Old 15th August 2010, 20:15   #1
buntydey's Avatar
Default Amplifier switching off!! Please Help
Hi, I am having this problem in my Swift. I have a Pioneer P8000BT HU, with Kicker components in the front, Pioneer components in the rear, Sony 500W amplifier and Blaupunkt TSSeries Sub Woofer.
I like to hear music in loud/full bass (I guess you got what I meant). But recently I am having this problem of the amplifier going into power/protect mode whenever I am turning the volume above 40. One punch in the bass, and the amp is going off. I have to turn the HU off, and then switch it back on, and it again starts.
I showed it to the Sony service center, and they changed the MOSFET circuits, but still the problem persists. I would like to hear the suggestions of you experts Help!!!!
buntydey is offline   Reply With Quote
Old 15th August 2010, 21:11   #2
DerAlte's Avatar
Thanked: 2,876 Times
Quite simple - the amp is not as powerful as you are assuming. The 500W is misleading, as this may not be the RMS rating.
You need to drive the sub with a good monoblock, like the JBL 301.1.
Old 15th August 2010, 21:30   #3
thelord's Avatar
Exactly! And also check the power/ground cables.
I was using JBL wiring kit(probably fake) and after an year it just gave up.
thelord is offline   Reply With Quote
Old 16th August 2010, 09:53   #4
buntydey's Avatar
Thanks everyone. My cables are fine, just need to add a mono amp as you all suggested. I am trying to source it from US, so any suggestions on this, apart from the JBL one?
Old 16th August 2010, 10:45   #5
Gilead's Avatar
Thanked: 20 Times
Your gains are probably set way too high, thus tripping the amp. I have not heard the JBL mono, but I have heard the Focal Solid1 powering a Kappa sub and it's very good. Try to catch some reviews online.
Gilead is offline   Reply With Quote
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
HELP! - Amplifier switching off esteem_lover In-Car Entertainment 21 25th June 2008 16:11
Why diesel engines are revved before switching ignition off? DCEite Technical Stuff 57 7th May 2008 00:53
Switching off with AC dsinz Technical Stuff 5 13th September 2006 11:51
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
