Old 18th March 2011, 15:55   #1
Thanked: 202 Times
Default Suggestions for iPhone based ICE
Hello everybody, once again !
If you read my other post on Tata Indigo modification, the part which I will be left to do after that would be ICE.
I am looking for a simple, straightforward music system, that should just do only this job:
1. I need to be able to connect my iPHone (or iPad) via USB into it.
2. I should be able to select playlists, browse efficiently, for e.g. I want to listen to Metallica song, I should be able to select M directly. - All this from the player and not from the iPhone
3. It should immediately pause audio if I receive or make phone calls, and I should be able to use hands free functionality, efficiently! That means the other party should be on car speakers, and the MIC should be sufficiently sensitive to pick my voice driving at higher speeds with some noise cancellation.
4. I just need a decent amplifier, or can do without one as well, the audio quality is more important to me than the volume/loudness itself.
5. It should have adaptor to control this functionality through steering wheel remote.
6. I do not care if it doesnt have a CD player. I do not care if it doesnt have Radio FM. iPhone is all that I need it to work with. I have tons of info getting changed everyday to keep me happy for days together (read podcasts). Also in the near future with 3G getting cheaper (or my company sponsoring an unlimited plan) I'd rather use online radio - atleast within Bombay and Pune
One final thing- where will I get this in Bombay? How much will it cost approximately? I dont wish to spend too much on it, lets say I am on a budget of under 12K. Possible? If not dont hesitate to suggest
Thank you once again.
Frontosa is offline   Reply With Quote
Old 18th March 2011, 16:58   #2
invincible7's Avatar
Thanked: 154 Times
Default Re: Suggestions for iPhone based ICE
I would have recommended you Alpine CDA 117, it works with Iphone, also with Ipod. Also supports Bluetooth (you would need a get the bluetooth kit seperately though). But it is expensive...
invincible7 is offline   Reply With Quote
Old 18th March 2011, 18:11   #3
Thanked: 202 Times
Thanks invincible7.
I did some research online and found the Parrot Rki8400 as a perfect match. However I'm not sure where I could find in Mumbai. I'm OK with any other substitute like kenwood or Alpine. How much does the CDA117 cost?
Old 18th March 2011, 20:29   #4
Thanked: 154 Times
It should be around 20+ i think....
Kenwood also has some options, you can check their site or search the forum. I am not sure about the model nos.
Old 19th March 2011, 11:44   #5
DerAlte's Avatar
Thanked: 2,879 Times
Try Kenwood 7016BT (with CD, ~12K) - comes with Bluetooth and iPod interface and cable. Should be available at your friendly neighborhood ICE dealer.
Old 23rd March 2011, 15:10   #6
quickdraw's Avatar
Thanked: 1,358 Times
Please take a note that the iPad cannot be charged (or will not charge) with in-car/HU USB ports since it requires a higher voltage.
quickdraw is offline   Reply With Quote
Old 23rd March 2011, 21:48   #7
DerAlte's Avatar
The charging voltage remains the same - 5V. It only requires higher current while charging. Since normal USB ports throttle this current to 500mA, the iPad will not charge. However, if one finds a 5-10W cig-lighter charger, that will charge the iPad. Yes, HU USB port won't support it.
Old 29th October 2011, 19:36   #8
Thanked: 41 Times
Hello, any updates on what you went ahead with?
rtandon is offline   Reply With Quote
MIB based Infotainment System - Future of ICE ajaypjayaraj In-Car Entertainment 0 10th April 2015 08:42
Sensor based traffic signals (based on induction-loops) in India? vharihar Street Experiences 8 13th February 2014 21:46
"Automatic Link" for iPhone: OBD-based Car Monitoring Solution crazydave Technical Stuff 0 13th March 2013 09:22
Iphone - now $100 since Iphone 3G S (speed) launched D-Man Gadgets, Computers & Software 32 14th February 2010 18:11
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
