Closed Thread
Old 17th June 2010, 21:22   #1
carfanatic007's Avatar
Thanked: 9 Times
Post iPod to Audio system connector
Hi All,
My friend was telling me about a connector to which you can connect your iPod and set a frequency and same frequency can be played on your car's audio system. So I wanted help on:
1) Which brands are available for this?
2) Is it available in India/Bangalore?
3) Approx cost for the same
4) Is it worthwhile?
5) Does it need an aux in the audio system?
Mods hope this is the right forum
carfanatic007 is offline
Old 17th June 2010, 21:32   #2
nik_kapur's Avatar
Thanked: 492 Times
Default Tried it !
The device exists, you can buy an expensive Belkin one or cheap Chinese versions. Let me warn you, its useless. Too much radio disturbance and you need to keep moving the device to find the right signal strength vis-a-vis the radio antenna in your car which can be at the read end of your car !!
I wouldnt recommend it. If you have an auxiliary input in your car, a wired device is your best bet.
nik_kapur is offline
Old 17th June 2010, 22:05   #3
greenhorn's Avatar
Thanked: 1,519 Times
http://www.team-bhp.com/forum/ask-gu...itter-ice.html
here you go!
greenhorn is offline
Old 17th June 2010, 22:08   #4
mjothi's Avatar
Thanked: 216 Times
Check this post
http://www.team-bhp.com/forum/produc...ml#post1377660
You can read the whole thread to know more about this. In summary, this is a cheaper version of FM transmitter and works very well. Except for the sound clarity. But I don't thin its too bad.
mjothi is offline
Old 17th June 2010, 22:55   #5
Eddy's Avatar
Thanked: 5,078 Times
Thanks Greenie & mjothi.
Eddy is online now
Closed Thread
USB Adapter / Connector for the Maruti Wagon R (Nippon System) GTO In-Car Entertainment 1 8th September 2016 20:45
AUX connector for iPOD Touch and Clarion DXZ385USB head unit manish_symc In-Car Entertainment 7 21st August 2008 15:33
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
Install Ipod Dock Connector with AMP in Car ? Lovelydude77 In-Car Entertainment 2 2nd October 2007 19:41
Best audio system with IPOD compatibility kashd In-Car Entertainment 19 20th February 2006 19:45
