Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 21st May 2017, 09:12   #31
Thanked: 617 Times
Default Re: Major design flaw in the Mahindra Swaraj Tractor – 735 FE. Coolant leaks everywhere!
I had a talk with a local tractor mechanic in Rajgurunagar near Pune.
What he said is 'This is a common issue. Most usere remove the thermostat and it gets solved'.
I personally do not agree with this, as the engine will not be achieving operating temperature at all, as it has a highly overdesigned cooling system.
One answer to this is to drill a hole through the valve plate of the thermostat, so that there is more bi-pass. It may take longer to achieve operating temperature, but the current occurance whic is localised overheating of cylinder head with rest of the engine remaining cold will be prevented.
To confirm that the source of your problem is the thermostat, try running the engine without the thermostat for just one day.
Rahul
Rahul Rao is offline   (1) Thanks Reply With Quote
Old 21st May 2017, 20:50   #32
Thanked: 2,040 Times
Originally Posted by shravan2k2 View Post
I think you are not aware there is no head gasket in today's tractor's.
Would like to know more.
This is necessary so that there is some flow of coolant at all times. Else the hot coolant never reaches the thermostat, which does not open, which leads to local overheating, which leads to superheated steam pockets, which leads to ...
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Design Flaw with Honda i-DTEC in Amaze & City: Susceptibility to Hydrolocking deetjohn Technical Stuff 103 14th March 2017 19:49
Mahindra Swaraj launches the 855 XM and 744 XM Tractors in MH GTO Commercial Vehicles 0 6th March 2013 09:33
Oil Sump In Optra Magnum-Design Flaw andrewdsouza72 Technical Stuff 33 3rd September 2009 15:13
Nokia 'leaks' pics and specs of its iPhone killer nishantgandhi Gadgets, Computers & Software 17 4th August 2009 12:20
Mahindra Shaan - New Tractor from Mahindra! normally_crazy Commercial Vehicles 25 7th April 2009 00:36
