Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Chennai
Old 5th June 2010, 17:38   #121
Thanked: 11 Times
@headers: very obvious! then whats the point of using shell super unleaded when one can use 97?
jagxf is offline   Reply With Quote
Old 5th June 2010, 19:40   #122
Gansan's Avatar
Thanked: 909 Times
The Jag is a high performance car that will benefit from high octane fuel. The ordinary cars don't require it. Shell super is the same octane as the Shell normal petrol, with some additives for engine cleanliness.
Gansan is online now   Reply With Quote
Old 6th June 2010, 15:40   #123
rajeshsundaram's Avatar
Thanked: 461 Times
One of the reasonable HP outlets in ANNA SALAI, which pumps good quality fuel and no cheating is - the one after KUN / DSC (not sure about the name) Hyundai junction. It is a COCO bunk. It is the one that houses the XENOS boutique. Fuel here seems to be unadulterated and billing, QOS seems to be decent.
The BP at the Velachery-Aquatic complex -Raj bhavan road junction (just opposite to old corcorde building, now a big construction is going on) seems to cheat many times.
The HP at 100 feet road velachery is moderately crowded and sells good quality fuel. Service is just average.
I generally find IOC bunks fuel quality are quite okay, and Shell takes the crown overall (quality and yes. including the skyrocketing prices) :-D
rajeshsundaram is offline   Reply With Quote
Old 6th June 2010, 22:04   #124
nitrous's Avatar
Thanked: 285 Times
OT:
With 97 Octane, most cars will give you a slight increase in FE as well as power. Its obvious isnt it?
No ways.
Cars with lower compression than 10.0 will not be able to compress the high octane fuel making the flame speed slower.
And in the absence of a knock sensor, the ECU won't know what fuel its running and will base the timing on sensor input from the IAT in closed loop conditions.
Petrol cars with a turbo or high compression and a knock sensor need Speed 97.
Old 6th June 2010, 22:17   #125
headers's Avatar
Thanked: 464 Times
Originally Posted by nitrous View Post
OT:
No ways.
I beg to differ on that!
If we talk non ECU vehicles. It can run on higher octane fuel. You need to retune the engine for that!!
Old 6th June 2010, 22:36   #126
nitrous's Avatar
Thanked: 285 Times
Increase compression (Can we call this tuning?).
And advance timing at the distributor (Of course, this is tuning).
Old 7th June 2010, 13:58   #127
funnyguru's Avatar
Guys,
I recently moved from Kottivakkam to Virugambakkam, so please let me know reliable petrol pumps nearby my area.
funnyguru is offline   Reply With Quote
Old 8th June 2010, 14:58   #128
ikoneer's Avatar
Thanked: 9 Times
The BP at the Velachery-Aquatic complex -Raj bhavan road junction seems to cheat many times.
+1 to that. I am a regular at the HP station, consistent quantity and quality. I can bet on the mileage when i fill here.
Another HP station that i fill is at TTK Road, before the eldams road signal. No cheating here as well.
To avoid:
The BP near Raj Bhavan tried to cheat me as well with the (cash/card technique and Rs 200 filled techniques twice), stopped going there eversince.
HP pump at medavakkam road towards velachery, they dont' even have the tag and 200 technique here as well.
ikoneer is offline   Reply With Quote
Old 8th June 2010, 16:54   #129
Klever's Avatar
Originally Posted by funnyguru View Post
Guys,
Welcome to Virugambakkam, Funnyguru. Where exactly in Virugambakkam do you stay?
Coming back to your question, there's a shell bunk diagonally opposite to the Vadapalani bus stand. I don't use it. Can't afford the extra 4/5Rs. Instead, I use the BP bunk near the Kodambakkam junction(When going towards Kodambakkam from Vadapalani, it's on the left hand side just before the Kodambakkam signals).
Been a regular to that bunk for the past 7 years. Never been short-changed and the overall experience is good.
Actually, there are quite a number of bunks in Vadapalani/Virugambakkam area but for no apparent reason I don't go there. I always prefer the one mentioned above.
But do avoid the shady looking petrol bunk(HP???) that's opposite to Vijay hospital.This petrol bunk is next to Rahat Plaza. Been short-changed once there.
Klever is offline   Reply With Quote
Old 8th June 2010, 17:23   #130
Thanked: 105 Times
I am trying to find a reliable pump in the shols/tambaram/mcity(Chengalpattu) route if any? Are they any good pumps in the camp road area?
vishnurp99 is offline   Reply With Quote
Old 8th June 2010, 18:03   #131
funnyguru's Avatar
[quote=Klever;1926872]Welcome to Virugambakkam, Funnyguru. Where exactly in Virugambakkam do you stay?
Hey buddy, i stay near Avichi school, near Jain's apartment.
Old 8th June 2010, 18:09   #132
ElantraGT's Avatar
As soon as you cross the Katankulathar and just before Marimalai nagar (Tambaram -Chengalpatu route), on the left side you see a BPCL bunk. This is a COCO bunk. You can see a lot of truckers lining up to fill their tanks. This bunk used to be good in terms of Quality and Quantity. Its been a while since I used this bunk, can some one shed some light on this?
ElantraGT is offline   Reply With Quote
Old 9th June 2010, 09:06   #133
scopriobharath's Avatar
Thanked: 1,255 Times
Default Balakrishna Automobiles - RA Puram, Chennai
Pump on St Mary's Road RA Puram. Balakrishna Automobiles. Very good, No Cheating, shows zero before fill. We can see lots of vehicles lined up. He is the official filler for Park Sheraton Cabs. I fill up there only as far as i can. no problems faced so far.
Amenties: Ordinary Water wash, Standard Chartered ATM, In&Out Store, Cards accepted at pump, Emission Test Facility
scopriobharath is offline   Reply With Quote
Old 10th June 2010, 09:01   #134
Thanked: 461 Times
Wink
Originally Posted by alexkrish View Post
Check the one near the Kamatchi Hospital Flyover, Pallikaranai. I had written a blog post on this long back. Check this post.
Alex!! Welcome to TBHP! Good to see you here!
Old 10th June 2010, 16:38   #135
arvind71181's Avatar
Thanked: 951 Times
Filled up full tank in the IO bunk on ECR today. This is in Kottivakkam. After the auto cut off I gave the guy the card, asked him to get the bill and then moved to fill up air for the tyres.
After filling up air, I am waiting and the guy comes and gives me a charge slip for 1745. I sign it on an impulse and then remember filling for only 1600 odd. Just to check, I have a look at the bill and sure enough, it said 1645.XX.
I ask the guy the same and he promptly goes and comes back with a 100 rupee note and an apology. Just posted it here as I did not know whether this was done by oversight or not (His promptness in immediately giving me 100 is what surprised me)
PS: I always fill up in this bunk and have found it to be the better of all the three bunks in the area.
arvind71181 is offline   Reply With Quote
The Petrol Pump Story - How Petrol Pumps Operate aplang1 The Indian Car Scene 158 25th July 2017 14:42
Fuel Stations / Petrol - Diesel Pumps on the road dmplog Route / Travel Queries 8 23rd November 2016 11:57
Trusted Fuel Stations / Petrol Pumps : Trivandrum basilmabraham Other Cities 20 17th November 2014 15:47
Trusted Fuel Stations / Petrol Pumps : Mysore MCR Other Cities 0 9th July 2010 21:10
