Old 6th December 2010, 10:23   #1
Mi10's Avatar
Thanked: 1,459 Times
Default Mid Range in A/C Side vents ?
Has anyone tried mounting a 3.5" midrange speakers in the side A/C Vents of a car ?
My Mid range seems to fit in plush, like a OEM fit.
Just want to know, if this can be done. Probably routing the Air through main vents alone. Is it feasible ?
Attached the pic for reference
Thanks in advance
Mid Range in A/C Side vents ?-midrange-location.jpg
Mi10 is offline   Reply With Quote
Old 6th December 2010, 11:01   #2
navin's Avatar
Thanked: 4,282 Times
Where will the tweeter go? above the midrange?
The AC balst will get diverted to the center but you wont get an even spread of airconditioning. Why not try the aircon out by closing the vents first?
Old 6th December 2010, 11:55   #3
Mi10's Avatar
Tweets in stock location. Its very close to the A/C Vent (above and slightly sideways)
Ya i am ok with that. As long as it doesn hinder with other electrical.
You mean just to try out the throw and spread with Side vents close right. Yeah, i ve done that and seems k with me. The thing is its mostly driven by me alone - Even the front passenger seat will be mostly empty, forge the rears
So this thing is do able right ?
Old 7th December 2010, 09:15   #4
DIY Guru's Avatar
Thumbs up
Can please confirm that you want to install it inside (or is it beside?) the AC vent tube on the either side of your car?
By the way which car is it?
Yes, it is feasible but I recommend opening the panel covering the AC vent and covering the AC tube with some sort of a sheet (direct blast of the AC on the speaker could damage it over it time, why to take a risk). The AC vent fins (as shown in the picture) can be easily removed from the panels and the speaker can be fitted inside (I recommend testing this first before opening the panel to see if the speaker fits snugly inside the AC vent).
DIY Guru is offline   Reply With Quote
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
Interesting facts about Left Side or Right Side Driving kreddy Street Experiences 28 7th November 2013 14:30
Amalgamated bass+mid range+high range. nickoo In-Car Entertainment 24 2nd July 2008 08:21
Mid Range & Top speed loss in my Karizma - Please help redrage Motorbikes 11 14th October 2007 01:11
Low Mid Range with Pioneer HU maverick In-Car Entertainment 2 2nd January 2007 15:07
