Old 21st September 2010, 19:23   #31
sathyaprakash's Avatar
Thanked: 44 Times
Thanks to Gilead, Djnik and Montyguru>>> i find both MTX and Infinity a good subs and mtx is to my taste but my concern in how to control the amp in the sub? does it come with a remote or corded remote to increase or decrease the wooffer sound or will the HU be able to control the active sub pls enlighten me on this as i am not a audio freak is there any other way to control the sub fixed in the boot from our seat?
sathyaprakash is offline   Reply With Quote
Old 21st September 2010, 19:53   #32
Gilead's Avatar
Thanked: 21 Times
sathyaprakash, take a look at this. The MTX has an EBC (External Bass Control) wired remote which you can fix at a convenient location on the dash. That's what you need to control the sub.
http://www.mtxaudio.eu/IMG/pdf/Manual-RT12PT.pdf
Gilead is offline   Reply With Quote
Old 21st September 2010, 23:48   #33
montyguru's Avatar
Talking
not just MTX, but most pre-amped units come with a cord remote for base.
montyguru is offline   Reply With Quote
Old 22nd September 2010, 17:41   #34
Thanked: 44 Times
Thanks Montyguru, Gilead >>> i would like Gilead to give me some more valuable information as your are also residing in chennai such as where to buy this MTX, how to to find whether its original, approx cost and the best place for installing it, i found from this forum Power Zone in Royappetta is a good place any other place? wires,connectors etc., to be used? the best place in the boot? finanlly the tunning part in which any special attention is needed?
Old 22nd September 2010, 19:39   #35
Gilead's Avatar
Thanked: 21 Times
Power Zone is probably the best place to get any type of MTX installed. He is an MTX-Kicker specialist. You will know what I mean if you go there.
You can find Power Zone contact details and other recommended installers here. Chennai - Team-BHP
Approx cost of the MTX would be 10K. Not sure. Add another 2K for amp power wiring. Leave the placement in the boot and tuning to the installer if you finally get it done at Power Zone.
I guess you have all the info that you need. Now it's time for you to do some actual leg work. Enjoy the bass.
Old 1st October 2010, 10:24   #36
DrBoom's Avatar
Thanked: 15 Times
Default Installing your old audio system in a different car
Hey mate.
With regards to your comment about your older car sounding better than the current one, I would like you to take the following into consideration.
Each car is different so there will be difference in sound quality. This is based on music transfer, which in most cases is reflected sound, also you have to consider the cabin gain, each car has a different resonant frequency so maybe the bass sounded better in your previous vehical. You may want to read up on the tutorial on how to set amplifier gains. If you are not sure, this is how you do it, adjust your head units bass and treble to a flat response, turn the amps gain all the way down. Its a good idea to have somebody in the front seat to adjust the head unit's volume, since I am assuming your amplifier is in the boot area. Also you may need to turn all bass boost down in the amp (if any) and then crank your head unit volume to 3/4 loud and then begin to adjust the gain on the amp. Keep going until you hear distortion and then back off a little. Tell your mate to turn the volume down on the head unit and you are done!
You have to realise that the amp will produce the same power as specified but you just have to adjust your amps gain to your head units output voltage. Good luck mate!
DrBoom is offline   Reply With Quote
Old 2nd October 2010, 13:31   #37
aseem's Avatar
Thanked: 419 Times
@Monkey_Wrench/Navin, would changing speakers help? Or the best bet for any ANHC upgrade warrant a dash kit with aftermarket unit? Can steering mounted audio controls be retained in that scenario?
aseem is offline   Reply With Quote
Old 2nd October 2010, 18:11   #38
monkey_wrench's Avatar
Look, honestly -- there's no end to what you can upgrade, and what you can't. Every small upgrade will help in some way or the other. One of my earlier plans was to get the BASE model ANHC (without anything) and then put in a monster 2-din HU, pimp the ride with 4-channel amp, speakers, components yada yada. I finally decided against it, because the stock HU in the VMT had it's own charm and I decided to go for the higher model and shelf the upgrade.
I did the very basic upgrade -- I kept everything as it was, and added a 2-channel amp that supports only the sub. I tweaked the settings and amp gain until I was happy with it, and now have the best of both worlds -- that is the stock HU along with better bass, thanks to the Sub addition.
So if I get your question correctly, I don't think you can retain the steering controls if you change the HU (note that you'll need to get a whole new stock dash mount from Honda for that).
Let me know a little more about what you have in mind and maybe I can help.
monkey_wrench is offline   Reply With Quote
Old 4th October 2010, 10:52   #39
navin's Avatar
Thanked: 4,282 Times
Yes changing speakers will help. Every little bit helps. I'd start with damping the doors though.
My wife insisted that we retian the stock look of her ANHC. Her car was bought when the ANHCs all came with a stock (CD less) HU and the dash kit was not yet available.
Yet because she was used to TA from her earlier car (Opel Sail with an Alpine 9833) we had to implement TA in this car. This meant an external processor. The MS-late was not out and the Audison bit one had issues (since resolved) so the choice boiled down to the RF 360.2 and Alpine 650. The Alpine offered less flexibility but was cleaner so we use the Alpine and then tricked the Alpine into producing the tonal changes we wanted.
Old 4th October 2010, 21:17   #40
aseem's Avatar
Thanked: 419 Times
With stock HU + Bull Components + 4 channel amp + JBL Sub --- sound better than stock, or would it just lead to distortion caz of the issues you have highlighted. I dont plan to install an expensive processor.
Old 15th April 2011, 17:10   #41
Smile Quick clarification on Stock HU on Honda City iVTEC
Hi Folks,
Can you please let me know if the stock HU on the new iVtec VMT comes with 2 pre-outs or not. I have a JBL CS60.4 amp and a GT 12" SW which i want to connect. Planning to install these this weekend once, i'm sure that the stock HUs have 2 pre-outs.
Many Thanks.
venkateshs is offline   Reply With Quote
Old 15th April 2011, 18:31   #42
Default Re: Quick clarification on Stock HU on Honda City iVTEC
Gurus,
I'm willing to change the 2 tweeters and 4 door stock speakers which have come along the car - but dont want to change the HU and spoil the ambience of the central dashboard. Just want to confirm if the HU has 2 pre-outs.
Thanks.
Old 16th April 2011, 12:32   #43
cityvic's Avatar
Thanked: 2,611 Times
I'm running my JBL compos,coax and sub all from the OEM HU.
There is just 1 preout.
Simple Solution,add a Schoshe Line Out Convertor.SLC 4.
It will cost you around 2.5k
cityvic is offline   Reply With Quote
Old 16th April 2011, 16:12   #44
Thanked: 41 Times
Dont worry about the Pre-outs. Just get a good HLA and you are ready to go. A good HLA will give you best soud quality.
My friend is using Genesis HLA III Series in the Cruze with stock HU with a great difference in sound quality.
monty9991 is offline   Reply With Quote
Old 18th April 2011, 17:55   #45
Default Re: Sub+Amp in ANHC?
Can someone pls suggest me good dealers in Blore where I can get the Scoshe Line Out Convertor -SLC 4, buy 2 comps and get my existing amp and SW installed?
ANHC SMT or ANHC EMT with Caska HU alam86 Sedans 19 16th September 2013 15:59
Best available powered SUB WOOFER for my ANHC sathyaprakash In-Car Entertainment 1 29th October 2009 23:22
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
WANTED - Amp & Sub kb100 Shifting gears 19 17th April 2006 13:40
