Old 3rd January 2006, 10:29   #46
dmitri's Avatar
Default Hiss in the speakers.
The hiss is there at all the time(with the engine turned off also), I think the hiss is not dependant on the volume control, but it gets drowned as the music flows. Is this any problem with the grounding?
Originally Posted by Sam Kapasi
Well like i told you earlier, soft sponge/heatlon will do the trick.
You are the second person with a similar complaint about the hiss from the pioneer 5750. Please clarify the following - do you get this "hiss" with the car engine turned OFF? Do you get this hiss at all volumes and does the HISS increase or decrease with the volume control?
The amp is definitely overloaded like i told you in my earlier post as you have connected 4 speakers to the front channel and the sub to the other in bridged mode. Putting a capacitor etc MAY help, but if it sounds good, i say leave it.
This problem will definitely be solved when you put a second amp for the subwoofer (any class). I suggest the CS300.1 to complement your CS60.4. It's less than 10k.
dmitri is offline   Reply With Quote
Old 3rd January 2006, 11:14   #47
navin's Avatar
Thanked: 4,286 Times
what RCA cables are you using. Some generic cables have poor rejection.
navin is online now   Reply With Quote
Old 3rd January 2006, 12:06   #48
dmitri's Avatar
The current cables are BOSS ones.
Old 3rd January 2006, 12:10   #49
navin's Avatar
BOSS strikes again. Change cable. Enjoy music. I think Monster is expensive but reliable. They got a cable called Interlink Junior that might be affordable.
Buying a 4 channel amp from US amit_sound In-Car Entertainment 22 11th March 2010 14:48
4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 Bass&Trouble Shifting gears 7 19th March 2008 09:27
2 channel or 4 channel amp harry2223 In-Car Entertainment 14 19th February 2008 22:08
Confused between buying a car b/w 8L or 11L or waiting for Civic? ankit.agl Sedans 26 29th March 2006 03:56
