Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 14th June 2013, 17:54   #31
Ashley2's Avatar
Thanked: 1,444 Times
Default Re: Tata's 37-ton Truck with Lift-Axle mechanism
Originally Posted by nithesh View Post
Tata had launched the lpt 3723 some time back and is available with the dealers. It comes at a price of 25.5 Lakhs (cowl chassis).
Thanks for the details.
But Tata has not launched it pan India. Even places where it was launched, it was taken back citing fuel performance. They are reportedly working on a 10X2 variant with 180hp engine. I am not sure of the areas where they are currently operating.
Originally Posted by Transsenger View Post
.... But AL seems to have developed it inhouse, for their 3718. Hope Ashley can put some light on this!
Also @Ashley, do you mean to say AL has new version of 3118 or 3116 with lift axle for specific applications?
AL has inhouse design but these are developed with JPSL.
Yes, a new 3118il lift axle is available along with existing 3118il twin steer.
Ashley2 is offline   Reply With Quote
Old 14th June 2013, 18:08   #32
Thanked: 532 Times
Cant say about that, but I see a few AP and OR registered ones being used as cement transporters. A few of them even had the new Tata big cab that was showcased at the Auto Expo. But Tata are known to use a few operators from Jamshedpur and Odisha for doing end-user trial run before launching a product pan-India.
But, also Tata generally dont hold a big launch event and put out press releases regarding product launches unless it is for a pan-India launch.
For example, the 4023S PrimaLX which was said to be launched along with the 3723 was actually available in certain areas long before that announcement.
But the test mule at the start of this thread may well be a 10x2 Tata 3718 under test. But even if such a machine is launched, I think Tata will keep the 3723 on sale. The extra power will be liked by operators who carry extremely bulky stuff like ore, cement etc. The extra power will make for faster turn around times on shorter routes allowing for more trips to be undertaken. Remember, some of these 37tonners will get over-loaded to around 40-42tonnes GVW and the extra power and torque will help in these cases.
julupani is offline   Reply With Quote
Old 22nd July 2013, 21:02   #33
TheARUN's Avatar
Thanked: 498 Times
Got this picture from a friend who works for Tata Motors. Awesome stuff
TheARUN is offline   Reply With Quote
Old 28th March 2015, 11:16   #34
tharian's Avatar
Thanked: 3,168 Times
Spotted a TATA 3723 on the road. Normally I have seen the AL 5axle and not a TATA that has a cabin that is not factory built.
tharian is offline   (2) Thanks Reply With Quote
Old 30th March 2015, 15:18   #35
peterjim13's Avatar
Thanked: 327 Times
This one is pretty long.
How does the lift axle work, will it help in taking sharper curves. Like the one set of tyres right behind the front tyres, which can also turn if needed.
peterjim13 is offline   Reply With Quote
Old 30th March 2015, 20:17   #36
tharian's Avatar
The first page of this thread has some information on lift axle mechanism.
I do not think the lift axle is fully steerable on this one, maybe at has some amount of passive steering. Experts may have more details on that.
tharian is offline   Reply With Quote
Old 31st March 2015, 09:09   #37
silversteed's Avatar
Thanked: 1,667 Times
The lift axle wheels have some amount of steerability, which AFAIK is not passive - it turns based on the steering wheel inputs itself.
silversteed is online now   Reply With Quote
Old 31st March 2015, 09:25   #38
Ashley2's Avatar
The axle can't be steered. It will just drag when making sharp turns.
Old 31st March 2015, 09:43   #39
What about the AL 3718il and 3723 lift axles?
Old 31st March 2015, 10:34   #40
Ashley2's Avatar
They also don't turn.
Ashley2 is offline   (1) Thanks Reply With Quote
Old 31st March 2015, 12:01   #41
peterjim13's Avatar
Thanked: 327 Times
Dragged means, during an upper curve it does not really help the truck in steering and rather increases drag. Am I correct
Old 1st April 2015, 20:42   #42
Thanked: 764 Times
I have seen a few of these in Pune. The Tata 3723 has larger front overhang, and the fifth axle is a lift axle which is free steered. So it will not actually drag, but turn in the opposite side of the front axles due to the vehicle turning.
The similar model from AL has the lift axle ahead of the driven axle, and also seems to be free steered.
Both have two steered axles in front.
Rahul
Rahul Rao is offline   (1) Thanks Reply With Quote
Old 19th April 2015, 11:01   #43
Ashley2's Avatar
Rahul
There exists no linkages between the steering and the tag axle. They cant be steered by any means. They just drag or can be said as freely turn (controlled) to aid steering.
Its only in the Vestibule buses where there was a mechanism which actually turn the last axle opp to the front axle.
Ashok Leyland launches new 5 axle 3718il Rigid Truck swiftdiesel Commercial Vehicles 40 1st October 2015 14:33
1 ton TATA ACE suniljathar Commercial Vehicles 37 25th June 2012 21:09
Eicher launches a 14.5 ton truck - The Eicher 11.14 GTO Commercial Vehicles 18 30th April 2012 17:51
Multiple Axle mechanism vinayrathore Commercial Vehicles 15 13th June 2010 04:22
3 rear axle Tata Truck. tushky Commercial Vehicles 5 28th February 2007 13:43
