Go Back   Team-BHP > Team-BHP > A Collection of the best threads
A Collection of the best threads The Best of Team-BHP. It's in here!
Thread Tools
Old 20th September 2005, 20:43   #31 (permalink)
sorry guys i have no idea regarding this, pls getr bac with info
raja_ys is offline   Reply With Quote
Old 22nd September 2005, 15:40   #32 (permalink)
Gurkha's Avatar
Originally Posted by hrag
I'd have thought it was the other way around, like on the Premier Padmini - synchro on all gears except 1st.
Yep, got it wrong, my Jonga is the same, Ist is no syncro, 2nd and 3rd are syncro.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Gurkha is offline   Reply With Quote
Old 22nd September 2005, 17:36   #33 (permalink)
MalluDude's Avatar
I believe double clutch is still there in old Ashok Leyland vehicles, i.e. the ones that came out before the power steering/ sync gear version which was introduced 5 years back. When the driver up-shifts, you can see him closing the accelerator, bringing gear to neutral, releasing clutch, and again depressing clutch to shift to the higher gear. Some guys even race the engine while the position is in 'neutral' claiming to avoid gear-grinding.
BTW I didn't know Jonga had this...Gurkha, you do mean the ones that came from Jabalpur, right?
MalluDude is offline   Reply With Quote
Old 22nd September 2005, 18:08   #34 (permalink)
Gurkha's Avatar
One of the reasons that is done in buses and trucks is because their syncros are shot so they have no choice or they are trying to preserve the syncro rings, otherwise the Leyland with the HINO/ZF power-train is smoother than most cars.
__________________
1999 Trax Gurkha
1996 VFJ Jonga
1995 Accord V6
1995 Honda RC 45
Old 9th January 2007, 06:00   #35 (permalink)
mithun's Avatar
I've heard that double-clutching is a better option even in cars which is having a synchromesh transmission because the actual gears are always in constant mesh, and the synchronizers only decide which pair of gears to connect to their shaft. Is that true ?
Also double-clutching is the right way to operate the clutch. Because it saves wear and tear on the synchronizers in the long run or if you're planning to run your car for over 3 lakhs KMS.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 9th January 2007, 11:41   #36 (permalink)
ex670c's Avatar
Default Advantages of Double De-Clutching (DDC)
When we engage the Clutch it slows down the Flywheel, thereby the engine.
Imagine DDC to be like cadence braking, It can rapidly slow down the engine while without heating up the clutch.
In High Performance engines (Hi-Speed & Hi-Torque) DDC Prevents the Clutch plate from heating up or coming under torsional stress.
It aligns the synchroniser rings/cones better.
There by preventing a lot of wear and tear and harshness.
In Off-Road and Towing situations it prevents the clutch from burning out.
Arka.
__________________
JEEPers speak - Engage Mind, before opening Mouth!!!!!
Old 11th January 2007, 05:25   #37 (permalink)
mithun's Avatar
Is it a wise idea to use double clutching on our new-age synchromesh transmissions ?
Will double clutching cause damage to the new-age synchromesh transmissions ?
__________________
Old 11th January 2007, 06:38   #38 (permalink)
chetanhanda's Avatar
Originally Posted by Shan2nu View Post
Ajmats. that's not double cluthing but it's similar to toe-heeling which is done to match the revs of the engine to the lower gear to make for a smoother deceleration.
While the heel blips the throttle, the toe is used to brake.
Watch any of the best motoring videos and you'll get a clear pic of it.
Regards...
Shan2nu
"heel-n-toe" or "toe-heeling" is not done to match the revs of the engine to the lower gear.
its done in order to keep the spooling turbo from dropping revs to lower speeds..to reduce turbo lag to a certain extent, another option to heel-n-toe is using a ALS to keep the turbo revving at the same speed even when the foot is lifted off the throttle.
When the foot is lifted of the throttle during braking the pressure/velocity of exhaust gasses drops, which causes the turbo to lose some rpm. so when the throttle is floored again (after gear shift or braking)there will be some lag for the turbo to reach the same speed.
So to prevent this the driver presses the brake with his heel to slow down and the throttle with his toe to keep the engine revving andd turbo spooling.
This creates heavy load on the brakes, engine etc but when u cant afford to lose speed at apex etc and suffer turbo lag .. u have to do this.
As mentioned earlier the other option is ALS .. but ALS comes with its
drawbacks.. loud sound and killer load on the exhust system as well as the blades of the turbo..
but nothing beats the sound of ALS on the overrun..
chetanhanda is offline   Reply With Quote
Old 11th January 2007, 17:22   #39 (permalink)
Rehaan's Avatar
Wise.....im not sure. More like rather pointless.
Nope.
cya
R
Old 11th January 2007, 19:41   #40 (permalink)
rks
rks's Avatar
If it is not required, then it is not wise to do it. Unnecessary wear and tear on your clutch, unnecessary revving on your engine, loss in fuel economy. Also I am wondering if the ECU, say of an MPFI engine, will get (at least momentarily) confused by the double declutching procedure, resulting in lower-than-optimal performance/FE?
Old 16th January 2007, 14:27   #41 (permalink)
I think Constant-mesh Gearbox's are the ones who may require double clutch sift for smoother shift's.
These are the one's used in the bus's and car's of yore.they required a lot of smoothness and technique,once mastered,i have seen many KSRTC and BMTC Driver's shift without clutch!!!!
Minus points are far too many of course rendering it obsolete and un-reliable.
In syncromesh i resort to double clutch changes to car' who have a wide-gate between 2nd and 3rd gear and when iam changing at full-rev's.
Desert fox is offline   Reply With Quote
Old 18th January 2007, 10:45   #42 (permalink)
yaeh... i've seen that process in many KSRTC busses but didnt quite understood that until now. thanks for that piece of enlightenment provided for us... reehan.
__________________
HORN...OK...PLEASE.....
vichu_zen is offline   Reply With Quote
Old 10th February 2007, 00:22   #43 (permalink)
rranjith_kum's Avatar
Hey Shan2nu,
the noise you hear is because reverese gear is a "straight-cut" gear and not a "helical cut" gear.
the straight cut gears are actually called as spur gear...
rranjith_kum is offline   Reply With Quote
Old 3rd April 2007, 16:54   #44 (permalink)
rider60's Avatar
awesome explanation dude i never knew about anything like this........
rider60 is offline   Reply With Quote
Old 8th April 2007, 00:08   #45 (permalink)
All BEST buses before 2002/3 have non syncro gearboxes & hence require double clutch. But many drivers do not use clutch at all in these buses.
Sometime in 2002/3, buses with ZF gearboxes started arriving into their fleet. These buses had a special notice for the driver saying "ZF G.box. Single clutch" The board also indicated the shift pattern!!. But these notices have vanished in some buses due to repainting.
About automatic buses, I know one AC bus of BEST which has rear engine & automatic transmission. The recently acquired Starbuses have manual transmission.
AkMar is offline   Reply With Quote
Thread Tools
MULTIJET & MPFI - Whats the difference ? nandans2005 Technical Stuff 20 22nd October 2009 09:48
Double Clutching... how many of us do this? any disadvantages? DaPilot Technical Stuff 2 13th May 2006 01:39
Whats the fastest i.e whats the highest average speeds that you have maintained naveendhyani Street Experiences 1 3rd April 2006 19:09
Whats the fastest i.e whats the highest average speeds that you have maintained MKRAFT Street Experiences 1 3rd April 2006 18:25
Mags & Alloys - Whats the difference? hot_rod Tyre & Alloy wheel Section 25 8th April 2005 19:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
