Old 24th November 2010, 13:54   #16
Pr_007's Avatar
Thanked: 9 Times
Sanjayc, there is also a cable where you can take audio out from the 3.5mm jack on your PMP/mp3 player and the other end would have a USB kind of a PIN where you can connect it to the USB port.
Pr_007 is offline   Reply With Quote
Old 24th November 2010, 16:26   #17
Thanked: 7 Times
Could not understand! The usb cable is used by any hu to access the mp3 etc stored on a usb drive and then the files are decoded internally in the HU - how would connecting 3.5 jack, which just carries analog audio signals be connected to the usb jack of the HU? Or, Am I missing something here?
sanjayc is offline   Reply With Quote
Old 24th November 2010, 17:49   #18
DerAlte's Avatar
Thanked: 2,876 Times
... take audio out from the 3.5mm jack on your PMP/mp3 player and the other end would have a USB kind of a PIN where you can connect it to the USB port.
If one does that, all one would here is a very comforting and relaxing silence (and maybe see an error message on the HU).
USB port contains 4 pins: +5V, D+, D- and GND. D+ and D- are serial digital signal pins. If one connects output from an analog device to the D+ & D- pins, the hardware will not be able figure out any 1's and 0's expected in the serial digital data, and will think that there is no signal coming, and output no data to the mixer in the HU, and hence no music.
Originally Posted by sanjayc View Post
... Or, Am I missing something here?
No, nothing much, just the climax scene. Sorry, couldn't help it!
Old 24th November 2010, 20:30   #19
mohitd's Avatar
@Kiran - thanks for the idea, but sorry I can't afford to spend more money(already have and air filter and exhaust lined up in my list of expenses )
@deralte - I agree with what you said. You cannot connect a 3.5 pin to USB with any interconnects as it will be pointless.
Has anyone faced a similar problem? Is there anything that can be done or is it a lost battle?
mohitd is offline   Reply With Quote
Old 26th November 2010, 13:31   #20
navin's Avatar
Thanked: 3,882 Times
Originally Posted by DerAlte View Post
USB port contains 4 pins: +5V, D+, D- and GND. D+ and D- are serial digital signal pins. If one connects output from an analog device to the D+ & D- pins, the hardware will not be able figure out any 1's and 0's expected in the serial digital data, and will think that there is no signal coming, and output no data to the mixer in the HU, and hence no music.!
I know the ipods expect some +/-2 2V signals at D+ and D- as well. So if the USB port is putting DC at D+/D- this can damage any non USB device connected to the USB port.
Old 26th November 2010, 16:23   #21
abhibh's Avatar
Thanked: 33 Times
I am usually not well versed with iPods as i only like their Classic 120/160 GB ones.
Try some other ipod if your friends have any and see if that works.
Old 27th November 2010, 10:39   #22
DerAlte's Avatar
@mohitd, did you use the same connecting cable in your friends car to check your iPod? If not, your cable might be suspect. And, as @abhibh said, try another (if possible older) iPod in your car to check if that works.
Old 27th November 2010, 12:20   #23
navin's Avatar
The Classics (120/160) also expect some DC at pins 2 and 3 of the USB. I think this DC is derived not from the USB per se but within the cable supplied (via a resistor network). I measured the voltages at the end of the ipod cable (30 pin connector) see PDF below
http://www.qables.com/shop/images/pdf/ipodpinout.pdf
same thing via web link so you can save the same in your browser (note exceptions made for iPhone/Touch and new nano).
http://pinouts.ru/CellularPhones-A-N...r_pinout.shtml
nice photos included here
http://www.allpinouts.org/index.php/...nd_iPhone_dock
short explanation of pins
http://nuxx.net/wiki/iPod_Dock_Connector
Old 27th November 2010, 12:27   #24
joybhowmik's Avatar
Thanked: 1,905 Times
If you are trying to get lossless output - suggest you stick with OEM CDs and play that on a properly cleaned HU, with good speakers and good wiring.
Be prepared for loss in signal due to
a) interface loss when you port the song to a flash drive, ipod or other player and connect HU to it
b) signal loss when you change the format from native recording format to mp3, flac etc
However, for most people, this loss in quality is acceptable as the environmental noise in a car is higher than in a recording studio - so people hardly notice either form of loss over for example wind noise or tyre noise.
Last edited by joybhowmik : 27th November 2010 at 12:32. Reason: better explanation
Old 27th November 2010, 20:15   #25
DerAlte's Avatar
Originally Posted by joybhowmik View Post
... a) interface loss when you port the song to a flash drive, ipod or other player and connect HU to it...
Why would that cause ANY loss? Those interfaces are not meant to lose bits and bytes. There would be a corresponding loss in general data, if so, leading to a possibility of 'woman' becoming 'man' in a text document, for example.
Old 28th November 2010, 08:35   #26
joybhowmik's Avatar
This is because digital signal processors can drop information bits albeit to a lesser extent than analog signal processors. But the loss is known to happen. You don't see this in networked computers (based on your example above) because networking protocols have in-built mechanisms to resend message in case of send/receive failures.
However, in real-time when two DSPs are connected to each other there is a possibility of drops.
Old 28th November 2010, 09:34   #27
joybhowmik's Avatar
@DerAlte
Another explanation as I could not modify my earlier response-but essentially the same thing:
Signal loss/Information loss can happen either inside the synchronously connected DSP or their interface. example a PMP connected to a HU using any interfacing mechanism.
On the other hand, when two DSPs are asynchronously connected using any interfacing mechanism, they may choose to implement mechanisms which guarantee information delivery. An example is networked computers, which rely on the networking protocol to calibrate the information content and exchange meta-data, thereby each computer is then able to request a message resend, in case the meta-data does not match the content received.
Old 28th November 2010, 12:19   #28
DerAlte's Avatar
... digital signal processors can drop information bits albeit to a lesser extent than analog signal processors. But the loss is known to happen. ...
... Signal loss/Information loss can happen either inside the synchronously connected DSP or their interface. example a PMP connected to a HU using any interfacing mechanism ...
This is a very involved subject where simple assumptions and modeling does not help.
The processors, neither the analog ones nor the digital ones, 'drop information' within the chip real estate. (Massive dose of) EMI interference may cause information or signal to be corrupted, like when old 2-stroke engine autos induce when standing beside you at a traffic signal. But, that is not the chip's fault. I am sure TBHP members who are into chip design will be able to quote real numbers of bit, byte or signal drop within the processors.
USB communication (short cable length, lower frequency than Ethernet), as opposed to networking communication (long cable lengths, much higher frequency), is much less susceptible to interference which is the main cause of drops.
Analog signal transmission to Aux-in, on the other hand, is much more susceptible to interference. Prevention: better shielded cables, even though one cannot obviate interference. Interference shows up more, and that also directly on the signal for longer durations than digital reproduction. Analog is also affected by line capacitance/inductance, which causes information loss (much less 'air' in high frequencies).
Since in digital reproduction, the possibility of frame decompression failure on bit / byte drop is higher than when bytes are decompressed at source (or not compressed at all), streamed uncompressed music (WAV) is always better than even loss-less compression. Here, frame = set of bytes representing a longer duration of music than the much smaller set of bytes representing the smallest duration of music in digital reproduction.
... However, in real-time when two DSPs are connected to each other there is a possibility of drops.
Theoretical possibility is always there. However, to know the practical impact on enjoyment of music, one has to relate to the real probability of that happening.
There are ways of calculating this, and data exists from studies in academics. Engineering of electronics deals with this very pragmatically to obviate the factors that contribute to data / signal failure. One wouldn't lose sleep on that, since there are hundreds of engineers who have studied it and created preventive measures.
Old 28th November 2010, 19:00   #29
joybhowmik's Avatar
Quite right. I tried to simplify this - but basically the more the complexity of the end-to-end system, the more chances of something going wrong somewhere. Most people in most circumstances can live with these inaccuracies - however, in a true sense it would not be technically lossless - which is what I was originally referring to.
At risk of , would affirm that signal corruption within digital circuitry is a given. It always happens - and I am yet to see a circuit which can protect against it 100% of the time. Most manufacturers avoid liability by publishing the operating ranges - which works for most of the situations most of the time.
Also as you have rightly pointed out , wires used to connect PMP to HU could pick up interference, and at that point it is really up to the logic embedded/written in the PLC of the HU to ignore the offending input. Better shielding is an answer, however, in a country such as ours - everyone may not have access to high quality connectors -and these are expensive also.
Old 29th November 2010, 00:55   #30
mohitd's Avatar
Thank You so much guys. My Ipod is working just fine after I updated the firmware My head unit reads ALAC off the ipod straight. Thank You guys.
JVC Head Unit Problem. revtech In-Car Entertainment 13 5th October 2015 12:05
Advice needed for playing FLAC files through ICE ZeroThoughts Gadgets, Computers & Software 9 24th September 2010 14:41
Can it happen?? - Replacing a 2 DIN Head Unit SRK In-Car Entertainment 9 8th May 2006 11:37
Need a DVD head-unit Sahil In-Car Entertainment 1 24th June 2005 13:43
Pioneer 5750 Head Unit neverclever In-Car Entertainment 4 14th June 2005 07:09
