Go Back   Team-BHP > Team-BHP > A Collection of the best threads
A Collection of the best threads The very best of Team-BHP. Its in here!!
Thread Tools
Old 17th April 2006, 11:08   #16 (permalink)
speedsatya's Avatar
along with tires ,tire pressure is also improtant ....we have have sticky v-rated rubber ,but the wrong tire pressure can change things drastically ..
also the road condtion is also important
speedsatya is offline   Reply With Quote
Old 17th April 2006, 12:15   #17 (permalink)
quicksilvr's Avatar
Originally Posted by ghostrider4385
Hey Rehaan. What do you mean by that?
And another thing, they say that a strut brace makes the car more rigid and less prone to flex during turns to make cornering (especially high-speed cornering) tighter. How EXACTLY does this flexing effect the car's handling on turns?
Godspeed,
Alok.
When there's excessive chassis flex, you're uncertain of the car's handling. You wouldn't know when it's gonna snap from understeer to oversteer or vice versa.
quicksilvr is offline   Reply With Quote
Old 17th April 2006, 20:45   #18 (permalink)
hot_rod's Avatar
hey guys what about the traction control?
__________________
4get metrosexuals be a petrosexual.............:D
TEAM-BHP.com pada pa pa IM REVVING IT!!!
hot_rod is offline   Reply With Quote
Old 17th April 2006, 22:32   #19 (permalink)
2fast4u's Avatar
here guys is a view of my strut braces front
http://www.team-bhp.com/forum/vbpicg...p?do=big&p=664
what it does as far as my driving is concerned is that the front end does not dip down when sharp cornering and normally where the suspension would be going down faster in this case the struts come in action. and in RWD into sharp cornering there is more kind of unpredictable drift which can be dangerous if u have to maintain lane discipline, with struts "on" the drift part is very controlled and u could make it drift to ur potential and be in control knowing what and when r u doing it.
rwd and struts should go in conjunction i feel.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 18th April 2006, 20:08   #20 (permalink)
veyron1's Avatar
Originally Posted by GTO
Heres a list, that I think, includes all the factors that contribute to make a tight-handling car. Any additional?
1. LightWeight
2. Lower Center of gravity
3. 50:50 weight distribution
4. Taut and Rigid Chassis
5. Aerodynamics
6. Tyres
7. Brakes
8. Tight Suspension (Multi-Link, Active, Double wishbone...)
9. Traction Control + Electronics
10.ABS
11.Gearing
12.Rear-Wheel/AWD
13.Quick + Responsive Power Steering
14.Minimum Body cuts (coupes)
15.No Convertibles
16.Alloy Wheels / Unsprung weight
17.External conditions
18.Differentials (Limited Slip...)
19.Dimensions (Track, wheel base...)
20. Most Imp - The Driver!!!
nice list...
a few things that came to my mind at first thought;
1) steering ratio (no. of turns lock to lock/ steering g'box ratio)- this would come under point number 13. ah, and yes-all wheel steering.
2) perhaps i'm a little off, but i thought that the optimal weight distribution should be 40:60, i.e, rear biased to overcome understeer; point number 3.
there are so many other points, but all of them come under the above said categories, only in more detail....
__________________
DAD
veyron1 is offline   Reply With Quote
Thread Tools
do alloys effect handling?? noidaboy Tyre & Alloy wheel Section 20 15th March 2007 15:30
Esteem handling issues. Stig Technical Stuff 8 26th January 2007 09:23
Change in mileage and Handling msk_kapoor Technical Stuff 6 23rd April 2006 22:34
Factors affecting Thermal eff vs FE and diesel vs petrol etc jat Technical Stuff 3 21st February 2006 22:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
