Old 11th November 2010, 16:02   #16
blueraven316's Avatar
skumar : Since you said by pressing the door down the vibrations reduces, couple of other things too you have to check,
Get the doorpad removed and see if the plastic clips which attach the plastic pad into the metal frame are broken or not , sometimes fitters misplace the clips while removing the pad, this can cause a lot of jarring in a swift pad.
What are the eq settings on the player ? is the HPF on or off ? what is the bass level ? and at what volume does the jarring start ?
blueraven316 is offline   Reply With Quote
Old 13th November 2010, 09:49   #17
The Eq setting I usually use is XPLOD, and jarring happens above around 14 level. HPF? never used that..Iguess its used for subwoofer? i dont have a dedicated subwoofer.
Originally Posted by DerAlte
The cross-overs are the small boxes (with a large copper coil as the most prominent component) to which the mid-bass and the tweeters are connected.
For my speakers, I don't think I have any cross-overs i my car. Is that fine for a stock installation of the speakers I mentioned? Do the cross-overs come with the speakers, or do I need to purchase them separately?
skumar69 is offline   Reply With Quote
Old 13th November 2010, 10:21   #18
The EQ setting Xplod makes only noise, try using custom with Bass at +3 to 4,
An HPF is a High Pass Filter which is used for speakers, not a sub, subs mostly are filtered with a LPF, Low Pass Filter.
The HPF if on will cut off some low frequencies which the speaker is not designed to handle at higher volumes, you can access this control by keeping the centre dial knob pressed down and a new set of menu options will show up.
The GT5 component speaker comes with a crossover which is a small black box about 1" X 3" into which the input wire goes in and two wires come out for speaker and tweeter, and no you don't have to buy it separately, it must be installed under the dash board or near the bottom kick panels in your case as the tweeter is on the dash board,
Another pointer is if by some chance the installer has not put it in, then the speakers will jarr a Lot , get it checked if the crossover is there in the setup.
Old 13th November 2010, 11:11   #19
I checked. Mt HU does not have specific HPF setting. It has LPF, and something called Sub ATT. I wonder if this Sub setting is the same as HPF. This Sub has two options 75Hz and 125Hz i think.
Old 13th November 2010, 21:01   #20
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by skumar69 View Post
... For my speakers, I don't think I have any cross-overs i my car. ...
Oh no, you most certainly would have cross-overs that came with the JBL components (set of tweeters and mid-bass drivers). One normally does not buy an XO separately, it comes with the components.
Times of India? Nope, VW of India. EDIT: Vibrating ad on 11 Sept 2012 (Pg 26) SkyWalker The Indian Car Scene 464 21st September 2012 16:48
Problem: Ford Ikon vibrating (almost shaking) when Idle. Eddy Technical Stuff 34 1st August 2011 13:26
M-800 Vibrating at high speeds krazydriver84 Technical Stuff 29 18th March 2010 10:18
Vibrating Brake pedal!! What reasons? Deeps Technical Stuff 6 5th August 2008 23:41
Scratching and vibrating noise from SKODA OCTAVIA 1.9 Ambient shineshine Technical Stuff 0 24th June 2007 16:34
