| A Collection of the best threads The very best of Team-BHP. Its in here!! |
| | Thread Tools |
| | #18 (permalink) | |
| Senior - BHPian | Quote:
nothing's better than a viper
__________________ I've lost my phone. Please PM me your phone number if I'm on your contact list. | |
| | #19 (permalink) |
| BHPian Join Date: Feb 2005 Location: Thane
| As many members have stated, turbochargers need a specific amount of exhaust pressure building up in the headers before the turbine actually spin fast enough. When the turbine spins fast enough the compresor wheel (impeller) spins at the same rpm and pressurizes the intake manifold. It means that until you've reached a specific rpm and the throttle is opened enough, the engine would actually lose power over a naturally aspirated engine, because the engine has to oppose the turbine's inertia by forcefully pushing out the exhaust gases. Ones that specific rpm is reached the turbine and compressor spin at extremely high rpms(read somewhere 100000 rpm +) cramming more AF mixture into the cylinders. All turbochargers have a centrifugal compressor, and this is the characteristic of a centrifugal compressor. A centrifugal compressor needs to spin at very high rpms to increase pressure. Superchargers used are generally are positive displacement compressors driven by the crankshaft torque. Some +ve displacement compressors are roots, lysholm screw, sliding vane. These compressors displace a fixed volume of air per revolution(unlike a centrifugal compressor), so in effect they work practically off idling rpm, so they cramm in more AF mixture right from idling rpm, but again they rob precious crankshaft torque( supercharger units have rotors which are much heavier than the ultra lightweight turbocharger turbines and impellers) , but more than make up for it by making the engine burn more charge and making more power. I believe vortech makes centrifugal superchargers, again these would face the same problem as turbos but atleast they wont tax the engine at higher rpms.
__________________ Signatures dont make you smarter. Last edited by topend_hooligan : 15th March 2005 at 20:30. |
| | #20 (permalink) |
| I saw a few dyno vids of turbocharged Hayabusas from www.suzukihayabusa.org. The bikes in the vids are making as much as 600 rwhp. But you can hear the revs to be suddenly and abruptly rising to the peak after a certain point. Also centrifugal compressors displace HUGE amounts of air per specific time period, hence they are the preffered choice for engines made to make power in the higher region of the rpm range of the engine.
__________________ Signatures dont make you smarter. |
| | #22 (permalink) |
| BHPian | The best is having both of them Lancia Delta the famous rally car used both Supercharger for low and mid range power and turbo for the high end the new volkswagen golf 1.4 tdi has both and manages 190bhp out of a small oil burner and has exceptionally good mileage |
| | #23 (permalink) |
| Newbie Join Date: Feb 2007 Location: BRISBANE
| Turbochargers IMO is any day better than a super charger until in certain specific set ups! obviously turbocharger have a huge top end hence one has to be a hell of a driver to keep the REVS high up there while smashing through gears. also fuel efficiency wise turbocharger does not come on boost till high revs so less fuel consumption as on the other side superchargers are belt driven so always on boost and hence chews a hell of a lot of fuel.. but again at the end of the day each to their own!! cheers |
| | #27 (permalink) |
| BHPian Join Date: Jul 2006 Location: Jakarta(originally bombay)
| Guys can someon please explain how the VW Golf uses both supercharger and turbo simultaneously? doesnt it mean that at high revs there will be boost from supercharger as well as turbo at same time? how is that taken care of? thanks.. |
| | #29 (permalink) |
| Senior - BHPian | It should be easy enough to have a valve diverting excess boost, or maybe they use the same boost. Another method is to have the supercharger run off an electromagnetic clutch, like the AC compressor.
| Thread Tools | |
Similar Threads | ||||
| Used wagon R ...How effective is this? | shapath | Hatchbacks | 14 | 25th August 2007 15:54 |
| will installing a turbo charger Compensate power loss from CNG | Fl|rty | Modifications & Accessories | 19 | 10th September 2006 03:15 |
| Turbo charger/Alloys/Tye Upgade for Petra 1.9D | shivag | Modifications & Accessories | 6 | 26th August 2006 00:12 |
| Inputs needed on Indica's Turbo charger : | just-a-starter | Hatchbacks | 5 | 8th March 2006 22:10 |
| Retrofitting Turbo Charger in Indica V2 | Rahulk76 | Modifications & Accessories | 3 | 5th December 2005 11:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
