Old 10th March 2012, 11:59   #31
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: Linea TJet+ ICE suggestions required
Originally Posted by nishantgandhi View Post
... considering an upgrade here (if it is truly worth!) so as to derive the best out of the HU. ...
The objective should not be deriving the best out of the HU, rather what you are missing in the output as compared to another system, like distinct vocals in the same song, or the feeling of depth. If you are not missing anything in a comparison, perhaps you should let that feeling go and use what you are familiar with.
... and get a good 2 channel for the sub exclusively ...
You already have a 4-channel, so get a mono for the sub. Not for loud volume, but for the amp's current dumping ability.
... 4. Damping: for front doors only ...
You are putting in a sub, so damping front door isn't enough. You have to consider doing the rear doors and more importantly the boot lid (even tightly stuffed cotton waste will help here). And don't forget to lay a couple of strips of double sided tape behind the rear number plate.
Old 28th October 2016, 17:17   #32
AbiS's Avatar
Thanked: 7 Times
Default Reuse Duster Anatel headunit
Hi friends,
My brother bought a new duster car and he replaced his anatel head unit with a Blaupunkt. My question is Can I use it in my Linea? Please advice.
Thanks in advance.
AbiS is offline   Reply With Quote
Old 28th October 2016, 17:57   #33
Jaggu's Avatar
Thanked: 8,695 Times
Default Re: Reuse Duster Anatel headunit
Originally Posted by AbiS View Post
Hi friends,
Thanks in advance.
Duster unit needs unlock code, so if you can get that from dealer for this particular head unit, it should work. Maybe you can ask your brother and check for this.
Jaggu is offline   (1) Thanks Reply With Quote
Old 28th October 2016, 17:57   #34
deehunk's Avatar
Thanked: 1,015 Times
You have to check whether the head unit can be fitted in a double din facia for Duster.
deehunk is offline   Reply With Quote
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Ooty - my first on MY LINEA, probably the first LINEA TO CLIMB famous 36 hairpin bent vinay.pillai Travelogues 56 13th September 2009 21:25
