Go Back   Team-BHP > Team-BHP > A Collection of the best threads
A Collection of the best threads The Best of Team-BHP. It's in here!
Thread Tools
Old 3rd March 2004, 11:49   #1 (permalink)
adityapd's Avatar
Thumbs up What's a free flow exhaust ?
Hi there
Since i had a tecnhinal query, thought let me the first one to broach this topic in this (yet)virgin area of this message board
Have been hearing this term quite often offlate. Does anyone have any idea what exactly is it all about and what benefits can one expect after fitting it to the car ? Also can it be fitted on both carb as well as MPFI cars ?
cheers
aditya
__________________
any rpm, any gear, just push the pedal to the metal and the baleno will deliver T-O-R-Q-U-E to you !!!
adityapd is offline   Reply With Quote
Old 3rd March 2004, 13:23   #2 (permalink)
Rehaan's Avatar
Hey guys,
Im gonna try and explain this keeping it simple.....correct me if there are any discrepancies
The exhaust system of a car takes the exhaust from the cylinders to the end of the tailpipe where it is expelled.
Starting off at the exhaust manifold which combines the individual exhaust gasses from the cylinders,
That pipe leads to the catalytic converter, which causes chemical reactions with the exhaust gasses to make them more enviormentally friendly
read this for further cat-con info > All Catalytic Converters - What Does A Catalytic Converter Do?
The output gas goes down a pipe to the muffler(silencer) which is required for cars to meet the noise pollution standards
Well that is a basic stock exhaust sytem.
Now what you have to understand is that even though we are dealing with gasses, there is still a good deal of pressure involved. Specifically backpressure. That is, the exhaust gas newly expunged from the cylinder has to push all the other exhaust through the manifold>pipe>cat>pipe>silencer. This is where the back pressure comes in, it provides a certain resistance.
A free flow exhaust, simply put, is an exhaust that decreases the amount of back pressure in the exhaust system and possibly also providing a smoother passage for the exhaust.
In my opinion, a free flow can have any/all of the following. A new exhaust manifold, providing smooth and equal length sections of pipe for gas from each cylinder (like the one in the first pic).
(Porting and polishing the head also helps the flow of the intake/exhaust gasses and is a mod, though not part of a free flow)
Pipes can be widened allowing more gas to flow. But keep in mind that theres always a right balance and backpressure seems to have its advantages.
The cat can be modified or removed all together. For example a certain evo6 in bombay was running without the cat at the autocar speedrun.
And the muffler aka silencer. This is where the most confusion can happen. Sometimes all you have to do is poke a hole in your silencer to make your car sound like its free-flowed. Its quite possible that 70% of the "freeflow" cars you see on our streets are actually just modded mufflers, giving the noise an the "feel" but no real benefit.
Importantly, keep in mind that huge amounts of research go into making a good exhaust system, its not just as simple as putting larger pipes and taking off the cat. Sometimes it can have a negative effect on the performance of the car.
As u must have figured, this can be done on carbed as well as mpfi cars.
After free-flowing your car, the gasses flow diffferently and hence your carb should be re-calibrated. And i can only assume that the correctway to do it with an mpfi is to re-program the chip ......(im not sure if there are enough sensors to calculate and adapt to the difference).
A good example of this is when your muffler cracks/rotts/falls off you will notice that your car starts to idle a lot faster (due to less back pressure)...
Hope i have managed to successfully convey this concept.
Let us know if you want to get further into this!
cheers
rehaan.
__________________
The memory of you will ride by our side forever.
Last edited by Rehaan : 31st October 2007 at 01:11. Reason: fixed a few image links...
Old 3rd March 2004, 13:29   #3 (permalink)
Aditya,
Any internal combustion engine has a typical breathing sequence. Cylinders have intake and exhaust valves for precisely this purpose. While the intake valves will "breathe" in oxygen and mix it with fuel, combustion related waste gases are let out through the exhaust valves. Thus in a four stroke engine (typically the norm today), the engine creates most of its power during the "power stroke" and in the exhaust stroke, the exhaust valves open up for the piston to push the exhaust gases out of the cylinder.
While filters like the K&N typically help the engine "inhale" more efficiently, free flowing exhausts help an engine "exhale" better. Free flowing exhausts of good quality (both in parts and installation) help an engine breathe better by reducing the back pressure.
Simply put, interpret it as "free flowing" and you will get what the purpose is.
Hope that helps,
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 3rd March 2004, 13:39   #4 (permalink)
Shan2nu's Avatar
So does that mean the faster the exhaust gasses are released out of the car, the better it performs?
I even hear than doing this not only improves performance but, also the fuel efficiency of the car.
Regards...
Shan2nu
Shan2nu is online now   Reply With Quote
Old 3rd March 2004, 13:50   #5 (permalink)
Dippy's Avatar
Yeah Shantanu free flows do enhance the performance of the car but Im not so sure bout the fuel efficiency
__________________
The Automobile - It's just that special. Nothing else even comes close
Dippy is offline   Reply With Quote
Old 3rd March 2004, 14:12   #6 (permalink)
Originally Posted by [b
Quote[/b] (Shan2nu @ Mar. 03 2004,12:09)]So does that mean the faster the exhaust gasses are released out of the car, the better it performs?
Regards...
Shan2nu
Not necessarily Shantanu. It all depends on what performance means to you i.e. It is highly subjective.
I know of some guys who installed headers et all, but came away disappointed because the pipes they used were really wide. Even though performance significantly improved in the high end, their cars totally lost low end grunt. A big problem in city driving and practicality.
__________________
Old 3rd March 2004, 14:25   #7 (permalink)
adityapd's Avatar
Thanks guys..especially rehaan for making it so illustrative et al ..couldn't have been more simpler
cheers
aditya
__________________
Old 3rd March 2004, 16:09   #8 (permalink)
Shan2nu's Avatar
Yeah Rehaan,
Your presentation was A1.
Rehaans "N-PSY-CLO-PEDIA"
BTW did yo'll read Dippy's new book titled "How To Hate A Hyundai" lol
No offence Dip but, i love doing that to you
Kya karen, control hi nahin hota
Regards...
Shan2nu
Old 3rd March 2004, 16:14   #9 (permalink)
Dippy's Avatar
Hey Shantanu
Great idea My book will be called " 101 and more ways to hate a Hyundai"
__________________
Old 19th March 2004, 08:38   #10 (permalink)
Dippy when you are going to release the book ?
toyota is offline   Reply With Quote
Old 19th March 2004, 09:13   #11 (permalink)
Rehaan's Avatar
Hahahaha....Dippy, this is like the 3rd time toyota has asked!! looks like it might just be a bestseller!
cheers
__________________
Old 14th July 2004, 16:17   #12 (permalink)
speedsatya's Avatar
This is from an article in Overdrive November 2001.,which cud help u knowing more about a free flow exhaust.
One of the easiet ways of increasing the performance of a car engine is playing around with the exhaust gases.
Getting down to the basics ,tuning an exhaust is not a piece of cake,but that also does not mean u need a rocket scientist to do it .lets start from the beginning---
What is an exhaust system ?exhaust systems carry out several functions.among them are .getting hot noxious exhaust gases from the engine to a place away from the passenger compartment ,significantly reducing noise output from the engineand in the case of modern cars ,to reduce the exhaust emissions or to reduce our PUC readings.
After ur air -fuel mixture (or nitrous –fuel mixture)burne,u will have a bunch of leftovers consisting of a few inburned hydrocarbons(fuel),carbon monoxide,carbon dioxide,NOX ,SO2,phosphorous and the occasional molecule of a heavy metal.these are all in gaseous form and r under a lot pf pressure as the piston pushes them out of the cylinder and into the exhaust manifold is usually made of cast iron and its primary use is to funnel several exahsut ports into one,so u don’t need 4 exhaust pipes sticking out of ur 4 cylinder car.
But exhaust manifolds are pretty restrictive to the flow of exhaust gases and so a lot of power is wasted as ur pistons have to push these exhaust gases pretty hard to throw them out.In a four cylinder car ,there are 4 cylinders sharing the same exhaust manifold.the manifold can also be an important source of back pressure because exhaust gases from one cylinder builds up pressure in the manifold that affects the next cylinder that uses the manifold.
This back pressure develops a resistance that the piston faces to force the exhaust gasses out and in a way a good way for an engine to loose power.
Then why do almost all new automobiles sold have exhaust manifolds.that is because they are cheap to produce and easy to install.
The performance alternative to the exhaust manifold is using HEADERS.instead of a common manifold for all the cylinders,each cylinder gets its own exhaust pipe.these pipes come together in a collector,which is made up of two individual tracts .the individual pipes are cut and bent so that each one is the same length as the other.this guarantees that each cylinder’s exhaust gas arrive at the collector spaced out equally so that there is no back pressure generated by the cylinders sharing the collector .
To gain a more complete understanding of how headers do their job ,v have to understand what an’ exhaust pulse’ is.
Exhaust gas does not come out of the engine in a continous stream.since exhaust valves open and close .exhaust gases will flow the stop and the flow as the valce opens.for a ‘pulse ‘to move,the leading edge must be of a higher pressure than the surrounding atmosphere.
The ‘body’ of a pulse is very close to ambient pressure and the tail end of the pulse is lower than ambient.so in fact there is a complete vacuum.the pressure differential is wat keeps a pulse moving.
A header does a good job of additionally ‘sucking’ more exhaust from the engine combustion chamber ,so on the next intake there is more fresh air to burn.
Headers with smaller ,longer primaries will give a better economy and better drivability. whereas one with smaller length primaries and karger primaries will high revving
From the headers ,the exhaust gases flow to the cat con .there is some debate on whether removing the cat con will liberate some horse power.the cat con cleans up some of the harmful chemicals from the exhaust .also they do a neat job in modern cars in quitening up things.
From the cat con these gasses flow into the muffler .exhaust gases leave the engine under extremely high pressure .if these were let out directly into the atmosphere they make sounds like gunshots,that wud make u and others deaf within a minute.
A muffler that makes ‘horsepower’ is absolute crap.or some dodo mechanics defunct mind.in reality the best mufflers are no mufflers at all!!
Inside a muffler u will find a deceptively simple set of tubes with holes in them.these tubes and chambers are fine tuned as a musical instrument.they aree designed to reflect the sound waves produced by the engine in such a way that they partially cancel each other.
So I think this is enough to make u understand wat exactly a free flow system consists of.
Ever since I got a free flow for my car ,I have stopped using my AC when I am driving alone.it has turned me into a real maniac without caring for economy as I have to indulge in pulling through each gear.
The roar at 100-120 kph is superb .inside tunnels u feel as if u r in a F1 car.
So if u r going for a free flow make sure that u go to someone who knows his job .
Also simply changing the muffler will not give any performance benefits.
speedsatya is offline   Reply With Quote
Old 14th July 2004, 17:01   #13 (permalink)
anoops's Avatar
cooooooooo...cant wait to get mine!! just ordered it yesterday. sat with the guy whos making it (RAC bangalore) for me and went through the software they use for measurements etc..
hoping to have it by next the next weekend. test drove a 1.2 palio (mine is a 1.2 as well) in which they had already installed one. sounds lovely and the car responds a lot quicker.
anoop
__________________
Italian to Korean!! Going senile you think?? :-)
anoops is offline   Reply With Quote
Old 14th July 2004, 17:47   #14 (permalink)
Rudra Sen's Avatar
Quote[/b] (anoops @ July 14 2004,14:31)]
Hey Anoop.
Can I get their address or telephone number?
How much they're charging you?
Rudra.
Old 14th July 2004, 19:30   #15 (permalink)
hi
has any one seen a diesel car with a free flow ?? ...i have never...maybe the sound coming out frm a diesel car with a freeflow would be devastating...
cherio
heavy_foot is online now   Reply With Quote
Thread Tools
Zen free flow exhaust desi_wananchi Modifications & Accessories 7 21st June 2009 00:23
free flow exhaust jobug Modifications & Accessories 3 28th September 2007 16:48
Help me for Free Flow Exhaust System malvechaitanya Modifications & Accessories 10 24th February 2007 16:58
Free flow exhaust!!! shalini_g Modifications & Accessories 1 27th June 2006 12:23
free flow exhaust sanket12 Modifications & Accessories 4 29th June 2004 21:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
