Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 26th November 2016, 14:22   #31
vibbs's Avatar
Thanked: 865 Times
Default Re: Explained: How Marine Diesel Engines Work
Originally Posted by rangarx View Post
Quick question, who holds the biggest of marine engine business share?
MAN, Wartsila or Cat?
I believe CAT is mainly into medium speed and high speed engines. Slow speed diesel engines are the ones that normally power these ocean going behemoths. There I would say its MAN and Wartsila that slug it out. But MAN should be leading by a fair margin. If I am not mistaken they have more than 60% market share world wide.
Wartsila however is now into much more than just engines. They are taking over a lot of companies in the marine industry offering a wide range of solutions.
vibbs is offline   (2) Thanks Reply With Quote
Old 30th November 2016, 01:58   #32
Thanked: 8,469 Times
Both companies have been caught cheating, with test results, software etc. Now where did we hear that before?
http://shippingwatch.com/suppliers/article8493130.ece
Jeroen is online now   (1) Thanks Reply With Quote
Old 1st December 2016, 13:28   #33
I found some of my old photoís. Note, these are nearly forty year old prints that I scanned with google photoís, so not the best of quality, but the best I can do for now.
This happens to be the very first ship I served on. In fact it was my apprenticeship year during 1979-1980. The way it worked in those days; two years naval college, followed by a full year apprenticeship, fourth year back at university to graduate.
This is 1979-1980, the vessel is the Nedlloyd Florida. A general cargo ship, about 12.500 tonnes. She was equipped with five holds, freezer rooms and clean oil tanks to transport oil as well. She was designed for a crew of around 80. When I sailed her that was ďdecimated" to about 55! Later I sailed on ships with as little as a crew of 7!
These were some of the best ships to be assigned to, because they went from port to port all over the world. Even in extremely efficient ports such as Singapore, HongKong, Japen it would take several days of unloading and loading. In other places you would find yourself in port for sometimes weeks at a time. Lots of shore time.
This is also an era where ships still look beautiful and graceful. She was pretty fast, well over 20 knots! Even dead slow was 6 knots, which presented some problems during slow manoeuvring
Explained: How Marine Diesel Engines Work-florida.jpg
The engine was a 12.000 BHP two stroke, B&W. (Burmeister & Wain). I found an original 1;10 drawing. This is me holding it up, Iím 1.96 so this engine was close to 20 meters high!
Actually, this type of engine was very common in those days. If you look closely you can see the turbo in the top left corner. It had two of those. You can also clearly see the piston, piston rod and cross head.
Explained: How Marine Diesel Engines Work-engine-drawing.jpg
Here is how things look at the cilinder head plate. Apologies for picture quality, but hereís what we are looking at:
This picture was taken from the front of engine room, so we are facing towards the rear of the ship. Clearly visible are five valve rocker assemblies.
We had just pulled piston number 1 and you can see it hanging from the crane. Look at the size, there is a guy in front of it. At the left you see one of the two turboís.
At the rear bulkhead you will see a spare cilinder head. Itís the piece with the huge studs sticking out. At the very front you will see cilinder number 1, the cilinder head was taking off and you will actually see the studs used to hold the cilinder head in place. The cilinderhead was lifted off, with the rocker assembly and everything else, e.g. injectors, still in place.
You need to look carefully but in the right hand corner you will actually see another piston. It has itís rod attached as well. This was a specially designed and constructed place. We could lower a piston with a piston rod poking downward like thesl so we could work on the piston itself. Cleaning it, measuring the piston grooves, rings, replacing piston rings etc.
Explained: How Marine Diesel Engines Work-topside.jpg
Here is a better picture of what is going on with cilinder 1. The cilinder head is removed and one of our crew is inside the cilinder liner doing some cleaning or measuring. Iím not a hundred percent sure of the size but I recall the bore was about 90 cm and the stroke about 1.80m or thereabouts!
To the left of the other crew member is one of the fuel pumps and you can see the turbo air intake really well
Explained: How Marine Diesel Engines Work-open-cilinder.jpg
Jeroen
Jeroen is online now   (3) Thanks Reply With Quote
Explained! The different types of Petrol Engines (Inline, Flat, V etc.) theMAG Technical Stuff 15 8th May 2017 10:05
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Scania launches Marine Engines in India parrys Commercial Vehicles 0 9th October 2013 16:02
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
Do non-common-rail diesel engines work better with warm air? Samurai Technical Stuff 35 23rd January 2010 09:34
