Old 16th June 2010, 16:46   #1
Thanked: 152 Times
Default Polk dB690 Vs Infinity Reference 9633i
Guys could you please help me out which is better between these two.
I am already having infinity ref 6022i in front doors and polk db 690 on boot tray in a zen 2003 model with a Kenny x994 (8016BT).
I have a opportunity to swap the db's with infi's at back .
Should i go for it.I listen to everything that has sound .
Future upgrades include a 5 channel amp and a woofer (both Infinity probably).
Trust_In_Thrust is offline   Reply With Quote
Old 21st June 2010, 00:05   #2
blueraven316's Avatar
as long as your polks dont develop some problem, you dont probably need to change. If you had a polk component speaker I probably would have suggested you to change
blueraven316 is offline   Reply With Quote
Old 21st June 2010, 12:14   #3
Thanked: 152 Times
@blueraven : Thanks a lot .One more info i am running these now on JBL1004 With front xover at 100Hz (12db octave) and rear at 80 Hz (12db octave) . I hope i am not damaging the speakers .Also sometimes when i keep playing a high volume i get kind of some smell .(Wonder what that is ).
Old 4th July 2010, 15:14   #4
The smell is copper burnt smell, though this happening all the time is not good, but it may not be such a concern unless the smell gets to unbearable levels.
Try keeping the gains low on the amp, that 1004 is too powerful and sounds very raw compared to the older amp 75.4.
Old 4th July 2010, 15:41   #5
Thanked: 36 Times
Smell of burning copper?! 1. Is it normal?
2. Does it happen with every ICE which has an external amplifier?
3. If yes, isn't there a solution to this problem?
abhipuru16 is offline   Reply With Quote
Old 4th July 2010, 16:29   #6
DerAlte's Avatar
Thanked: 2,879 Times
Smell of insulation burning that comes when wires overheat due to continuous overloading. No, does not happen every time, and not in most installations. The solution is using cables rated higher than the highest current expected in a situation. If you don't intend to put all knobs at max and attempt to permanently disable your auditory faculties, the normal wires are good enough.
Old 5th July 2010, 13:36   #7
Thanked: 152 Times
Guys the smell came only for few days after i installed the amp .It doesn't come now at all even after playing loudly continuously for a long time and they system still sounds great. And all wiring is as it comes in the original JBL kit so i am assured about the wiring and speakers wires are 16 gauge .
Now i am looking for a slim sub woofer (<13cm mounting depth) available in india to fix in the spare wheel well )Any options are awaited.I saw the Kappa 120.9 and JBL8" as listed on JBL India website meeting my height requirements.However 8" is not available at all .Does anyone know the price of 120.9 .
Also should i get the JBLGTO3501 or 7001 .I am bent on 7001 .
Difference between Infinity Reference and Infinity Kappa series kanhaiyo In-Car Entertainment 30 9th March 2017 13:19
Confused between Pioneer 308d4 or Polk db1240 or Polk db1212 althaaf In-Car Entertainment 10 27th October 2011 14:03
Polk vs Infinity components pras.oct25 In-Car Entertainment 9 24th May 2010 12:38
GTO 947 or Infinity 9633i Bullfrog In-Car Entertainment 9 25th November 2009 23:27
For Sale Infinity Reference 6913l 6x9 speakers clipto333 Shifting gears 0 2nd May 2007 20:16
