Old 2nd September 2015, 01:17   #46
Paradox's Avatar
Thanked: 11 Times
Default re: ICE upgrade : Maruti Ritz
Originally Posted by Sunsh!nes View Post
It also helps create a gap between the speakers and the body when the speakers are deep and have big magnets.
Sorry to be a muggle, if these spacers are added, will it not make the doors fat and hamper the safety?
Paradox is offline   Reply With Quote
Old 2nd September 2015, 19:44   #47
Sunsh!nes's Avatar
Thanked: 96 Times
There is ample gap between the doors and the speakers even if these MDF rings are placed, In Bangalore almost all audio professional installers place a MDF ring between the speakers and the door. Moreover, they are only about an inch or so in thickness. You can check with any audio installer in your city. I had done it in my Ritz so can say, there is lot of gap in the doors. Shouldn't matter. Dont worry. Once the Door pads are fixed you wouldn't even know.
Last edited by Sunsh!nes : 2nd September 2015 at 19:45. Reason: adding information.
Sunsh!nes is offline   (1) Thanks Reply With Quote
Old 3rd September 2015, 21:43   #48
Paradox's Avatar
Thanked: 11 Times
Can someone help at this odd hour? I'm stuck with a car decor at KPHB. They don't know how to install ICE.
Old 3rd September 2015, 21:52   #49
Thanked: 13,389 Times
I have ordered the following for my Ritz Zxi:
And, any recommended place to install these near KPHB or Madhapur - Hyderabad?
Where exactly are you?
Try visiting Reliance Car Decors on the Madinaguda road (Near Lingampally).
What is the problem that you are facing?
Old 3rd September 2015, 21:55   #50
Paradox's Avatar
Thanked: 11 Times
I bought HU and speakers from them. All installed, but they are lost when it comes to connecting the steering controls.
I'm near Road # 1, KPHB.
Old 3rd September 2015, 22:17   #51
For that may be you'll need to visit MASS for it get working correctly or any high-end audio installer.
Didn't they how the OEM wiring is done before the HU change?
Old 3rd September 2015, 23:55   #52
Sunsh!nes's Avatar
Thanked: 96 Times
You will need Steering remote interface for Ritz which you should get for less than 2.5K and this should fix your problem with connecting the player controls to the steering controls.
Sunsh!nes is offline   Reply With Quote
Old 4th September 2015, 00:23   #53
Paradox's Avatar
Thanked: 11 Times
But the HU I bought from them ( Sony - XAV-68BT-15.7 cm WVGA Touch Panel Monitor with Bluetooth) has steering wheel control configurations. Should I still buy additional?
Old 3rd October 2016, 15:13   #54
Shreeniwas's Avatar
Thanked: 19 Times
Default Re: ICE upgrade : Maruti Ritz
Hello All,
Sorry for bringing up this old thread. I was planning to change HU of my Ritz VDI Genus which comes with company fitted Nippon HU.
I was wondering if it is possible to change HU ? As the existing HU looks like single unit. How and where do I fit a single DIN unit after removing the stock HU. Is there a replacement flap available as in LXI/LDI ?
Shreeniwas is offline   Reply With Quote
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 384 3rd June 2017 20:36
2010 WagonR Vxi Vs Ritz Lxi EDIT: Its Ritz ! akshay Hatchbacks 24 25th July 2014 12:57
ICE'd - Maruti Suzuki Ritz a4anurag In-Car Entertainment 5 18th February 2012 18:51
My very own first car - Ritz Zxi or i10 Asta? EDIT: Booked Ritz Zxi. Gandhi Hatchbacks 93 24th November 2009 15:50
Maruti To Launch Suzuki Splash as Maruti Suzuki Ritz in May 2009 romeomidhun The Indian Car Scene 350 9th May 2009 19:33
