Old 30th November 2010, 19:00   #1
quakerme's Avatar
Thanked: 56 Times
Default New Amp and sub for existing setup
Hi Planning to upgrade my current setup please advise,
HU Pioneer 4050USB
Front : nothing
Rear : Infinity Ref9633i
vehicle : IKon tdci
Im looking at a budget of <13k for sub and amp if possible front speaker's.
quakerme is offline   Reply With Quote
Old 1st December 2010, 09:38   #2
quakerme's Avatar
Thanked: 56 Times
Guys im looking for some help
Old 1st December 2010, 13:18   #3
DerAlte's Avatar
Thanked: 2,879 Times
Front: components - JBL, Blaupunkt, Hertz, Auditor, ... should be about 5-6K. Don't put this as "if possible" since this is the heart of the system, not what you have in the rear
Sub: JBL or Blaupunkt. With a box, this would be ~4K
Amp: Kenwood / Blaupunkt / JBL / Pio / Sony 4channel, ~4-6K
Cables, installation: another 2-3K
Since you already have a pair of good 6x9s at the back, you can put off getting the sub till you create another budget for it. With the 6x9 on the amp, it will give a decent feeling of bass. When you get a sub, drive the 6x9 from the HU and use those amp channels (bridged) for driving the sub.
Old 2nd December 2010, 00:39   #4
quakerme's Avatar
Thanked: 56 Times
Thanks DerAlte,
Based on the comments ive come up with the below configuration, Please let me know if it can be enhanced by adding a diff brand.
Component: JBL GT5-S265C - 5k
Sub: JBL CS 1215 - 4k
Amp: GT5-S422 - 4.5k
Old 2nd December 2010, 12:00   #5
torquarius's Avatar
Originally Posted by quakerme View Post
Thanks DerAlte,
S265C is lesser than 5K. While doing research for my ICE couple of
months back, the best price (with bill) I was offered for this model was 3.8K. And moreover this is an entry level component speaker.
If your budget is 5k, few more (better) options will open up for you.
DA will be here shortly to give you better advice.
torquarius is offline   Reply With Quote
Old 2nd December 2010, 14:01   #6
DerAlte's Avatar
These seem to be MRP before bargaining / discount. Where did you get the prices from? S422 will not be able to decently drive a sub. S644 is a better option for a shade more.
IMHO you should try a slightly different approach - set the objective as which equipment you should buy (and then consider the budget at overall level), rather than select equipment which are the lowest cost so that you don't cross your set budget. By the 1st approach you can postpone till you can afford a really good equipment (like good components now, and sub later), by the 2nd you will compromise and get something which may not be that good.
Check around for prices of Blau, Hertz, Auditor and others. If JBL, audition and compare GT5 and GTO before deciding - any good dealer and installer will be able to do that for you. Conversely, if they hesitate to give an audition, they don't know their stuff - it is better to look elsewhere.
Old 2nd December 2010, 18:20   #7
montyguru's Avatar
why do you have speakers in rear?
assuming there's a reason, you could also begin with S422 and a component set. use the amp only for speakers. postpone the sub for later, get a monoblock for it. or a pre-amped sub.. if you don't want a really low n loud things.
montyguru is offline   Reply With Quote
Old 5th December 2010, 00:26   #8
quakerme's Avatar
Thanked: 56 Times
Thanks all.... i guess i will postpone the sub to a later time...will add a comp in the front with a proper damping (infi 6030cs-7k after discount :()
Old 5th December 2010, 18:58   #9
fiesta_21's Avatar
Thanked: 22 Times
Hey I heard my friend's ICE and was shocked at the bass generated!!He had a basic pioneer HU with USB front coaxials and rear 6*9(both sony).I couldn't get that much bass when I have invested more except the HU.I have hertz components and 6*9's,sony 6042 amp and ford OEM HU.
I am confused now.Can anyone tell me if I cahnge the HU will I get a better sound quality considering that I already have an AMP.
Also does an AMP generate the same output quality regardless of the input it gets.Please guys really need your help.
fiesta_21 is offline   Reply With Quote
Old 5th December 2010, 22:52   #10
DerAlte's Avatar
No, you are doing an apples to oranges comparison. The other system could have been playing at a higher volume with Bass set to highest (the HUs are different). Don't be disappointed.
An amp DOES NOT produce the same quality regardless of input. Tune your system well, and you can leave the others behind! It will definitely help getting a better HU, but the OE HU will not be incompetent.
Old 6th December 2010, 09:40   #11
fiesta_21's Avatar
Thanked: 22 Times
@DerAlte: Hey thanks for the tips man.Really helped to calm me down.Now in my fiesta's HU the top row of buttons dont function(buttons like next track,CD/FM and the button controlling the bass and treble).This is the main reason I want to change the HU and also I am tired of writing audio CD's.I am planning to go for the JBL(333) HU which is set for its launch soon in the markets.
Anyway can I tune my setup to get a better bass(my amp does not have any bass boost option)?
Old 6th December 2010, 11:26   #12
DerAlte's Avatar
There is not much you can do if your HU buttons don't work. Could be simple loose contact - see if you can get the Ford service guys to look at it.
Some HUs allow equalization to be changed via remote - do you have that?
Old 6th December 2010, 11:48   #13
fiesta_21's Avatar
Thanked: 22 Times
Got to check if its a loose contact.Anyway I dont have a remote for the HU
Which sub/amp to add to existing system? sidharth_j In-Car Entertainment 61 30th April 2010 09:46
wagon r ice medium value for money setup wih sub and amp in chennai dvprasad In-Car Entertainment 2 24th April 2010 19:49
hi to all guru's - Q on adding a Subwoofer to existing setup ajji In-Car Entertainment 8 6th July 2007 12:29
Help for adding speakers to an existing ice setup shrayv In-Car Entertainment 3 20th June 2007 22:56
Amp for existing Baleno Setup Speedme In-Car Entertainment 14 11th December 2006 09:14
