Old 11th January 2006, 16:51   #31
Thanked: 76 Times
I am sorry navin. Can you please explain little bit more? Are you saying that it is recommended to use 2 channels to drive front speakers also?
msk_kapoor is offline   Reply With Quote
Old 11th January 2006, 17:30   #32
rsjaurr's Avatar
Thanked: 27 Times
What he meant that u can bridge 2 ch of sony amp to power single subw and 2 ch can be then used for either front or rear.
Out of these two,front shud be given preference over rear [if u want to power front OR rear & NOT both]as u sit and drive from front where sound stage is more important.
rsjaurr is offline   Reply With Quote
Old 11th January 2006, 19:12   #33
navin's Avatar
Thanked: 4,284 Times
See Sam now Doc's got into the act too! :-) LOL
Old 11th January 2006, 23:30   #34
rsjaurr's Avatar
Thanked: 27 Times
u know navin,when i was doing my graduation,we used to play 4-5 games there and one of my my nickname was coach.
And no need to tell what coach has to do.
just trying my hands [rather brain] on giving some advice and not always asking for it.
Old 11th January 2006, 23:48   #35
navin's Avatar
I did not mean that Doc. Sam is always clarifying what i say since i am often vague. mosgtly the vagueness comes from being pressed for time. this time you clarified a vague post of mine. thanks.
Old 12th January 2006, 10:09   #36
rsjaurr's Avatar
Thanked: 27 Times
Navin,let me tell u,UR POSTS R NEVER VAGUE.We all look forward to ur replies.others will agree with me.I think we guys,in ICE forum r lucky to have somebody like u.Not so sure about forums.
My previous post was in good humour.I believe if we r getting something [especially free ], we shud not shy from giving it.Sometime i think if i remain here for another yr,i can start some sort of ICE business,quitting my profession...just kidding......
Old 12th January 2006, 10:59   #37
navin's Avatar
ha ha ... i've been playing with audio for about 30 years and never had any illusion about making it a business. the market in india is very small and what little is left post video boom concentrates on Bose look-a-like systems.
Fortunately my academic qualifications allow me to something other than audio for a living. BTW I know quite a few docs who are interested in audio the oldest being my 87 yr old aunt. She had old fisher valve amps, AR speakers, and a garrad turntable whay back in the late 50s.
Old 24th January 2006, 16:30   #38
Thanked: 76 Times
I finally settled for Blaupunkt GTA 270 Amp and Kenwood KFC-W3009 Sub-woofer.
Old 9th February 2006, 13:14   #39
Thanked: 76 Times
Hi Audio Gurus..... help needed again please..... :(
I am not getting proper bass effect in my Sub. I am not sure of how to tune the Amp settings. I have Blaupunkt GTA 270 Amp connected to a Kenwood KFC-W3009 Sub-woofer. Please let me know what will be the best setting here.
Old 9th February 2006, 13:25   #40
Any of those thing still remaining now?
Vivekphadnis is offline   Reply With Quote
Old 9th February 2006, 20:05   #41
navin's Avatar
no vivek. they were distributed to relatives in the US. she did not want to carry them to india when she moved here.
Old 9th February 2006, 20:06   #42
navin's Avatar
I am not getting proper bass effect in my Sub..
is the amp bridged? what do you mean by proper bass effect? is thebass loose? is the bass soft?
Old 10th February 2006, 10:43   #43
Thanked: 76 Times
yes it is bridged. I am facing with jarring effect. If i increase the bass boost it jarrs a lot and if i decrease the nass is very soft.
I can see the following adjustments in my Amp. What does these things actaully does? If i change Low-pass to high end 250HZ what will be the change in effect? and please explain the other things also.
Low-pass filter 50 - 250 Hz (12dB/Oktav)
High-pass filter 50 - 250 Hz (12dB/Oktav)
Bass Boost 0 - 12dB at 45 Hz
Old 10th February 2006, 15:20   #44
navin's Avatar
1. is there anything else vibrating but the woofer?
2. if it only the woofer that vibrating i suspect the woofer is being pushed beyond it's physical limits. which means you'll need a better woofer.
Old 10th February 2006, 16:26   #45
Thanked: 76 Times
Hi navin my woofer can stand 800w and the amp can produce only 400w output
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
Confused about audio config. exceeding budget luvjascha In-Car Entertainment 52 10th August 2006 20:15
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
