Old 10th February 2006, 22:51   #46
Autophile's Avatar
MSK,
Carry the following steps :
1. Switch ur amp crossover to LPF around 80Hz
2. Check that ur gains are not turned all the way up. If yes then turn them down to half
3. Switch off bass boost on the amp.
The 400W amplifer has no problem in handling the 800W woofer. In your case I guess its the MAX power of the both.
If this also does not help. Then tap the woofer cone in the centre snd see if it makes crackle (sound), if yes then your woofer has gone
Autophile is offline   Reply With Quote
Old 11th February 2006, 09:25   #47
navin's Avatar
Thanked: 4,283 Times
Originally Posted by msk_kapoor
Hi navin my woofer can stand 800w and the amp can produce only 400w output
not a problem. does the woofer work well at low volumes and then make noises only at higher volumes?
navin is online now   Reply With Quote
Old 13th February 2006, 12:11   #48
Thanked: 76 Times
Thanks Autopile i will do these.
Yes Navin the woofer is working in low volumes without any issue. I am having bass boost nearly to 50% now.
msk_kapoor is offline   Reply With Quote
Old 13th February 2006, 12:45   #49
navin's Avatar
are use useing too much bass boost on either the Amp or the HU? if not then I can only suspect that the suspension of the woofer has deteriorated and maybe you need a new woofer.
if you are using any bass boost on the amp or HU please set these to flat and then listen.
Old 23rd February 2006, 10:36   #50
Thanked: 76 Times
Thanks all for your suggestions.now i am able to get a better sound. But the same settings give different outputs for different CD's. I assume them as CD problems
Old 23rd February 2006, 10:40   #51
navin's Avatar
Every recording engineer mixes CD they way they feel fit. The fact that you can distingush the differences means that you are listening. good work.
Old 23rd February 2006, 11:01   #52
Thanked: 76 Times
hi Navin..... one more question... my friends use the terms depth and punch associated with sub-woofers. what does these things mean?
Old 24th February 2006, 09:44   #53
navin's Avatar
msk, i dont think one can fully decribe these terms. It is best if you ask your friend to listen with you and explain to you during or after listening what is depth and punch and overhang and underdamped and overdamped etc...
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
Confused about audio config. exceeding budget luvjascha In-Car Entertainment 52 10th August 2006 20:15
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
