Old 28th September 2010, 21:43   #1
Default ICE upgrade for POlo 1.6
I am aware of similar threads but its bit different where I need to retain the stock HU and add amplifier and components.
Currently I have these which were taken out from my old car.
ARC Audio 300.4
Polk MM 6501 components
Pold db 6 in speaker
Polk DB 12in sub
I did some research and found two products which can take high level input and process the signals i.e.,
MTX REQ5
Amazon.com: MTX re-Q5 5-channel bass restoration signal processor Get full bass response when adding amps to a factory system: Gateway
and
Kicker
Kicker ZX10SUM8 Zero Summing Device for OEM Integration, 10ZXSUM8
Gurus, need advice on which one would be better? or are there better ones? btw cant afford audison bit one or RF 3SIXTY2.
Also I have a Kicker 750.1 Mono amp which puts out almost 900 rms @ 2 ohms
Which one would match Alpine Type X 1043D 1000 RMS or IDQv3 which is just 500 RMS.
P.S. I dont want to slice or do any alteration on the stock wiring. So do we get an extender coupler where the wires can be sliced?
[FONT=Arial][/FONT]
kiran1103 is offline   Reply With Quote
Old 29th September 2010, 09:26   #2
navin's Avatar
Thanked: 4,282 Times
MTX REQ5
Kicker ZX10SUM8
WHat about the 360.1?
The 2 devices you have listed do not have Time Alignment. I am not even sure if they will negate the EQ some OEM HUs have
The ReQ is a 5 channel device the Kicker is a 4 channel device so without having heard either I'd take the MTX REQ. Please note that many such devices do not have a low noise theshold and you might get some hiss in your system. For this issue only I'd recommend you try before you buy.
Old 3rd October 2010, 10:48   #3
Thanks Navin
Ok I guess I will go with the REQ5. Also does anyone know if i can get the coupler extender for Polo HU. I dont want to cut the stock wires. Also does the RCD 510 be a direct fit?
ICE upgrade : VW Polo avi_hi_im In-Car Entertainment 91 17th October 2017 15:53
ICE Upgrade for Polo Highline AnkitPrashar In-Car Entertainment 23 30th April 2014 12:46
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
