Old 1st March 2011, 12:27   #16
fine69's Avatar
Thanked: 883 Times
Default Re: SPL Setup in Swift for 35k
I would suggest you to get one good sub instead of two entry level subs. I was planning on getting two 1214's myself but after taking all the advise I got from here I settled for a single MKII
Do you mean GZ MKII? Is it still available in the market? I couldn't locate it on the website and 30T seems to retail somewhere around 9k if I'm not wrong (which is out of my budget).
I don't think given your budget a dual sub setup would be a good choice.
Heart says I should get 2 subs but in my head somewhere I feel that getting 1 sub for 7-8k makes more sense.
fine69 is offline   Reply With Quote
Old 5th March 2011, 16:14   #17
fine69's Avatar
Thanked: 883 Times
Hours and days of reading through threads, getting recommendations and almost going into depression because of my inability to audition certain component speakers I still managed to finalize (almost) the setup for my car:
HU - JBL x333
Front Components - Morel Maximo (shall audition every other comp in this price range as well on D-day)
Sub - ID CTX 12" in ported enclosure (shall also audition Bull/JBL subs on D-day but doubt if they are any match for the ID sub based on what I've read)
Amp - JBL GTO 1004 (I hope its not an overkill for a 175 rms sub, this question posted on another thread already)
This was finalized after my visit to Driven again today. They have an entire roll of power cables (different gauges) and as told to me they'd be using the power cables from that roll (can't recall the brand) and hence I've not specified the power kit separately. (it'd still cost 3k)
The total cost of the setup would be around 35500/- (excluding dampening and if I finalize Morel Maximo)
I have a question for the audio gurus though, what gauge power cable should be used for such a system - 4/6/8? (and if you could share how its determined)
Also, is there only right one set of dimensions for a ported enclosure? I mean if boot space isn't an issue for me would increasing the capacity of the enclosure (proportionately) give me a louder output without compromising on the quality of the sound?
Old 5th March 2011, 22:14   #18
abhibh's Avatar
Thanked: 34 Times
HU - JBL x333
4-5GA wiring kit should be enough for the setup. Just a suggestion if you plan to go down iD CTX route then stick with sealed enclosure.
Old 5th March 2011, 22:34   #19
fine69's Avatar
Thanked: 883 Times
What's the calculation behind determining the gauge/spec of the power cables?
The reason for a ported enclosure is to get more SPL but since you are recommending a sealed enclosure I'd appreciate the logic if shared, thanks.
Old 5th March 2011, 22:49   #20
Thanked: 158 Times
4 gauge wiring should be ideal for gto 1004.
Here's a link for you to calculate the gauge/spec for the wires for a given wattage-
Recommended Power and Ground Cable Sizes
BTW, another sub you might want to consider is infinity 1260w, rated at 300w rms at 4 ohms. It's currently available on ebay global for 4500 bucks-
http://orders.ebay.in/ws/eBayISAPI.d...d=330534900811
Or if you can stretch your budget for the sub from 8000 bucks to 9000 bucks, you can get infinity kappa 120.9w.
http://orders.ebay.in/ws/eBayISAPI.d...d=330529344142
Astleviz is offline   Reply With Quote
Old 5th March 2011, 22:57   #21
fine69's Avatar
Thanked: 883 Times
Oh, so its rms + distance (length) of cable used. Here the rms is per amp or per channel? (I hope the question isn't too stupid)
Another query unresolved is the sub enclosure dimensions, anybody?
@Astleviz: How are ID and Infinity (ref only as Kappa is way over budget) subs when compared? both SPL & SQ-wise
Old 5th March 2011, 23:39   #22
thelord's Avatar
The iD CTX can take that much power easily but to be honest, I wouldn't buy a CTX for SPL purposes. It's best played in a sealed box (0.8-1 cu.ft) with about 200-350W RMS. Have you auditioned the subs by Digital Designs or SMD? Ask Driven if they can arrange for an audition for DD and you can contact LBM for SMD.
thelord is offline   Reply With Quote
Old 6th March 2011, 00:23   #23
abhibh's Avatar
Thanked: 34 Times
Because AFAIK CTX perform better in sealed application and can take plenty of power and with the amount of power you have on tap (around 300W RMS) it can easily go loud in a 0.75-1 cuft. enclosure.
Old 6th March 2011, 11:14   #24
fine69's Avatar
Thanked: 883 Times
I didn't want to request title changes again and again but I've actually decided that if the budget doesn't permit a true SPL system why not just have a loud setup which offers good quality sound.
As for not auditioning DDs, the 12" subs start at somewhere around 11k and were again out of the budget.
I'll see if I would have the option of auditioning this sub in both sealed and ported enclosure. However, the installer has assured that even with a ported enclosure this sub wouldn't give any distorted/not likeable output at any volume. Ported only to increase the loudness of the setup.
The reason for narrowing down on the ID sub was that it was the only sub (as per the installer) which could really shake the car (at least from inside ) without compromising on the quality of the sound. Still, I'd audition the Bull/JBL/Infinity subs on D-day to ensure that I indeed chose the best (at 8k) of the lot.
From where I started (I don't know what I was thinking in my first post), the setup has finally started to make some sense (I hope you all would agree ). The SPL keeda (bug) really took its toll on me but I've ultimately emerged as a learned man.
EDIT: How do we know that the extra power that we'd be supplying to the sub beyond its rating (175w rms) wouldn't blow the sub. I mean what's the threshold here?
Old 6th March 2011, 11:59   #25
Thanked: 158 Times
For power cables, it's based on the total rms, in your case it will be 600w. So 4ga should be ideal.
As far as sub enclosure dimensions are concerned, every sub will have a recommended volume for sealed and ported boxes. Depending on which you decide, you can use the following link to calculate the exact dimensions of the enclosure-
Enclosure Volume Calculator (EVC)
I haven't auditioned ID subs but have heard good things about them, maybe other members can give their feedback. Infinity ref subs are quiet good, certainly better than the entry level jbls or bull audio, they can get quite loud while still sounding decent. A VFM sub, in my opinion. But then again, it all boils down to how it sounds to you.
Old 6th March 2011, 12:11   #26
fine69's Avatar
Thanked: 883 Times
This is all greek to me, need to spend some time in order to comprehend what it all means.
This I shall do, audition a few other subs before finalizing the ID CTX.
Swift DDiS Ldi : long term report - 35k service done shantyrocks Long-Term Ownership Reviews 34 8th August 2013 20:57
Dream SPL Setup : Budget 1.5 lacs for Stage 1. Suggestions? procircuit_234 In-Car Entertainment 27 28th May 2012 21:28
Need an Audio system for Swift - Budget 30-35k zerocritical In-Car Entertainment 13 7th August 2010 22:53
Cops use SPL setup to scare people off :D hydrashok In-Car Entertainment 6 2nd December 2007 10:41
