Old 6th January 2006, 12:38   #16
Sam Kapasi's Avatar
Thanked: 1,473 Times
On behalf of Navin:
He meant, acoustically isolate the sub. Physically, boxwise.
Old 6th January 2006, 15:25   #17
navin's Avatar
Thanked: 4,282 Times
yeah, what Sam says...it prevents Doppler distortion.
Old 6th January 2006, 15:52   #18
Post
hello sam,
right now 2 speakers and 1 sub is in 1 large box and installed in 3 different compartments of the same box.
1. should i put 2 speakers in 1 box and the sub in a different box? wont it feel as if bass is pounding from one corner of the boot?
2. or, should i get 3 different boxes and arrange the woofer's box in-between the 2 speaker boxes? will it sound better in this config or the 1st config?
regards,
anuj
Originally Posted by Sam Kapasi
On behalf of Navin:
rev_hard is offline   Reply With Quote
Old 6th January 2006, 17:22   #19
Sam Kapasi's Avatar
Originally Posted by rev_hard
hello sam,
Then it's ok - just make sure
1) the 3 compartments are properly sealed from each other.
2) Lower the gain on your 222, connect only the speakers to it and get a decent amp for the subwoofer.
3) Love your parents and be faithful to your woman (And if you cant be faithful, try really hard)
Old 6th January 2006, 18:14   #20
Post
hi sam,
i have two sony 222's installed. should i junk 1 for a upgrade and connect one speaker each to one amp or is 1 222 enough for 1 sub? also, what amp upgrade would you recommend.
regards,
anuj
Old 7th January 2006, 15:16   #21
Sam Kapasi's Avatar
Use 222 for the fronts and one for the rears. As navin suggested, buy a JBL CS60.2 for the subwoofer. Bridge it and connect it in LPF mode to the sub. Buss. Ho Gaya.
Old 7th January 2006, 16:12   #22
iceman91's Avatar
Thanked: 22 Times
yeah i have not heard the jbl..but if sam and navin say its good go for it..else get a good monoblock for around 6-7k...
you can also check the sony monoblock, pioneer monoblock. they are in your budget...more expensive ones are alpine rockford fosgate earthquake etc..
iceman91 is offline   Reply With Quote
Old 9th January 2006, 10:40   #23
navin's Avatar
funny but at teh lower price points a stereo amp bridged into mono might be better VFM.
Old 9th January 2006, 11:17   #24
Sam Kapasi's Avatar
I have heard the 60.2 bridged into one 12" woofer - it makes phenomenal VFM.
Old 9th January 2006, 11:22   #25
navin's Avatar
at a lower price point the sony 502 can work too.
Old 10th January 2006, 10:37   #26
Post
hi navin,
isn't the 502 another 2 channel amp from sony. i got it fitted in my bro's zen. i feel its just a marginally better product than the 222. confusion is reigning supreme herein navin, so please clarify.
i think 502 is just rated at 28w pmpo above the 222. does it really make a difference then?
regards
anuj
Old 10th January 2006, 10:52   #27
navin's Avatar
I've heard about the 502 and used the 504. the 504 is very grainy but ok for sub duties as it can swing volts into low impedances. I expect the 502 to be a 2 ch. version of the 504. However if you are in doubt try the JBL 60.2 albeit at a higher price.
I have not compared the 222 to the 502 or 504 so cant say for sure. However there are many amps that while being ok running into 4 ohms run out of steam when asked to manage a 2 ohm load.
A 2 ch. amp when brdiged sees a 4 ohm speaker as it would 2 ohm speakers if it was used a stereo amp.
Watt ratings of most amps are very optimistic. I would test the 502 on the grounds that if it does not swing enough volts (is not loud enough) you can upgrade to the 60.2 and if that is not enough the 300.1! :-)
Newbie needs Guru's directions in selecting DVD + USB Head Unit :) touringmaniac In-Car Entertainment 29 5th November 2008 10:29
<Newbie Alert> IronWolf Baleno Bangalore <Newbie Alert> IronWolf Introduce yourself 26 21st June 2007 20:28
