Old 12th January 2006, 22:58   #1
Shan2nu's Avatar
Thanked: 89 Times
Default Which AMP and Subwoofer for the Innova!!
Our latest adition to the family....our Toyota Innova, has been installed with a Pioneer P6750 Mp3 player, stock Alpine speakers on the front doors and JBL - GTO506CS (165W) speakers on the back ones.
The problem i'm facing, is the rattling sound the door panels make when the "Bass" is increased. The absence of a subwoofer has converted the gap between the door and the door panel into a makeshift sound box, which really gets on my nerves when ever it begins to rattle.
What do you think would be the right AMP and Woofer combo for my setup?
Shan2nu
Old 12th January 2006, 23:03   #2
Thanked: 1,592 Times
I'm no audio expert, but since the interior space in the Innova is similar to that inside the Safari I can vouch for the Blaupunkt ODsb8000A Active sub. Decent, SMOOTH base (not Brigade-Road-Thump-Thump) and quite compact too. Its a bit pricey at Rs.12,900/-, though. The big advantage is that you dont lose space for two components (Sub and Amp) as the amp is built in.
Steeroid is offline   Reply With Quote
Old 12th January 2006, 23:07   #3
mclaren1885's Avatar
Thanked: 34 Times
Infractions: 0/1 (10)
well shan the best way to reduce the rattling will be to use damping pads like wurth , dynamat etc ..
Coming to the amps , i suggest the amps from alpine are the best .. If u can tell us ur budget for both then it would be easy to suggest u a amp and sub..
Old 12th January 2006, 23:10   #4
Thanked: 34 Times
Also i fugured out that u have coaxials running at the front and the JBL compos at the rear .. U might want to reverse that for better soundstage ..
PS: A budget of 20 k for both would be ideal ( well if u didnt know we can get u to spend twice as much too ,what say navin )..
Old 12th January 2006, 23:15   #5
kpzen's Avatar
Thanked: 1,650 Times
I'm no expert here but Shan2nu have look at this it sounds good...
http://www.team-bhp.com/forum/indian...ts-here-2.html
post# 16
Old 13th January 2006, 10:40   #6
navin's Avatar
Thanked: 4,265 Times
Shan,
The Blau sub mentioned by Steeroid is not bad. Another alternate is teh JBL 60.2 with the 1200B. but you first need to damp those doors.
yeah mclaren, swithing the components to the front will improve front soundstage dramatically.
Old 13th January 2006, 10:56   #7
Thanked: 34 Times
the active sub that steeroid has is good actually.. The other day when he was in bangalore i was tweaking it and i found the bass to be quite good for a 8''.. However im not sure if its available here as of now .. If im not wrong that piece was picked up at dubai , isnt it steer uncle ..
Old 13th January 2006, 12:31   #8
No Rahul beta, it was bought from the Blaupunkt shop in Cochin.
By the way, there are TWO 8 inchers inside that box, not one.
Old 13th January 2006, 14:48   #9
navin's Avatar
2 8" in one box! Hey Seetoid got a pic? I think I might have found what I am looking for (dont need an amp though).
Old 13th January 2006, 14:53   #10
mohit's Avatar
Thanked: 122 Times
Here you go!
mohit is offline   Reply With Quote
Old 13th January 2006, 19:05   #11
Thanked: 34 Times
Oh i thought otherwise bcoz we dont get any actives here in bangalore ..
2 8'' ??? wow i never noticed .. i could see the one facing the top of the dicor , wondering where the other one was .. facing the back of the seat ???
Old 14th January 2006, 10:22   #12
navin's Avatar
woofers on 2 sides. so i could configure this to a dipole sub! ha ha ha
Old 14th January 2006, 10:24   #13
rsjaurr's Avatar
Thanked: 27 Times
Seems to be a good buy,2 amplifiers subw in single box for about 12k.
rsjaurr is offline   Reply With Quote
Old 14th January 2006, 10:33   #14
I thought it was 1, too - till the Blau guy told me it has two. He has allegedly set up the one at the bottom (facing the floor) to 'reverse' on the Head Unit. I saw the setting (Sub 2 on the HU, Sub 1 is set to 'normal') but cant figure how this works. I plan to change the mounting to set it up horizontally, that way it would work front and back.
Here are the specs, though I dont see two speakers written there...the rest of it is greek and latin to me.
ODsb 8000A active sub main features:
Active subwoofer with passive radiator technology in extremely compact enclosure
The easiest way to more bass - amplifier and speaker in a box!
Twin 200mm drive units using passive radiator technology
Powerful 140Watt Class 'D' amplifier
Efficiency 4 ohm
Can accept line level (RCA) or speaker level input
Max. acoustic pressure (SPL @ 100Hz) 136dB
Frequency response 60 - 120Hz
Phase regulator (0-180 degree) adjuster
Variable low-pass filter (60-120Hz)
Gain controls (0.2V - 8.0V)
Integral 20A blade fuse protection
ISSAC and power indicator LEDs
Dimensions 292w x 278h x 248d (mm). Weight 7.5kg
Two year manufacturer's warranty
Complete with fixing brackets, speaker level input lead, full fitting and operating guide
Active Subwooferbox for system
Diameter 200 mm + passive radiator
Max. Power 140 Watts
RMS Power 70 Watts
Max. acoustic pressure 136 dB (2,83 V/1 m)
Frequency response 30 - 120 Hz
Impedanz active system
Membrane material SPC
Dimensions (WxHxD in mm) 288 x 274 x 238
??????? Isnt Mico based in Bangalore? They brought it down from the Mico Office when I asked for this model.
Uncle could you say that in English, please?
Old 14th January 2006, 12:52   #15
Thanked: 34 Times
well u can try that out .. face one of the subs to the rear door and the other towards the rear seat ..
The highlighted part says twin drive units which i presume has to be the 2 subs .. Wowie .. Nice find steeroid uncle .. Gotto dig on it the next time ur here ..
Yes mico is based in bangalore but the last time i went to them enquiring them for an active sub they said " we dont have them sir " or maybe they meant no stock and we never bothered to ask ..
haha .. Welcome aboard the UNCLE gang navin .. Trust me there are a lot of uncles here .. Btw steeroid uncle if ur an ICE fan nothing new , wait until navin goes full techy techy .. Sounds as if even french , german , spanish , tamil will be easier all put together .. Ok let me stop before navin gets mad at me ..
Which Subwoofer and Amplifier ramie2400 In-Car Entertainment 88 18th February 2018 11:48
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
Which Subwoofer to go along Kenwood-Infinity Reference setup? jsrakkar In-Car Entertainment 3 18th February 2009 14:31
MODIFIED suggestions for 4 ch. amp & subwoofer ggoyal_83 In-Car Entertainment 114 15th December 2006 20:07
Which subwoofer to go for? DCEite In-Car Entertainment 6 19th June 2005 16:12
