Old 16th January 2011, 06:20   #46
bhatmaster's Avatar
Thanked: 7 Times
Default Re: Looking for a new headunit in 15-20k Budget
NO it wont solve that as 75-85% of the power is needed by the midwoofer.
For example on typical music I listen to (70s Rock, Jazz, Blues, Classical) 50% of the energy is under 300Hz, 65% is under 1200Hz, 75% is under 2500Hz, 90% is under 5000Hz. So if you are XOing at say 12db/2500Hz then 75% of the power would be needed by the midbass and only 25% for the tweeter.
Hi Navin,
Yes, I calculated with more or less same percentages. For me, under 2000 hz where my cross-over is, should be around 75% of the music / energy. So, for a single channel driving both woofer and tweeter, the mid bass driver would get only 12 watt out of 16 watts of toal available power ( Lets assume). But now it is getting full 16 watts to drive only the woofer i.e 33% of power of hike effectively which is not negligible, what do you say?
I agree that it sill cannot beat the solution of having an external amp, but again I have limitations as explained earlier.
bhatmaster is offline   Reply With Quote
Old 24th January 2011, 23:47   #47
bhatmaster's Avatar
Thanked: 7 Times
Anybody heard Blaupunkt Acapulco MP54 ? I'm getting this one really cheap, around 40 USD. How is the SQ?
Old 26th January 2011, 12:04   #48
DerAlte's Avatar
Thanked: 2,879 Times
Blaupunkt HUs generally have a very neutral sound, and are VFM. At USD40 it would be a really good deal, especially since it has 3x 4v Pre-outs. Make sure to get the separate accessories like Aux-in and iPod interface cables when you order this.
ICE for IKON..Budget 20k MAX.. Ford_madhan In-Car Entertainment 42 3rd August 2009 09:47
Help needed for ICE in swift- Budget 20K raptor_79 In-Car Entertainment 36 26th August 2008 18:21
ICE-Swift Chandiagrh(Budget-20k)No idea how to go about it!!! Gill In-Car Entertainment 17 14th August 2007 10:50
Need an ICE advice for Swift -- Budget: 15-20K harryc In-Car Entertainment 16 29th May 2007 15:09
