Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 12th February 2018, 09:41   #1
Rehaan's Avatar
Thanked: 24,597 Times
Default Ashok Leyland Circuit-S Bus @ Auto Expo 2018
Big shoutout to Suhaas307 for shooting these pictures & his coverage of the Auto Expo. Thanks for sharing!
Highlights:
• Ashok Leyland in collaboration with Sun Mobility (Chetan Maini is the co-founder), is all set to introduce the Circuit-S Bus.
• A typical electric bus takes about 1-2 hours to fast charge, or 8 hours to regular charge. That's a lot of downtime for a commercial vehicle.
• Note that this is the Circuit-S, as opposed to the Circuit that was launched in 2016. The "S" implies Swappable battery.
• The Circuit-S bus has a removable battery that can be automatically swapped out for a freshly charged one in less than 4 minutes.
• Each battery pack is about 1/4th the weight (improving efficiency) and smaller (freeing up passenger space) than a typical bus battery.
• The reduction in battery size & weight is due to the fact that it is a lower capacity battery, that gets swapped out frequently. The range of each battery pack is 50 km.
• Ashok Leyland will sell these buses without the battery included - which makes the upfront cost of the Circuit-S bus equivalent to that of a regular diesel bus.
• The bus operators then use the swappable batteries on a pay-per-use basis.
• A network of Quick Interchange Stations will be set up to facilitate the swapping, charging and maintenance of battery packs.
• By setting up 30 Quick Interchange Stations at existing bus depots in Bangalore, Ashok Leyland claims they can cover 85% of the bus routes.
4 steps up to the seating area, this is not a low-floor bus:
The Circuit-S bus ranges from 9m to 12m / 25 to 35 seats. The battery pack is visible from inside the bus (through the window at floor level):
Note the P/R/N/D push-button gear selector:
You can see the swappable battery peeking through the lower window from the outside too:
Though not pictured here, the bus is fitted with a fire detection and suppression system:
On the right is the mechanism for the Quick Interchange Station:
Note the box at the end which houses the mechanism to lock onto the battery:
The arm telescopes all the way into the bus' battery bay:
It locks onto the discharged battery pack and pulls it out:
Even though this is considered a "small" battery by bus standards, it's still huge!
On the other end of the battery you can see the large electrical connectors (heavy amperage!):
The battery gets rotated around…
…and taken along to the charging dock:
Additional specifications:
Rehaan is offline   (15) Thanks Reply With Quote
Old 12th February 2018, 10:14   #2
Rehaan's Avatar
Default Re: Ashok Leyland Circuit-S Bus @ Auto Expo 2018
Thread moved out from the Assembly Line (The "Assembly Line" Forum section).
JBM Auto to launch its first electric bus at 2018 Auto Expo TusharK Commercial Vehicles 2 27th November 2017 23:42
Ashok Leyland @ Auto Expo 2016 Ashley2 Commercial Vehicles 26 18th July 2017 16:40
Ashok Leyland Circuit launched; first India-made Electric bus dZired Commercial Vehicles 12 28th October 2016 18:10
How Bajaj Auto, Tata Motors, M&M and Ashok Leyland gave birth to auto MNCs darklord The Indian Car Scene 0 17th October 2013 13:06
Ashok Leyland to be renamed as Hinduja Leyland? Ashley2 Commercial Vehicles 8 15th April 2011 13:14
