Old 6th July 2010, 21:30   #1
Default UK Wagon R+ and a custom sub
Hello again all at Team BHP, CustomIce from the UK here again. Thought i'd share with oyu my latest creation, its a sealed enclosure (only just enough air, and wadding!) housing a 10" InPhase XT10 sub:
It can be done!
CustomIce is offline   Reply With Quote
Old 7th July 2010, 16:40   #2
Bass&Trouble's Avatar
Thanked: 74 Times
Cant see any subwoofer enclosure. Looks like you uploaded the wrong picture.
Old 7th July 2010, 17:33   #3
Odd, thought it was there, anyway heres a second attempt at attaching it!
Last edited by Jaggu : 7th July 2010 at 18:01. Reason: Please Preview before Submitting posts. Thanks
Old 7th July 2010, 17:58   #4
whizzkid_ram's Avatar
Originally Posted by CustomIce View Post
It can be done!
Is that Sub or speaker on the Dash?
whizzkid_ram is offline   Reply With Quote
Old 7th July 2010, 18:59   #5
Tha is an MTX road thinder 4" coaxial on the dash with cloth covered MDF pannels. Just sounds and looks better!
The pic is actually some custom pillar pods (as you can see!) for my 52mm gauges. More organic looking than the plastic pods.
Last edited by Jaggu : 7th July 2010 at 19:18. Reason: Back to back posts, please wait for moderator approval to edit the original post.
Old 8th July 2010, 18:00   #6
Thanked: 74 Times
Are these DIYs or a pro job? What is the finish on the subwoofer enclosure?
And I'm really sorry, but the pillar pods look way too organic. You should consider sanding them and probably painting them or something.
Hope you take any criticism constructively. If you are a professional, it'll only just help you.
Old 8th July 2010, 19:21   #7
The sub enclosure is in need of more attention, some of the glue hasn't taken propperly to the carpet (off-white sub box carpet) it needs a bit of fiddling an it'll be spot on. More sound deadening and screwing down required too, as the pannel above has begun rattling like mad!
DIY's while i had some time out from running CustomIce and another business! Although i know what you mean with the pilar pods, there is more work to be done on them, more filler and more sanding, then re-primer. Needed to have the car back on the road without gauges hanging all over the place! Not finished but it will be a pro job by the time i'm done.
All criticism when written in a constructive maner is appreciated
Old 17th July 2010, 07:21   #8
vigsom's Avatar
Thanked: 618 Times
A good DIY effort ;but as B&T put it,the finish is missing
Are the dash speakers 4"?Look like 6*9s
Old 17th July 2010, 12:54   #9
I know the finish needs work. Yes the dash speakers are 4
wagon r ice medium value for money setup wih sub and amp in chennai dvprasad In-Car Entertainment 2 24th April 2010 19:49
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Custom Sub Box - Your Views Please vigsom In-Car Entertainment 11 6th February 2009 17:42
