Old 17th January 2006, 22:40   #16
navin's Avatar
Thanked: 3,885 Times
no major brand in india makes 4" components. you can ofcourse roll your own. :-)
check with your installer, most doors can take a 5" it might involve some metal cutting though.
Old 17th January 2006, 23:06   #17
IndianDawg's Avatar
i asked someone and he told me i can install 4 inch coax so now i was thinking to install 4 inch coax front and rear 6 inch comps i really got no idea now what should i do? please help me out 1 amp is for sure now i just gotta decide about front and rear
IndianDawg is offline   Reply With Quote
Old 17th January 2006, 23:09   #18
Of course he can. Very easy. Navin, inspire him.
Vivekphadnis is offline   Reply With Quote
Old 18th January 2006, 00:10   #19
revtech's Avatar
Thanked: 35 Times
if you put a four inch coaxial in front and a 6+ coaxial in the rear your going to have a complete rear sound stage.thats something you wouldn want if your driving most of the time.im sure you can fit atleast a 5 inch component.
Rev
revtech is offline   Reply With Quote
Old 18th January 2006, 10:08   #20
navin's Avatar
I agree with revtech.
1. try and shoe horn the largest woofer that will fit in the door. 5" or even 6". with a City you dont have tweeter pods (alteast our CVTs dont) so you either live with Coax or with a tweeter flush mounted inthe A pillar or surface mounted on the dash. pick your poison. either way try 5". It should fit.
2. then use the same speaker in the rear you can use coax in the rear to sme bucks.
Trance is very bass intensive. I would look at 2 12" subs if you afford it. It will require 2 amps. or you cna get 1 amp and 1 12" sub for now and add one later.
Old 18th January 2006, 10:18   #21
navin's Avatar
Your wish...
1. buy a 4" coax from say JBL. The JBL 426 is a good example....
2. fashion 2 dust cap/ phase plug out of a plastic cone (I've used many odd things from the covers of some old Leggs Stocking my ex-GF used to have to brass cups to having custom one made out of clay damped with resin). I suggest using a plastic phase plug as it is easiest to install.
3. snip out the tweeter from the 4" coax. save these for later.the cap (usually 1uf or 2uf /50V can be junked)
4. install phase plug / dust cap where tweeter was to cover the hole on the voice coil. A light dust cap piece can be stuck to the cone without a huge change in the cone's abilities a heavier clay/brass style phase plug would require you the pole piece to be mounted from behind the woofer
5. now use a nice poly cap of the same value of the cap you discarded and series that with the tweeter fluch mount the tweeter using blutack on the magnet inside the tweeter pod.
If you car does not have tweeter pods (like the City) then I do not suggest doing all this as making a tweeter grill is hard work and requires someone who can draw a metal mesh into a grill. I have done this but wont try it again.
Now that you have great 4" components it is time to power them with a nice tube amp....Vivek will fill in those details! :-)
Old 18th January 2006, 11:32   #22
IndianDawg's Avatar
Thanks for your help i think i need to talk to my guy who's going to install the system am sure he will say the same lets see how it goes now. I will definately post the final system. Thanks for your help it has really helped me a lot
Old 23rd January 2006, 11:07   #23
IndianDawg's Avatar
This is what the system i have decided with my guyFront Kickers Comp 6.2= 5760, Rear Kickers Comp 6x9= 5760, Woofer Kicker= 6000 | Box Special=1500, Amp Pioneer= 7000 , Monster cables= 2500, Installation= 1200
Old 23rd January 2006, 13:15   #24
IndianDawg's Avatar
I forgot to mention should i buy Pioneer HU 5750=40 or Pioneer HU 7500=55
I guess 5750 has more features than 7500
Old 14th March 2006, 19:03   #25
Thanked: 11 Times
Hows your install sounding ?
Old 14th March 2006, 19:06   #26
v.tec's Avatar
Thanked: 16 Times
did'nt see this thread earlier..but i sure HOPE you have'nt changed the HU!!! it really rocks!
v.tec is offline   Reply With Quote
Old 15th July 2006, 23:35   #27
Tool's Avatar
hey bro osborne.. umm it really would help if you can state how much you are looking to spend on this too... .. once you mention that.. ull see the suggestions flow.. trust me heheheheh...
hope i was able to help you out.. take care
Tool is offline   Reply With Quote
Old 16th July 2006, 00:12   #28
Thanked: 16 Times
Originally Posted by osborne
Hi Guys
My name is Osborne....i have recently purchased a Honda city zx vtec in the month of june 2006
its got a alpine 560e 2 din audio system....need help on the speakers , amp, and woofer ....for some good low bass....and clarity....
can anyone help me ....
cheers!!!!!!!
Man! Welcome on board. Need some more info on your req.
Old 16th July 2006, 22:59   #29
navin's Avatar
My name is Osborne....its got a alpine 560e 2 din audio system....!!!!!
Oz,
The 560 dont have preamps outputs. The cheaper way to do this is to get a speaker level adapter that will adapt your speaker output to be used with an external amp. This will not produce the same quality of sound if you had premap outputs but in your only other alternate would be change the HU (esp if you dont need cassette - the 560 is a 2 DIN Hu with casette and CD).
that said let us know your budget. the gurus here will be most eager to confuse you.
Old 17th July 2006, 00:45   #30
cda-560e has a single subwoofer preamp out. so i guess you can use a mono amp for the subwoofer. if you want to use the same HU and use an amp to power the speakers, then get an amp that takes speaker level input or use a line output convertor.
wiking is offline   Reply With Quote
Honda City : A close look at the factory-fitted Audio, Video & Navigation System rajeshblue In-Car Entertainment 17 2nd June 2016 19:20
Replace Audio System in Honda City VTEC udit78 In-Car Entertainment 4 1st June 2009 20:09
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
Audio install - Honda City VTEC wiking In-Car Entertainment 33 9th November 2006 23:36
