Old 5th January 2011, 18:13   #1
Default SQ help: Genesis Profile 5, ClarionDXZ785, Rainbow 3 way
My Setup:
HU: Clarion DXZ785USB
Speakers: Rainbow Soundline 3 way components (Non Kick version)
Amp: Genesis Profile 5 (Bridged 4 channels to power up the comps)
Cable: Audison 6 channel BT series RCA.
Sub: ID CTX.
Damping: Dynamat Extreme in boot and Left and Right doors.
Problem: Not happy with Midbass and midrange. Midbass sounds muddy, while midrange a tad shrill. Need more kick from the midbass and a smoothened and rounded midrange.
Please help and let me know where am I going wrong?
The set up is semi active.
Cross over points:
Highs: HPF : 4k
Mids: LPF: 1.2K
HPF : Through
Sub: LPF 80 hz
HPF: Through
All slopes at 12
The rainbows are bi amped (Genesis 5 channel)
kumargandharva is offline   Reply With Quote
Old 5th January 2011, 23:47   #2
Thanked: 294 Times
Default Re: SQ help: Genesis Profile 5, ClarionDXZ785, Rainbow 3 way
From where did you got the installed done as you are from Meerut ??
And why are the Mids HPF is through ?? try it at 80 hz !!! and so wide gap between mids and high 1.2k hz to 4hz ??
Old 5th January 2011, 23:51   #3
abhibh's Avatar
Thanked: 34 Times
1. Amp: Genesis Profile 5 (Bridged 4 channels to power up the comps)
2. The rainbows are bi-amped (Genesis 5 channel)
How did ya manage to achieve that ?
If you are running the XO which came with the speakers why are u setting the filters on HU?
Old 7th January 2011, 20:09   #4
Correct it should be working via the Passive Crossover of the Component system
Piyush_Vroom is offline   Reply With Quote
JBL 608GTi or ID CTX65CS or Rainbow CSX 265 DREAM or Rainbow SLC 265 KICK panky12345 In-Car Entertainment 52 12th November 2011 01:32
Rainbow Comps..which one to Buy? IDV3 12"..how much power? nitinralli In-Car Entertainment 121 18th May 2009 16:41
Sub and Amp recommendations for Rainbow components? Atlblkz06 In-Car Entertainment 38 22nd January 2009 14:44
Swift Gets the Rainbow!!! m4ugr8 In-Car Entertainment 26 5th August 2008 22:06
