Old 16th August 2010, 23:31   #1
viky_s's Avatar
Thumbs up Good 4" Components
Dear fellow members,
i have a modest ICE setup in my esteem.
1. Pioneer DEH-4190 SD
2. Front Polk Audio 4" DB401
3. Rear Infinity Kappa G939i Components
4. Hertz 4ch EP4
5. Sub Polk Audio DB-1240 12" Enclosed
6. Audision AmpKit
The kappas and the sub are powered by the AMP
I am not at all keen on cutting a hole in my doors so that option is out.
Now which 4" components should i go for to be fitted in the dashboard and how should i power them i.e with HU or AMP
which amp?
awaiting your expert advice
My total budget is around 10K for front comps and amp
regards
vikram
viky_s is offline   Reply With Quote
Old 17th August 2010, 09:57   #2
DerAlte's Avatar
Thanked: 2,877 Times
Try Illusion 4" components - you may need to source them from Mumbai.
Get a good 2-channel (mono will be better, but will be costlier) for the sub, and shift the front and rear to the Hertz 4-channel.
Old 17th August 2010, 11:00   #3
SPARKled's Avatar
Thanked: 325 Times
There are also some Kicker 4 inch components that you you can check out.
SPARKled is online now   Reply With Quote
Old 17th August 2010, 15:08   #4
viky_s's Avatar
Thumbs up
ok fellow members,
after a lot of thinking i have finally decided to cut the door trims and install the 6" Illusion electra Components .
Rammy has even offered to get second hand esteem trims and send them retro-fitted with the components.
I think i'll go for this but i am a little skeptical about the trims being damaged in courier from Mumbai to nashik.
i'll be powering the front 6" Illusion components and rear 6x9 Infinity with my Hertz 4ch EP4 amp.
Gurus please suggest a budget 2 channel amp for my Polk audio DB 360Watt woofer.
my budget is 5k for the amp.
regards
vikram...
mods please change the thread name to " Esteem ICE- In Pursuit of Nirvana...."
Old 17th August 2010, 15:12   #5
SPARKled's Avatar
Thanked: 325 Times
I am glad you are going the 6.5 inch components route instead of the 4 inch one. The difference in sound will be pretty amazing. Illusion Electras are some of the best sounding speakers at that price.
Old 18th August 2010, 01:38   #6
viky_s's Avatar
Thumbs up Good VFM ICE for my Esteem
I have finally decided to go for 6" components in front for my esteem.
I need a good VFM amp ( which would be better a mono amp or 2 channel amp) to power my 12" enclosed DB124 Polk Audio Sub rated at 320W
The front components and rear (infinity kappa 6x9 ) components are powered by my Hertx EP 4 380W amplifier.
Also suggest some food 6" components.
Budget for amp is 8-9k and that for compos is 6-7 k.
Awaiting your expert advice
regards
vikram
Good VFM Sedan type car for office use? COUGAR Sedans 28 20th April 2010 16:58
Are VFM cars really VFM? - Cabs are wrong examples? WindRide The Indian Car Scene 5 21st March 2010 20:35
Good VFM Infinity tyre damaged SS-Traveller Tyre & Alloy wheel Section 22 5th February 2009 13:37
Getz Crdi VFM ICE : Beast meets the BULL naman In-Car Entertainment 47 1st September 2008 23:44
