Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 28th June 2006, 11:42   #1
Revvhead's Avatar
Default Whats This- Pipes on a BEST bus??
Ok, i have noticed that all the CNG BEST buses in bombay have two pipes sticking out of the rear capped with a T. Also has a rubber gland between the pipe and the sheel, so this is definitely an intentional design fit.
The end of the T has a mest siliar to a flame arrestor type mest- but the mesh size seesm to be a bit too large for the purpose of a flame arrestor.
My guess is that it may be part of the safety relief valve system on the CNG cylinders.
I could only snap one (was driving
) but they are always in pairs, side by side. Courtesy the Cab that decided to stop right up to the bus (typical) i could get a full pic of both
any one to shed any ideas on this?
Revvhead is offline   Reply With Quote
Old 28th June 2006, 12:06   #2
normally_crazy's Avatar
Thanked: 394 Times
could be the CNG filling inlet ?
normally_crazy is offline   Reply With Quote
Old 28th June 2006, 14:57   #3
Revvhead's Avatar
Nope no change of that.
There's no evidence of any pressure cap/ quick connect coupling or any high pressure system there.
As i said, the ends have wire mesh on them
I dunno how CNG in cars is filled myself, but am dead sure from the construction its not a filling pipe- that stuff looks like ordinary pipe- altho, if one were to use it as a relief line i figure cryogenice pipes would be neccessary if you construct it properly
Old 28th June 2006, 15:48   #4
naveendhyani's Avatar
Thanked: 7 Times
in delhi also the CNG vehicles have these pipes although they run all the way till the top of the bus. i guess it cud b some leakage preventive measure, though not sure.
naveendhyani is offline   Reply With Quote
Old 28th June 2006, 16:06   #5
sumitkalindi's Avatar
Thanked: 13 Times
Yes it is a release pipe to offload CNG from the tanks incase of some mishap
sumitkalindi is offline   Reply With Quote
Old 28th June 2006, 20:41   #6
Thanked: 66 Times
i used to think it was for supporting the posters behind..
but i guess im wrong
team bhp...always helps
xtreme power is offline   Reply With Quote
Old 29th June 2006, 17:56   #7
It is the CNG system's pressure relief valve outlet..
The T is so that it doesnt blow off the person/vehicle immediately behind.
The mesh may have a more common-place purpose, to prevent rats and birds getting in . A flame arrestor is a bit more elaborate than just a mesh.
Why in pairs - Maybe its a dual redundant system ie 2 PRVs or maybe there are 2 CNG tanks in these buses?
nitinbhag is offline   Reply With Quote
Old 29th June 2006, 18:13   #8
Revvhead's Avatar
True, but the mesh size is a little wide.
Believe me , in a relief system, a proper mesh is an excellent flame arrestor
and many times thats all there is.
The reason why it could be in pairs is possibly both of two reasons-
The primary one being the redundancy- In the event of malfunctioning/non lift of one relief valve the other will make sure that the pressure is relieved
and/Or
To ensure a sufficient rate and volume of release to prevent any pressure buildup in the line.
Whats double clutching & whats the reason to use it _Crazi4Speed_ Technical Stuff 109 25th February 2016 08:49
Loud Pipes face the Axe manson Superbikes & Imports 42 28th April 2013 09:03
Advantage or Disadvantage of Twin Tail Pipes Ricky_63 Technical Stuff 15 9th June 2007 12:40
Whats the fastest i.e whats the highest average speeds that you have maintained MKRAFT Street Experiences 1 3rd April 2006 17:25
