2nd May 2010, 18:57   #9
i am getting Kenwood 8105d for 12k with bill, is it worth it or i can get better options at this price.
Old 2nd May 2010, 21:16   #10
rbp
Thanked: 287 Times
Are you sticking to the stock HU?
Eagerly waiting for the installation details with pics.
I am subscribing to this thread as I too own a i20 .
rbp is offline   Reply With Quote
Old 2nd May 2010, 23:43   #11
nitinralli's Avatar
Thanked: 798 Times
The latest price of ID V3 12" is 14K. I bought it in may09 and it was 14K then so hope its the same rightnow too.
Its always better to buy from US as the price is cheaper there.
nitinralli is offline   Reply With Quote
Old 3rd May 2010, 17:55   #12
Default Need Assistance!!!
hi, guys, i am still not satisfied as i haven't got any foolproof answer for my above queries. Please guys help me in this matter as i am very confused here. I need to power an IDv3 12" + Illusion nd6.1 compos + DLS classic 426. Now the main question is regarding the amp, that should I go in for
Option 1 - HK Ca470 + kenny 8105d
Option 2 - Audison lrx6.9
Which is a better option if the total cost comes out to be the same ?
Old 3rd May 2010, 20:57   #13
Invinsible's Avatar
Thanked: 60 Times
I would take the Audison without second thought, it would give much more cleaner power.
Old 3rd May 2010, 21:57   #14
donarun's Avatar
Thanked: 17 Times
I think the HK CA470 is outta stock. I tried to get one for myself but wasn't able to.
donarun is offline   Reply With Quote
Old 5th May 2010, 19:13   #15
hi guys, thanks invisible for the suggestion. But, there is another hickup in Audison that the power output per channel is lesser than HK. The carbons i believe are rated at 100 rms and HK gives out 85 and Audison pumps out 70 rms, AFAIK. so wouldn't it better to feed them with more power. Audio gurus need your suggestion. Though i still have around 2 weeks to finalize my decision.
i20 Asta 1.2L Petrol : 1st i20 2011 model on Team-BHP Forum Suess Test-Drives & Initial Ownership Reports 30 29th May 2013 12:15
All i10 & i20 owners, I need feedback EDIT - Booked i10 AT Asta Tejas@perioimpl Hatchbacks 89 12th October 2011 14:58
My i20 asta(o) 1.2 ICE quest slayer87 In-Car Entertainment 12 20th May 2010 09:38
