Old 16th December 2010, 19:43   #1
OHCVtec's Avatar
Thanked: 12 Times
Default Sound from the Front Component Speakers not Satisfactory
Dear Gurujis,
I have JBL component speakers in the front and JBL's on the rear. A four Channel 800W JBL Amplifier drives these speakers. The reason I went for an amp was that the front components were hardly audible, however even after putting in an amplifier, the sound from the front speakers is hardly audible. Also the Fader and Balance of the HU do do not function as they should, the dealer told this is because the HU is not four channel. I am not sure if this is normal or is there something wrong with my setup.
Thanks for your inputs.
OHCVtec is offline   Reply With Quote
Old 16th December 2010, 22:17   #2
abhibh's Avatar
Thanked: 34 Times
Default Re: Sound from the Front Component Speakers not Satisfactory
Which HU do you have ?
Old 17th December 2010, 10:48   #3
DerAlte's Avatar
Thanked: 2,879 Times
Either the dealer is using cryptic language and does not know how to explain the problem, or does not know at all what he is talking about.
1. What are the model numbers of the HU, amp and speakers?
2. Were you present when the system was installed? Did you audition is as soon as the installation was completed?
3. How many RCA cables did he use? If he has used only 1 pair quite likely the same signal is going to the front and rear amp channels (if you are sure it is a 4 channel amp). If so, Fader will not work
4. If Balance is not working the problem could be that either left or right channel is connected to the front channel, and the other to the rear channel (I hope the installer was not that dumb). In that case Balance will work as Fader, and the setup will sound really funny!
5. If there is no low mid-bass punch, quite likely the mid-bass are wired out of phase. This can be corrected by reversing the connection at one of the mid-bass speakers
Go back to the dealer and ask him to open up the system and show you where and how he has made the connections. I am sure he will have many 'Ooops!' moments.
Old 17th December 2010, 11:09   #4
motomaverick's Avatar
Thanked: 869 Times
Originally Posted by OHCVtec View Post
Dear Gurujis,
I exactly have the same system as you do, and faced the same problem. It is the HU, i think your HU has 1 rca pre-out so when the connection was made from the amp, 4 channels were clubbed into 2, so basically what is probably happening is the fadder is towards the extreme rear to drive all 4 speakers.
This was the case with me, i just changed the HU to 3390UB and all problems solved as this HU has 2rca preout.
Old 17th December 2010, 11:24   #5
Sam Kapasi's Avatar
Thanked: 1,473 Times
What I am guessing is that you have a HU with only one pre-out, that has been split into 4 using a Y-cable and then fed into a 4 channel amplifier.
The first thing you should ask your installer to do is INCREASE the gain on the front speakers. If you want to play the front nice and loud without any distortion, I suggest you switch the HPF on for the front (Since you have no sub, you can keep the rears, presumably larger, on without a filter)
You should cut off the front components at 60Hz or higher.
Then turn up the volume and watch them sing.
Top 10 6.5" Component Car Stereo Speakers k_ajay In-Car Entertainment 66 9th May 2018 16:53
Hissing sound from speakers when not playing music. Please help. vishnuvijay In-Car Entertainment 62 12th March 2016 15:17
Front Component Speakers for AVEO 1.4..need advice s3va In-Car Entertainment 2 6th October 2009 15:16
Lightning Audio 5.25" Strike Series Component Speakers for sale esteem_lover Shifting gears 2 15th August 2007 23:57
Lightning Audio Component Speakers blueraven316 Shifting gears 4 1st April 2007 14:55
