Old 13th September 2010, 12:04   #16
SPARKled's Avatar
Thanked: 299 Times
Now thats a huge upgrade. So now your Morels are truly getting the signal they deserve. Congrats!!
SPARKled is online now   Reply With Quote
Old 14th September 2010, 10:58   #17
Epic's Avatar
Thanked: 334 Times
Hey thanks Sparkled! I have decided to not upgrade any more equipment in my system at the moment but only do that in my new ride in probably 3 yrs time. But the ICE bug has already started tickling me to change my amps and sub. I am trying my level best to resist but can't promise it won't bite. Lets see.....
Epic is offline   Reply With Quote
Old 14th September 2010, 12:00   #18
Ajaybiz's Avatar
Thanked: 140 Times
Start with sub get good DVC sub in sealed box, later if you wish change the amps as well.
Ajaybiz is offline   Reply With Quote
Old 14th September 2010, 13:58   #19
Mi10's Avatar
Thanked: 1,455 Times
So, you atlast took the plunge ?
Morel + PRS, must be one sweet combo.
I am sure you ll very soon be upgrading your sub atleast.
Mi10 is offline   Reply With Quote
Old 14th September 2010, 15:12   #20
Epic's Avatar
Thanked: 334 Times
Oh the Morels + PRS is a full on combo. I am loving it totally!!!!
You guys are making total sense but my question is, which sub? Which is the sub that if I change now will contribute to my current setup and to my future setup? I have planned to get the Audison LRx 5.1k for the future.
I believe my current JBL 301.1 gives 204 watts @ 4 Ohms & 294 watts at 2 Ohms. My current Infinity Ref 1200T SVC is not getting the full 300 watts RMS that it is rated for at 4 Ohms.
What you guys suggest?
Old 14th September 2010, 16:14   #21
Mi10's Avatar
I dont know what will suit your taste, but just keep in mind that when you upgrade, pls do both your Amps and Sub at same time. It will surely save you on labor, and you need not open up your car (for wiring) often.
Old 15th September 2010, 14:28   #22
Epic's Avatar
Thanked: 334 Times
Hi guys,
I am looking at upgrading my subwoofer to the Infinity Kappa 120.9. I believe it has great reviews to be a sound quality sub and is for around 10k. I think that is absolute value for money. Specifications as below:
12" SSI Kappa Series 2 Ohm or 4 Ohm Subwoofer
Power Handling : Peak 1400W & 350W at 2 Ohms or 4 Ohms
Coated Glass Fiber Woofer Cone
Thick rubber surround
Selectable Smart Impedance (SSI) lets you set the subwoofers impedance with the flip of a switch
Cast aluminum basket with voice coil vents
Triple voice coil technology
2" Voice coil diameter
Rubber boot surrounds the magnet structure
Frequency response: 23-400 Hz
Sensitivity: 91 dB
Frequency Response: 23-400 Hz
What do you guys think? I can upgrade to this so that the sub can get 300W RMS from my current JBL 301.1 and then upgrade the amp later to the Audison LRx 5.1k which will give the sub 750W RMS.
Old 15th September 2010, 15:29   #23
Gilead's Avatar
Thanked: 20 Times
Hi guys,
I have heard the Kappa sub and it's ultra smooth and precise. It's not an SPL type sub though. Put it in a 1 to 1.25 cu ft well built sealed box and the response will be superb. I think Invinsible has one, so maybe you can get more info from him.
What would be the point of feeding 750 RMS to a 350 RMS sub? It won't hurt, but seems rather pointless unless you really like the Audison's output.
Gilead is offline   Reply With Quote
Old 15th September 2010, 15:52   #24
Mi10's Avatar
Prob'ly he wants to have 2 X 350W RMS
Old 15th September 2010, 15:58   #25
Gilead's Avatar
Thanked: 20 Times
Then he needs the Infinity Ref subs that come in the factory fitted dual ported enclosure. I have heard them as well and they are deadly. Much better than a single sub putting out 700 RMS.
A lot depends on the mono too I guess. The Kappa I heard was powered by a Focal Solid 1 and I bet the Kappa's silky response had a lot to do with that. Both are smooth operators.
Old 15th September 2010, 16:32   #26
Ajaybiz's Avatar
Thanked: 140 Times
If you are not planning to upgrade the JBL 301.1 soon then go with Infinity REF 1062 sub i am using it with my 301.1 in sealed tiny box and wowo man the way it thumps, puts shame on many 12", using 301.1 's full potential at 2 ohms, sub is rated 275 w RMS at 2 ohms so perfactly mated.
Old 15th September 2010, 17:37   #27
Invinsible's Avatar
Thanked: 60 Times
It's discussed here lot more in detail.
As for the enclosure .8 to 1 cu.ft is what it requires.
http://www.team-bhp.com/forum/produc...er-review.html
Invinsible is offline   Reply With Quote
Old 15th September 2010, 17:44   #28
Epic's Avatar
Thanked: 334 Times
Very useful information from all of you. Really appreciate it but whoa hang on guys!!!!
Ok. As you can see, my final ICE setup is aimed towards SQ so I don't really want SPL. Now, your last two lines are interesting as I have either been given wrong information on the difference between RMS power and Peak power or I have not understood the concept.
My understanding of RMS/Peak Power is - RMS power is the actual power that the sub can handle continuously. Peak power is what the sub can handle at a given point of time but NOT continuously.
What I have been told about RMS/Peak Power is - RMS power is the minimum power required for the sub to perform. Peak power is the maximum of what the sub can handle continuously. This I was told just yesterday.
Which of the above is true??
No no my friend!! I have no intention of having two subs in my car. I am starting to believe that the 'bug' in 'ICE bug' is actually you!!
I was looking at the Infinity Ref 120.9 only because it had good reviews for a sub costing 10k. But as mentioned above, I do not want two subs.
Well I am definitely not planning to upgrade my amps at the moment but will be considering upgrading to the Audison LRx 5.1k as a one amp solution by Jan 2011 and hence thought of upgrading and investing in a sub now that will suit my current JBL 301.1 and will not have to change again when I upgrade to the Audison LRx 5.1k later.
Btw, isn't the Infinity Ref 1062 a 10" sub? What is the cost of this sub? Is there a model available in 12" as I would prefer that.
Old 15th September 2010, 17:50   #29
Invinsible's Avatar
Thanked: 60 Times
Believe in what you think at times not always
Your understanding is correct in regards to RMS and Peak power.
Regarding the sub it's a complete Sleeper. I highly regard this sub in sub 20k category. Very sub can play low, smooth, and be loud at the same time. Run this sub at 2 ohms for best results.
Old 15th September 2010, 18:32   #30
Epic's Avatar
Thanked: 334 Times
Ok so your above post says to go for it. However I have one question, since you mentioned to run the Infinity 120.9 in 2 Ohms for best results, what difference would it make since it is rated at 350W RMS at 4 Ohms & 2 Ohms?
Also, since I am planning to use the Audison LRx 5.1k to power this sub, it gives 750W RMS at 4 Ohms and 1150W RMS at 2 Ohms. Now, if I run the sub at 2 Ohms, is there a chance of any damage due to the massive extra power being fed to the sub from the amp at 2 Ohms as compared to that at 4 Ohms?
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
On a strict budget, Swift gets some SQ ICE (Morel/Kenwood/Blaupunkt) thelord In-Car Entertainment 37 6th September 2011 12:49
Morel+JVC+Pioneer - budget ICE setup in my SX4 ZXi VVT etchemkay In-Car Entertainment 30 6th August 2011 23:18
Presenting my Swift Symphony - | Morel | Rockford Fosgate | Kenwood | Blaupunkt | Mi10 In-Car Entertainment 14 23rd September 2010 08:46
Swift VDI, JVC+PIONEER+JBL, ICE upgrade?? srikant In-Car Entertainment 13 12th November 2008 06:49
