Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 13th February 2007, 13:40   #1
Thanked: 54 Times
Default Under the Monster Volvo B7R Hood (Engine Compartment Pics)
Hi Guys,
Had a chance to peep into the hood of Volvo B7R Bus. What a monster engine it houses, a big radiator fan like a train, 2 cylinder AC compressor, turbocharger....
6-cylinder, 6.7 LITERS, 4-stroke OHC Turbocharged Intercooled DI diesel
Output 285 HP @ 2200 rpm
Torque 1200 Nm at 1120 rpm
6 forward speed, fully synchronized, electric retarded gears
Here are some pics -
It has a good torque punch under hood. The idling speed is 500 rpm and max RPM is 2500 rpm. At around 2200 rpm, it cruises at 100 in the 6th gear effortlessly.
Vishnu
vishnugs is offline   Reply With Quote
Old 13th February 2007, 14:34   #2
kpzen's Avatar
Thanked: 1,655 Times
Idle speed is below 500 rpm i think.... the torque is awwsum.....can feel it as a passenger also .....the driver feel should be even better
Old 3rd May 2007, 15:25   #3
rahul_intlad's Avatar
This went somewhat unnoticed on team-bhp:
Volvo buses now come with common rail engines ,Volvo calls it CRD,it is euro 3 compliant and guess what ABS is now standard on B7R's.
tech specs now read,
6-cylinder,7-litre diesel
213 kW (290 hp) @ 2100 rpm
1200 nm @ 1050 - 1650 rpm
Disc brakes with EBS 5
The euro 3 B7R comes with ABS as standard, a leaning facility that can raise the buses by 5 cms and a fuel tank with a 600 litre capacity.
Did not understand the part in bold
source:
Auto Monitor
Also tech specs:
Volvo India
rahul_intlad is offline   Reply With Quote
Old 3rd May 2007, 15:37   #4
That tacho looks a lot like the Safari DiCOR's tacho. The DiCOR redlines 500 rpm higher.
dicorex4x4 is offline   Reply With Quote
Old 3rd May 2007, 16:27   #5
condor's Avatar
Thanked: 4,903 Times
...a leaning facility that can raise the buses by 5 cms ...
Active suspension / GC-on-demand ?
Old 3rd May 2007, 16:41   #6
Ram
Ram's Avatar
Thanked: 149 Times
source:
Auto Monitor
My take is that it is a typrographical (brainographical?) blooper by a journalist who doesn't understand contemporary bus technology.
The correct words would be it has a kneeling facility that can lower the buses to 5 cm (the height of a low kerb)
This is to permit a passenger with a wheel-chair to be helped into the bus.
Ram
Ram is offline   Reply With Quote
Old 3rd May 2007, 16:51   #7
"a leaning facility that can raise the buses by 5 cms "
This is a feature which is common in most of the buses in Europe. This is to help the passengers to get into the bus easily. This feature is ued to lean the bus(which makes the stairs to come closer to the ground) to the side from which passengers get in.
shivapsreddy is offline   Reply With Quote
Old 6th May 2007, 05:14   #8
Mpower's Avatar
Thanked: 1,687 Times
can be done with any vehicle with ECAS. (electronic air susp)
Some off roaders like Cayenne, RR can do the opposite, raise the body by an inch or so for off roading (only under 25 mph or something like that)
Volvo B7R reviews? abhijitaparadh Commercial Vehicles 189 14th January 2017 19:38
Another Volvo B7R accident on the Pune-Mumbai expressway Ram Commercial Vehicles 63 24th July 2007 10:34
Volvo B7R high-roof sleeper Ram Commercial Vehicles 43 8th May 2007 19:59
Volvo B7R crash on Pune-Mumbai expressway Ram Commercial Vehicles 30 10th May 2006 14:45
Spotted DC modified Volvo B7R Bus Stratos Commercial Vehicles 10 1st November 2005 00:23
