Old 22nd December 2005, 15:28   #1
amit1101's Avatar
Default The H bridge concept & Building an amplifier
hi team bhp
If i have an amplifier of 100watt rms into 2 channels
can any one tell me what will be the output in watt rms if
i connect these 2 channels in B bridge configration.
will it become 2 times(200rms) or 4 times(400rms)
ny help will be greatful
thankz
amit1101 is offline   Reply With Quote
Old 22nd December 2005, 18:18   #2
amit1101's Avatar
its h bridge nor b bridge sorry :-)
Old 22nd December 2005, 19:14   #3
navin's Avatar
Thanked: 4,282 Times
100W/ch at 4ohms would give 200W/ch at 4 ohms if the amp is stable at 2 ohms (in stereo).
Old 22nd December 2005, 22:11   #4
amit1101's Avatar
hello naven
here is a small derivation which says that i will get 4 times output that is 400watts instead of just double that is 200wats
POWER = VOLTAGE*VOLAGE/RESISTANCE
P=V*V/R
In the h bridge configration the voltage is doubled across speaker ( basic concept of h bridge)
power is proportional to square of voltage so when voltage is doubled due to h bridge the power will increase by a factor of square of 2, that means 4
can any one tell if i am right
Old 23rd December 2005, 11:29   #5
Sam Kapasi's Avatar
Thanked: 1,473 Times
I agree. However in a typical situation, a bridged ampifier gives about 175% in bridged mode. So a 100W X2 @ 4ohms
with roughtly translate into 175WX1 @ 4ohms
Old 23rd December 2005, 17:45   #6
navin's Avatar
P=V*V/R
amit you are gonna hurt yourself. :-)
P is also = I*I*R. that is where typical amps trip up. current capacity.
Sam, my home brew 200W/ch 8 ohms home amp dumped over 500W in bridged mode into 8 ohms. Then again it has a 1200VA trany and 120,000uf of filter caps. The fact is I use about 10W of this 30kg beast. the rest is for show!
Old 23rd December 2005, 17:57   #7
general_neo's Avatar
Thanked: 26 Times
Default 4 channels bridged to 1
Well let me have the best of it...
So guys, can someone tell me if i can bridge a 4 channel amp which is manufactured by the company to run 4 channel and 2 channels to do 1 channel.
IE, Connect on single sub and derive the complete power to a sub. Well I am sure u can have two speaker setup on these easily but is the 1 channel setup advisable and recommended. If yes, how is it done.
Hope i am clear.
general_neo is offline   Reply With Quote
Old 23rd December 2005, 18:04   #8
Sam Kapasi's Avatar
Hope i am clear.
Hello General,
To tell you the truth - NO you arent clear
But i gather you want to bridge 4 channels into 1. No amplifier i know of does that yet.
Old 23rd December 2005, 18:34   #9
amit1101's Avatar
Default I*i*r
hello navin
here is the derivation in i square r format
suppose u have a normal amp , its a push pull amp and operates at +/- V rms volts
impedance of u r speaker be R ohms
during positive cycle the currrent through speaker is +V/R rms
during negative cycle the currrent through speaker is -V/R rms
total power is I*I*R where I= V/R rms
V*V/R watts ...........................................(1)
now u make an H bridge
since the voltage across speaker is now doubled the current will aslo double
bcoz V=I*R
thus in bridge
current during positive cycle is +2V/R
current during negative cycle is -2V/R
now power by I*I*R
(2V)(2v)/R
4*V*V/R watts ...........................................(2)
now the power in equation 2(bridge) is 4 times that of equation 1(normal)
amit
Old 23rd December 2005, 18:51   #10
Sam Kapasi's Avatar
amit101 - look at navins statement again: CURRENT CAPACITY is the key. We're talking about amplifiers that run off a 12V battery and have a limited power supply to say the least. Current will double only if the power supply is capable enough to supply the juice
Old 23rd December 2005, 20:55   #11
Thanked: 26 Times
Originally Posted by Sam Kapasi
Hello General,
I am sorry..
If i were in ur place reading my post, I would be shellin u with abuse... heheheh!!!
U answered my question... but i tried reading my own post and it doesnt make any sense at all.
U must be a genius to understand what i was looking for...
Old 23rd December 2005, 21:34   #12
navin's Avatar
gen neo, geez. you cant do that. think when you bridge an amp the +ve's are used across both channels. once you have done that how do you connect 2 bridged amps?
Old 23rd December 2005, 22:54   #13
Thanked: 26 Times
I consider myself moderate, when it comes to audio setup. I raised the question becoz i didnt believe such a thing cud be done. But how ever When the tread started, i felt somebody was talkin about it and wanted to clarify. Neva know wats in and wats out. Thanks for the intel...
Old 25th December 2005, 18:57   #14
amit1101's Avatar
there is no limit on the voltage u can obtain from a car battery
we use a circuit called chopper boost up circuit which can avail us 250 volts dc very easily
u must have noticed coils in amp. those are passive filters but mainly they are the paart of this chopper ckt.
if there was no choppers we would have to keep big big transofrmers at our back with amp. :-)
Old 25th December 2005, 21:55   #15
navin's Avatar
there is a limit on the power supply on most power amps.
P=V*I=I*I*R Even is V=250 you still have to dump amps. it is the current capacity which limits most amps.
On the anvil: 22,000 crore hybrid bridge-tunnel connecting India & Sri Lanka darklord Street Experiences 4 21st December 2015 12:07
Alto'ed: Dooar Diaries (Coronation Bridge, Mal Bazaar, Chalsa, Samsing & More) YanTra Makto Travelogues 18 30th April 2014 21:49
The building of a concept bike... Tyagi Motorbikes 14 15th January 2010 13:44
Kali bridge at Karwar closed for a month - Traffic between Goa & Karnataka diverted misquitas Route / Travel Queries 0 11th December 2009 23:34
two channel Amp - how to bridge? zzzehar In-Car Entertainment 15 19th May 2006 17:22
