Old 7th December 2010, 15:48   #16
fiesta_21's Avatar
Thanked: 22 Times
Guys I need a good SUB for my existing setup.Total budget is 7k(max).
The wiring should cost about 2K(or is it available for a lower cost)
sub+enclosure 5K
Suggest me a good sub.I need a punchy bass!Please guys dont try to exceed the budget
fiesta_21 is offline   Reply With Quote
Old 7th December 2010, 16:14   #17
navin's Avatar
Thanked: 3,885 Times
sub+enclosure 5K
You wont find a decent subwoofer under 5K (with box). Perhaps the Pionee 307 could be an option.
have you looked at the classifieds?
http://classifieds.team-bhp.com/buy-...b-Woofer.html/
http://classifieds.team-bhp.com/buy-...ubwoofer.html/
http://classifieds.team-bhp.com/buy-...4-12Inch.html/
Old 7th December 2010, 16:27   #18
fiesta_21's Avatar
Thanked: 22 Times
Hey thanks Navin.The JBL cs1215 sub should give a punchy bass with a JBL 300.1 mono right?I also have a problem that when I travel with my parents they dont want any effects from the sub.Can I control the power input(from battery) of the mono amp with a switch so that I can turn on the sub whenever i want?
Old 8th April 2011, 00:40   #19
ayushagarwal26's Avatar
Thanked: 85 Times
Default Re: ICE - Need urgent advice
I have a very similar query to the one this thread was originally set up with. Have a Sony 554 4 ch amp, which puts out 50W RMS x 4 at 4 ohms, and 75W at 2 ohms.
Now, I use two bridged channels to power a CS1215, and was looking at powering a set of GTO507C's up front. However, since I have a Fiesta, which takes 5 x 7 speakers, I am also considering 2 pairs of GTO8628 coaxs.
Now, the apparent option is to power the fronts from the amp, and leave the rears to the HU. However, what happens if I choose to power BOTH pairs of speakers, front and rear, in parallel from the amp? Again, overall impedance per channel will be 2 ohms in parallel, which means I still get a 75W output. Each speaker gets 37.5, right? Same PD but half the current? (Hope I don't sound ))
I agree there will be some losses, but if I want balanced sound from the front and rear (I like my soundstage up front, but like a little sound from the rear as well. And HU power doesn't do it!), will this set up do the trick, if I increase the gains a little bit for the speakers?
ayushagarwal26 is offline   Reply With Quote
Need Urgent Advice: 1.7K done Audi Q7: EDIT booked Toureg Edit: cancelled, now Q7 entropy Luxury, Imports & Niche 160 27th April 2010 07:27
Need Urgent Advice. Dragonov SUVs, MUVs & 4x4s 2 30th April 2006 11:03
need sum urgent advice !!! manson Motorbikes 27 16th November 2004 21:44
