Old 16th August 2010, 12:31   #1
Saptarshi B's Avatar
Thanked: 9 Times
Default Integrate ICE with Map my India and Reverse camera ?
I have a Tata Sierra which has enough space to put in the works. Am starting from scratch. Currently there is not even a tweeter in place.
Few things to factor in:
- There is a lot of external and engine noise. Don’t think I can do too much about it. High quality speaker sound may be lost in the Tata Sierra
- I will put in a reverse camera with a screen
- I will put in ‘Map my India’ as well.
- Total budget for all the above is approx 40k
1) Is there any way to integrate Reverse camera with Map my India AND the ICE ?
2) Can the Map My India screen be used for the Reverse Camera or do I need to put in a separate screen in place of the rear view mirror?
3) Can the Map My India screen be used for the Video Out of the ICE ?
4) What would the Budget breakup be ?
Open for suggestions on the best combination possible and if I need to rework the budget
Saptarshi B is offline   Reply With Quote
Old 16th August 2010, 12:44   #2
luky_13's Avatar
Thanked: 116 Times
I think you are almost talking about a carputer project. Should be able to integrate ice+gps+camera and visuals over a decent touch screen. Run one of those carputer UI's for windows. There are a lot of threads that discuss this as a DIY in great detail. Best of luck.
luky_13 is offline   Reply With Quote
Old 16th August 2010, 22:43   #3
greenhorn's Avatar
Thanked: 1,519 Times
buy one of these
DealExtreme: $163.67 7.0" Touchscreen 400MHz CPU Windows CE 5.0 GPS Navigator w/ Bluetooth Handsfree + 2GB Maps SD
the Mapmyindia stuff is of similar quality, so dont worry about buying chinese
this has a video input ( as does the MMI). just plug the camera into it
you do not need a separate screen for ICE. use this as your video player ( it runs WM6)
your budget just got a lot smaller
Old 26th September 2010, 13:28   #4
Thanked: 9 Times
Thanks.
Greenhorn, I have been tracking this product for the past month. It is still out of stock.
Any other product reccomendations ? I got friends coming in from HK/Singpore and can get it imported.
Reverse camera or Sensor ? Maneesh Modifications & Accessories 654 2nd April 2018 11:40
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
ICE for Toyota Altis J - 2 din touchscreen with gps/bt/reverse camera skuz In-Car Entertainment 8 13th August 2012 14:37
OBD-II Scantools (Swift) to integrate with CarPC wmanu Technical Stuff 4 7th June 2010 14:50
Photos : Reverse Camera in my Swift CarDude Modifications & Accessories 103 5th December 2009 16:38
