Old 22nd July 2010, 18:18   #16
yogiii's Avatar
Thanked: 18 Times
Originally Posted by UniqueMods View Post
another option for a woofer. pic is not a zen, but still possible.
thats a pretty neat install !!
my friend just bought a santro CNG a couple of days ago and was thinking if he could go for a SW.
Can anybody in New Delhi really do this ??
yogiii is offline   Reply With Quote
Old 6th June 2012, 08:26   #17
HimuraKenshin's Avatar
Thanked: 183 Times
Default ICE in a Hatchback with a CNG kit?
Until a few days ago, i ws a happy boy. driving my swift, with a rocking ICE set up. Hey, i liked it. :P
But then came the CNG kit, after the exorbitant rise in petrol prices.
Now i request ice gurus to help me out.
I want to add a subwoofer,like the one i had before, but since i have no boot space left, what do i do?
The CNG tank is at a height of 6" from the boot floor.
please advice me guys. I cant llive without a sub. I do not plan on changing the front stage or the rear stage. Im open to changing the entire substage. (Subwoofer+ amp). But it would be nice if i could stay within a budget of 10k
thanks again guys
HimuraKenshin is offline   Reply With Quote
Old 6th June 2012, 14:19   #18
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: ICE in a Hatchback with a CNG kit?
Please post a picture of your boot, and a list of what stuff you have. This will enable us to visualize your situation better.
Old 6th June 2012, 15:31   #19
intoxicangel's Avatar
Default Re: ICEing a Zen with CNG cylinder installed.
Used to drive a Zen with a CNG kit until 2009 when I picked up my Swift Vdi.
Had a rather basic Kenwood HU (which was pulled out off a Lancer GLd which my dad sold in 2005 and then put in the Zen) which did a decent job playing my CD's (thru a 10 CD changer, mounted under the passenger seat) for quite a while.
Then did get irritated of the flat sound after a point once I managed to save some money up. The itch in the hands to spend on the car rose and did put in a little money into bettering the sound.
Got fibre glass + wood enclosures for the front doors and put in 6" JBL's (basic components, don't remember the model no, was back in 2008, no crossover units, only a simple resistor between the speaker and the tweeter) and put in a half inch plank on the boot door with a set of then available Blaupunkt 5 1/4"slim components (again without a crossover) on the plank.
I know the installation has already been done on the Zen in question on this thread, but a combination of 6" components upfront and 5 1/4" components in the boot door should do justice without having to do any fancy fibreglass work or compromising on sound despite having a CNG tank in the boot.
intoxicangel is offline   Reply With Quote
Old 6th June 2012, 15:35   #20
thanks again guys
I think you would be able to get an active slim subwoofer for that budget.
They sound pretty awesome for their size and depth and don't depend on an enclosure but really on the size of the cabin that it needs to spread around in.
Thereby saving you the cost of sub+amp+custom enclosure for car with CNG tank.
Pioneer has a series available in India, or if you get lucky you could find one from Clarion as well.
Old 15th November 2013, 20:31   #21
pdiddy741's Avatar
Excuse my newbie question, but can an amplifier be fitted into the trunk of a car that has a CNG kit installed? my bro's fabia has one on the front wall of the trunk, and a cng kit would certainly block access to this area
pdiddy741 is offline   Reply With Quote
Old 16th November 2013, 17:58   #22
DerAlte's Avatar
Not recommended. It is not about access, but about sparking if the installation is not good enough or wires are frayed.
Better mount the amp below one of the front seats.
DerAlte is offline   (1) Thanks Reply With Quote
Old 16th November 2013, 18:54   #23
ramie2400's Avatar
Thanked: 58 Times
Yess u can very well install amplifier and subwoofer in a CNG fitted car,infact you can even use multiple amplifier's.
There are specific ways to get the complete system install in a CNG fitted car
Ref pic:
Needs precision calculations,correct equipments and installation skillset to do it.Cost is a bit expensive though.Sound output almost similar doing a regular install. You need to use a subwoofer which has a Qts to run it in a small sealed enclosure RMS power is you can expect from 130-150 acts as a low frequency filling.
Ramie
Car with four cylinder engine or three cylinder engine? sunil8089 Technical Stuff 37 7th January 2018 21:06
CNG Oil Change - Regular or any CNG specials? panky12345 Technical Stuff 5 20th May 2016 11:56
Volkswagen Vento Automatic - Terra Beige**EDIT: CNG kit installed** nvluv Test-Drives & Initial Ownership Reports 50 31st August 2014 14:30
Swift Lxi (CNG Fitted) vs Santro GLS (CNG) coolaxe Hatchbacks 18 28th June 2012 16:58
