Old 17th November 2010, 17:29   #16
theexperthand's Avatar
Thanked: 1,244 Times
@blueraven316: thanks a ton for the details. I think I am slowly catching the ICE bug and I am doing my ground work before I start planning for the upgrade
theexperthand is offline   Reply With Quote
Old 17th November 2010, 18:09   #17
Thanked: 49 Times
Originally Posted by LionX View Post
@CrackedHead, I got your point buddy. I might change my sub to 2x12" or 2x10" but it will be well within 600WRMS.
I am looking only for a Mono, Class -D amp just for the sub.
Read up on the Clarion before you dismiss it. Class GH gives you the best of both worlds - high efficiency (the main benefit of class D) and SQ comparable to Class AB.
So the amp is a lot more versatile - you can use it for your sub by wiring one channel to each voice coil of the sub. Or you can just bridge it.
Alternatively, you can use it to power your front components if you wish (because it is a full range amplifier). All this flexibility by adjusting crossover settings.
CrackedHead is offline   Reply With Quote
Old 17th November 2010, 18:21   #18
LionX's Avatar
Thanked: 655 Times
@CrackedHead, I understand the benefits of going for clarion over mono, but the feedback about clarion service in india is scaring me. My HU is Clarion 785USB, so I have done my research on their servicing here.
For full range I already have a 4 channel - a Kenwood 8405.
LionX is offline   Reply With Quote
Old 17th November 2010, 19:32   #19
Thanked: 49 Times
I haven't come across any feedback on Clarion service - could you please share the information you have.
PS: I have the same HU.
Old 17th November 2010, 23:31   #20
blueraven316's Avatar
Moreover I wanted to try out something new and after reading the reviews I am more inclined to JackHammer. What all parameters need to be considered for a mono amp in an SQL setup?
1. RMS Power Out
2. 4/2/1 Ohm stability
3. SNR - ?
4. THD - ?
There is no such parameter for a good SQL amp, specs can be pretty misleading, I have run a Brutus mono @ 2 0hms running a 600 RMS Hifonics sub and it has been doing fine till date on a friend's car, it depends on how the amp's output is through the gain levels and also one has to know the driver's (sub) break point, but that not everyone can do really just by listening to it.
My point, you probably have to hear the amp play before you decide whether the amp is the type of SQL your ears like. Everyone's tastes and preferences are different.
blueraven316 is offline   Reply With Quote
Old 18th November 2010, 14:09   #21
LionX's Avatar
Thanked: 655 Times
@blueraven316, I don't know anyone who is running JackHammer in Bangalore. Most of the amps we discuss in tbhp are not available for audition, if available they have a different configuration.
For someone like me, the best bet is to get an opinion from someone like you or believe the user reviews available online.
Help: Problem with new install(MTX Audio) kumargandharva In-Car Entertainment 5 10th June 2009 20:38
Price of MTX Thunder AMP? superbhikari In-Car Entertainment 26 8th June 2009 09:44
mtx XT693 mdesai_1981 In-Car Entertainment 20 19th May 2009 23:48
URGENT: MTX or Pioneer? panky12345 In-Car Entertainment 39 9th June 2006 19:41
Mtx JackHammer nosfreak In-Car Entertainment 20 17th March 2006 16:31
