Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 11th January 2017, 18:58   #1
rajeev k's Avatar
Thanked: 1,689 Times
Default Kerala to soon get solar-powered boat
A solar powered boat, christened 'Aditya' would be launched shortly in Kerala to ferry passengers from Vaikom in Kottayam District to Thavanakkadavu in Alappuzha District.
The boat is presently moored at the wharf at Vaikom, hoping to set sail soon.
rajeev k is offline   (6) Thanks Reply With Quote
Old 11th January 2017, 19:07   #2
libranof1987's Avatar
Thanked: 2,488 Times
Default re: Kerala to soon get solar-powered boat
Details:
https://en.wikipedia.org/wiki/Aditya_(boat)
What particular interested me:
The total energy needed to operate the ferry for 5.5 hours is 110 kWh (20 kW is average power). 1 kW solar panels produce 4 kWh of energy per day, factoring the system efficiency and standard sun of the location of 5.72 (average through out the year). Hence the energy from solar panels is 80 kWh. The gap in energy is provided by lithium battery that can provide up to 40 kWh (80% discharge) from a total capacity of 50 kWh. The lithium batteries are fully charged in the morning because of overnight grid charging.[8]
A trip between the two boat points takes 15 mts and it needs energy of 5 kWh. Hence a total of 22 trips can be made daily transporting 1,650 people daily, or 580,000 people every year without burning fuel.
libranof1987 is online now   (4) Thanks Reply With Quote
Old 11th January 2017, 19:33   #3
Rudra Sen's Avatar
Thanked: 3,832 Times
Mod note: Thread moved to Commercial Vehicles.
Rudra Sen is offline   (1) Thanks Reply With Quote
Old 1st July 2017, 10:29   #4
rajeev k's Avatar
Default Re: Kerala to soon get solar-powered boat
Traveled on this boat two days back.
The Interior of the non polluting boat, on a cruise, ferrying commuters across the Vembanad Lake, between Vaikom & Thavanakkadavu.
rajeev k is offline   (8) Thanks Reply With Quote
Old 2nd July 2017, 13:19   #5
Thanked: 3,631 Times
Originally Posted by libranof1987 View Post
Details:
Thank you for sharing this most interesting boat. Solar power for inland and coastal water transport can be a real alternative because the power needed top pull a floating object (ie the boat) is very small if speeds are kept low. In water, speed and power have a cube co-relation. Reduce speed 5 times and power needed drops 125 times and vice versa. So a boat with a full load displacement of 50 tonnes would needed roughly 40 to 60 bhp to cruise at about 8 knots ~ 15 kmph. For coastal & inland work a 50 tonne boat is big and 15 kmph is a jolly decent speed for a coastal boat. So long as speed needs are kept low the sun can work very well. To provide a reference for those have done the ferry from Apollo Bunder (Gateway) to Elephanta - those boats cruise at about 6 to 7 knots.
Also relative to size boats (or ships) can carry a greater weight of batteries than a wheeled vehicle. And of course submarines have been (partially) battery powered for a century.
V.Narayan is offline   Reply With Quote
Old 2nd July 2017, 16:20   #6
Turanor PlanetSolar is the largest solar-powered boat in the world. In May 2012, it became the first solar electric vehicle (of any kind) ever to circumnavigate the globe. The 31-metre boat is covered by 537 sq metres of solar panels run two electric motors, one in each hull. There are 8.5 tons of lithium-ion batteries in the ship's two hulls. The boat's twin hull ie catamaran hull gives it a top speed of 14 knots (26 km/h) and a cruise speed of 10 knots (18 kmph). In 2013 she crosed the Atlantic back and forth. All this on solar power only. We live in exciting times.
Displacement: 85 tonnes
Length: 31 metres (35 with panels opened out)
Beam (or width): 15 metres (or 23 with panels opened out)
Top speed: 26 kmph (or 14 knots)
Engines: Electric Motors -2 x 60 kw for speed and 2 x 10kw for cruising
Fuel: Solar energy
Range: limited by crew endurance and food supply!!
The boat with its twin hull design for speed, stability and ample deck surface area. Think of Karl Benz in 1885 or Wright Flyer in 1903. We are looking at a step into the future. Sceptics beware.
View from the top when sailing on the seas with solar panels fully open. In harbour the outer panels slide in to aid maneuvering and berthing. The size of the ship can be gauged by the three crew men on deck.
The seals say they approve! Mr. Trump please note.
Dear Rajeev K thank you for letting me go a wee bit off topic.
V.Narayan is offline   (3) Thanks Reply With Quote
Cruising the Kerala backwaters in a passenger boat - The "See Kuttanad" service TKMCE Travelogues 19 14th August 2015 17:27
Manipal Institute of Technology students design solar-powered car, 'SERVe' sarathlal The Indian Car Scene 9 7th May 2015 10:42
Engineering Students build India's 1st Solar-Powered Vehicle S2!!! Technical Stuff 0 9th July 2014 16:42
Spotted : Solar Powered Vista Hybrid in the offing ? sajo The Indian Car Scene 10 23rd September 2010 02:07
Solar-Powered Vehicle shyn Technical Stuff 1 20th April 2010 16:39
