| A Collection of the best threads The very best of Team-BHP. Its in here!! |
| | Thread Tools |
| | #46 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #47 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| can we get some brew this weekend for the drag ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #49 (permalink) |
| Newbie Join Date: Aug 2004 Location: Bangalore
| Octane rating of the fuel to be used in the vehicle is directly propotional to the Compression ratio. Some facts: 1. Fuel octane requirements for gasoline engines vary with the compression ratio of the engine 2. The higher an engine's compression ratio, the greater the amount of heat generated in the cylinder during the compression stroke. 3. The higher the octane rating on fuel the less volatile (evaporative qualities) and the slower the fuel burns. 4. Higher octane fuel contains more POTENTIAL energy but requires the higher heat generated by higher compression ratio engines to properly condition the fuel to RELEASE that higher potential energy. High octane fuel does reduce knocking due to the delayed ingition. But engines with low compression ratio are not able to utilize the potential of the high octane fuel and actually the performance may reduce using high octance fuel. Suggested Compression Ratios for Street Driven Engines (Source: http://www.ford-trucks.com/article/i...ion_Ratio.html) With cast iron heads, 9.0-9.3:1 is considered the maximum C/R for regular (87 octane) pump gasoline. 10.5:1 is about maximum for today’s premium (91-94 octane) pump gasoline with a cast iron head. And that’s assuming you keep the rpms up without lugging the engine, you’ve cleaned up the combustion chambers of sharp edges and rough spots to reduce the possibility of pre-ignition and use a zero deck clearance, or close to it, to enhance quench. Aluminum heads will generally allow 11.5:1 C/R on premium pump gasoline, again assuming you have clean combustion chambers and a zero deck clearance. If you run A/C, take .5 off the maximums.
__________________ Gurdeep |
| | #50 (permalink) | |
| BANNED | Quote:
now with 87 octane being replaced by 91,will it help if the octane type is changed. can u list the cars in which this can be done. wat abt the mpfi zen. | |
| | #53 (permalink) |
| BHPian Join Date: Mar 2004 Location: bangalore
| you need to check the comp ratio of your engine, any thing above 9 will work well with 91 octane gas...generally the car manual will tell you what octane rating works the best. but the fuel we get here is not the best...so 87 octane might not actually be 87....thats the only danger.
__________________ AAKGC- Activist Against Killing a Good Car |
| | #54 (permalink) |
| Senior - BHPian | well guys i used dom's mixture in my car and the response is almost immediate and the car burns better and is much more crisper...got an excellent mileage of 19.7 on the highway in my baleno...dom was sittin with me to prove it!!!
__________________ ...91 is back !!!! |
| | #57 (permalink) |
| Senior - BHPian | hey dom will it be possible for you to send us some of it or like will we have to make it ourselves anyone here sell toulene or get it ??? was thinking of using it on my palio or ikon how much does it cost per litre ??? will there be anychange in performance of the carb if 91 octane is used . i mean FE and performance wise thanx
__________________ ˘нєєяѕ ℓαмвσ lamborghinirules@gmail.com |
| | #60 (permalink) |
| Senior - BHPian | thanx for the offer dom satya happy bday will check it out after my exams
| Thread Tools | |
Similar Threads | ||||
| How does high octane fuel improve performance? | DCEite | Technical Stuff | 90 | 19th June 2008 11:53 |
| Are High Octanes really high OCTANE | pratheesh | Technical Stuff | 9 | 20th September 2006 22:48 |
| premium diesels do they work like high octane petrol | garvit2002 | Technical Stuff | 2 | 20th February 2006 09:54 |
| High Octane and Maruti | pratheesh | Technical Stuff | 24 | 10th February 2006 21:30 |
| High Octane for NHC? | srasania | Technical Stuff | 6 | 28th May 2005 20:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
