Old 26th February 2011, 12:22   #1
Thanked: 57 Times
Default Pioneer HU dead after battery recharge
Few days back my car's (Getz prime, 2 year old) battery had fully drained after I had left the key inside in the on position and fan running throughout the night. Next morning I got a jumper cable and started the car. I have driven the car last 2 days and all other electrical components including AC are working fine. But the Pioneer HU seems to be dead - display is totally blank and nothing seems to work with it.
Is there anything simple I can do myself to check the unit or do I have to take it to a service center.
mohan41 is online now   Reply With Quote
Old 26th February 2011, 12:27   #2
akshay4587's Avatar
Thanked: 1,686 Times
Default Re: Pioneer HU dead after battery recharge
i faced same problem when battery drained in my car.
it was a kenwood HU,i had to reseat the wires at the back of HU,and it was fine after that.
Old 26th February 2011, 19:48   #3
Thanked: 103,372 Times
First, check the fuse. If it's not blown, remove the battery's negative terminal for 5 minutes, then reconnect it. Most probably, either should do the trick.
Old 26th February 2011, 20:22   #4
thedreamcatcher's Avatar
Thanked: 62 Times
Most probably to do with a bad fuse. But am curious to know, why you left the car on the whole night, with the blower on?You could not have forgotten all this now, could you
It happened to me once, I was taking a call, and was sitting in my car with the blower on, music on, lights on and after about an hour or so on the phone, the car never started. Had to push start the car and after that it was fine. It most probably is a blown fuse, because of the sudden power surge caused by jump starting
thedreamcatcher is offline   Reply With Quote
Old 27th February 2011, 14:40   #5
Thanked: 57 Times
Thank you GTO, I will check the fuse (first I have to find out where the fuse is, but I will do that)
Something similar happened here. It was around 10 PM, I was talking over the phone after I had got the car inside the portico, engine and lights were switched off by then, and I somehow forgot the key, got out of the car, went inside my house, had dinner and totally forgot about the key.
And was thinking why the fuse would be blown, and you seem to have a valid point, it could be due to the surge from the jump start.
I dont have a jumper cable and I was trying to push start the car. Only then I realized the Getz would not start with push start. One has to keep the clutch pedal depressed to start the car, so when the car was pushed and I released the clutch it didnt start.
Old 3rd March 2011, 21:48   #6
Thanked: 57 Times
Smile Re: Pioneer HU dead after battery recharge
I couldnt check the fuse, so decided to try GTO's suggestion. Removed the battery terminal for a few minutes, connected it back, inserted the key and HU is working!
Thank you GTO Sir!
Old 4th March 2011, 15:36   #7
Thank you GTO Sir!
Happy to help. Sometimes, and just like a Microsoft Windows OS, a reset / restart inexplicably solves the problem in modern cars
AC gas recharge, big scam? tsk1979 Gadgets, Computers & Software 106 2nd March 2017 18:30
Swift : Battery 100% Dead : What to do? manjubp Technical Stuff 91 25th June 2013 21:21
Rechargeitnow.com - Money deducted, not received Airtel recharge. EDIT : Refunded bluevolt Gadgets, Computers & Software 8 24th April 2012 13:32
NHC - AC Regrigerant Gas and Refrigerant oil recharge anandpadhye Technical Stuff 12 27th June 2007 12:05
Battery dead! Help! superavi Technical Stuff 7 1st June 2006 14:10
