Old 12th November 2010, 02:11   #1
StreetAddict's Avatar
Thanked: 45 Times
Default About Line Drivers
Need some advice from gurus. I was finding an existing thread on Line Drivers but was not able to find one.
Following is my current setup
HU : CarPC (http://www.team-bhp.com/forum/diy-do...-carputer.html)
Front components : Rainbow SLG Titans
Rear Fill : None
Amp 1: Kenwood KAC-8401 (for components)
Amp 2 : Blaupunkt VPA1500 pro mono (for sub)
Sub : Fully loaded Fi SSD 18"
RCAs & Fuse : Scosche
Distribution Block : Connection Audison
Power cable : Finolex 0-AWG
The sound from the setup is not upto the mark even with all the gains on amps maxxed out. I did a bit of research & was suggested to add a line driver to the setup.
Hence, I need suggestions from fellow BHPians if someone has already used one or has got some more details on that.
StreetAddict is offline   Reply With Quote
Old 12th November 2010, 10:33   #2
navin's Avatar
Thanked: 4,282 Times
What do you not like about the sound. I suspect a line driver might not be the correct solution here. I dont know what sort of output your Car PC puts out but the rest of the components you are using are good.
Old 12th November 2010, 10:53   #3
Invinsible's Avatar
Thanked: 60 Times
You could also add a sound processor, where you get line driver as well as EQ, which could help in processing sound as per your desire.
Invinsible is offline   Reply With Quote
Old 12th November 2010, 12:07   #4
panky12345's Avatar
Thanked: 149 Times
Please dont do that. Check the entire wiring first.
panky12345 is online now   Reply With Quote
Old 12th November 2010, 12:33   #5
Thanked: 294 Times
Guys he is running the amp via a car pc the output of the sound card is quite less hence he need to jack them a bit. Even at full gains the output is quite less (I have heard the car).
Old 12th November 2010, 13:56   #6
DerAlte's Avatar
Thanked: 2,879 Times
Is it on-board sound (Realtek or similar) or is it a PCI/USB sound card?
Old 12th November 2010, 20:09   #7
Thanked: 45 Times
I was using the onboard sound (Realtek) earlier but then switched to a Creative X-FI USB sound card. This did not increase the audio output but SQ was better as compared to the Realtek one.
Never used one. Are they also known as DSPs ?
Did that multiple times.
You heard it from the horses' mouth!
Old 13th November 2010, 10:01   #8
navin's Avatar
Finally someone who has heard the car....LBM bhai did you measure the output? How low is it? 300mv? 1V? Most amps have a sensitivity of 500mV or so.
The other problem (I have no idea of PCs or Car PCs) could be the impedance matching between the outout of the PC and the input of the car amplifier.
A cheap line driver would cost about $100 at the least and the only brand I have tried and could recomend is AudioControl. However if I were the owner I'd get the Epicenter instead as it offers a lot of subwoofer tuning options as well. The epicenter has been around for over 20 years so there should be a wealth of information on the internet. About 10 years ago Audiocontrol put out a simple line driver called Overdrive. It had a 24db gain. Nice piece it was clean and trouble free.
Now you can either spend $100-150 on the Overdrive, or spend about $200 on the Epicenter or $300-350 on an Alpine 650/RF 360.2.
Old 13th November 2010, 11:15   #9
valhallen.282's Avatar
Thanked: 164 Times
What are the ouputs you are using. The x-fi is a true 5.1 output card. First off are you running on stereo -> 2.1 split like a y adapter where one stereo pair goes to the kenwood and the other goes to the blau?
OR are you using the dedicated 2.1 output where front left right is only assigned to the kenwood and you are using the center/sub for the subwoofer? This is important first as using a split cable will cause issues.
valhallen.282 is offline   Reply With Quote
Old 13th November 2010, 11:45   #10
Invinsible's Avatar
Thanked: 60 Times
Epicenter is a bass restorer. It doesn't have line output control. In this case overdrive or matrix could work the best. For little more money there is also DQX that I would suggest to it has a line driver, XO, EQ feature with 6 channel output. The other in dash option is Four.1i.
Old 13th November 2010, 12:03   #11
navin's Avatar
the old version I worked with had a pass though that was full range so you had a LF singal that had a 5 channel parametic EQ and bass restoration and a fullrange output that could be fed to the fullrange amp.
Old 15th November 2010, 20:57   #12
Thanked: 45 Times
Would look into it!
It's a dedicated 2.1 output.
Edit : I was also looking on this. http://www.rockfordfosgate.com/produ...3&locale=en_US. Suggestions ?
Old 15th November 2010, 21:57   #13
Invinsible's Avatar
Thanked: 60 Times
I would suggest the Audiocontrol products over the RF line driver. They have been choice of many pro audio builders in 90's and even today, they are flawless.
Old 15th November 2010, 23:21   #14
navin's Avatar
Yup I have used their products in the late 80s too.
Old 16th November 2010, 00:34   #15
Thanked: 45 Times
Any idea if they are available in India ?
Gumball Rally Start Line London BAD 130Y The International Automotive Scene 61 2nd November 2007 21:45
Formula 1 line ups for 2006 ?? Badcheetah Int'l Motorsport 32 3rd October 2005 18:04
An Amazing addition to the new Aston line GrimReaper The International Automotive Scene 0 5th November 2004 17:34
2005 F1 Driver line-up...so far. Rtech Int'l Motorsport 18 15th August 2004 12:01
red line navin Technical Stuff 8 16th April 2004 22:28
