Old 6th July 2010, 15:00   #16
Speed-Freak's Avatar
Thanked: 67 Times
Hi Guys,
The Multi-EQ function is only enabled after you connect and configure the 9887 set using the Imprint kit. The bass and treble settings are available only after the Multi-EQ is "ON".
Speed-Freak is offline   Reply With Quote
Old 14th July 2010, 10:26   #17
Originally Posted by Speed-Freak View Post
Hi Guys,
Thank you very much for your reply Speed Freak.so do you mean one has to own a KTX 100EQ IMPRINT in order to turn on Multi-EQ? if so will it be installed in car or can be removed once calibration in done?
bmr_ind is offline   Reply With Quote
Old 14th July 2010, 12:01   #18
anachronix's Avatar
Thanked: 1,307 Times
The KTX100EQ is more of a tuning kit for the 9887. It can be removed from the car after tuning. I am not sure if you would require the IMPRINT kit all the time when you want to make a change to the tuning! In that case, I am wondering if I should buy one!
However, I am planning to visit Technokrat over the weekend to setup IMPRINT. I am still running on stock speakers though!
anachronix is offline   Reply With Quote
Old 15th July 2010, 09:00   #19
Thanked: 67 Times
Hello
The IMPRINT kit calibrates the sound using a microphone and a software connected via cable to the head unit, the unit has 4 or more presets for calibration, you can configure the sound using the kit by placing the microphone on each seat to calibrate the presets.
You dont need to have the kit connected all the time, however if you need to retune the setup then you might need to reconnect the kit. Best is to find out if any local tuner has such a kit which can be used once and returned back.
Poor Experience and Alpine 9887 stolen at Carnation Chandigarh R.I.P Indian Car Dealerships 16 24th February 2012 15:16
Alpine 9887 at Approx Rs13000 anToNIcHeN In-Car Entertainment 2 24th January 2010 16:37
Alpine 9887 Vs Pioneer P880. clipto333 In-Car Entertainment 164 20th November 2008 07:35
alpine 9887 + infinity kappa + jbl amps sounding harsh..please help tuning vickyre In-Car Entertainment 8 5th November 2008 14:02
Alpine 9887 St. Anger In-Car Entertainment 8 4th December 2007 06:42
