Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 29th June 2010, 21:30   #121
Amartya's Avatar
Thanked: 439 Times
Twelve thousand views to read a hundred and eighteen posts, in my opinion, mean,there are a lot of people who want to know who buys an AL and who buys a TATA of the same configuration and why, and we, at least on this count, seem to be short on information.
Hoping for some direction to the thread... :(
I hope for the same and I personally do not have any information about the same. However, I am of the opinion that Tata's truck range is now much more advanced that the Ashok Leyland range, specially because of their Prima and Novus range of trucks.
For all their clout with transport departments, Ashok Leyland has always taken the shortcut (using tie-ups to produce trucks) to try and make money, mainly by investing much less than Tata in research and development. I understand that Ashok Leyland fans might be up in arms about this, but I know it for a fact that Tata invests more in R&D (even in % terms) than AshLey.
Amartya is offline   Reply With Quote
Old 30th June 2010, 15:44   #122
Originally Posted by hvkumar View Post
Yes, I noticed that when I went to Aurangabad recently. Not only Aurangabad, I also found a lot of the Marathwada region - Beed, Osmanabad, etc - populated by only ALs.
AL seems to have clawed itself back into BEST again, all the new CNG and low-floor AC bus are AL.
If you are talking about MSRTC (state transport) then the state is divided as follows.
1. konkan - Leyland
2. Westerm MH - TATA
3. Marathwada & Khandesh - Leyland
4. Vidarbha (eastern MH) - Tata
This has been the case since my childhood.
qj7081 is offline   Reply With Quote
Old 30th June 2010, 16:36   #123
hvkumar's Avatar
Thanked: 3,361 Times
1. konkan - Leyland
But there has been some major changeover. The Mumbai region which was all-Leyland is now all-Tata, except for some short-haul (Panvel/Uran) CNG buses out of Kurla Nehru Nagar Depot. I heard some talk of a powerful dealer having switched loyalties over some commission disputes. Even in Konkan, some depots like Alibag, Roha, etc, started getting Tatas too.
hvkumar is offline   Reply With Quote
Old 30th June 2010, 19:29   #124
Ashley2's Avatar
Thanked: 1,444 Times
Agreed for this part with Prima range alone. Tata has nothing to claim the development of Novus as they were developed by Daewoo and later been taken over by Tata.
Here I have some different opinion.
I don have the stats regarding the amount of money each of them spend on R&D but still I have the following points in favour of Ashokleyland.
AL have heavily invested in making its own range of engines - Neptune series. But Tata still is behind Cummins for the engines. They always play a safer game in development.
I would like to say both of them needs to drastically revisit their strategy towards R&D investment as they still have a larger ground to play.
Just to share the info and nothing to raise my arms
Ashley2 is offline   Reply With Quote
Old 30th June 2010, 22:37   #125
Thanked: 154 Times
I think Tatas are better off strategically, Engines are much sophisticated these days and need lot of R&D investment. Leave that to specialists (Cummins) and concentrate on other areas to improve the overall product. That is one reason, they are able to introduce more models and variants in a shorter timeframe. This is a strategy followed by other manufactures around the world, make the high volume engines inhouse, procure the niche ones from the specialists. Volvo uses Cummins Engine in some of their trucks, Navistar uses Paccar engines in few of their vehicles. Also another advantage for Tata is they have a joint venture with Cummins, not just a sourcing agreement. Read this announcement yesterday
[Cummins to invest $300 mn to set up 4 units in next 5 years-Auto Components-Auto-News By Industry-News-The Economic Times]
The company will set up an engine manufacturing facility with its joint venture partner Tata. It will start with an initial capacity of 60,000 units by the end of this financial year
Besides this engine facility, the company will set up a rebuild centre for generators, re-conditioning facility and a parts distribution unit within the complex.
It looks like Cummins investment in Automobiles engines in India is thru the Joint Venture with Tatas.
teamveevee is offline   Reply With Quote
Old 1st July 2010, 00:44   #126
Amartya's Avatar
Thanked: 439 Times
Yes, you are absolutely right. I knew about this, but chose to cite this purely as being more advanced than what AL had on offer. That was the moot point in my post, you are right - of course- about the Daewoo takeover.
Again, thanks for sharing this. Yes, I understand that developing an engine is indeed an achievement, but this is very similar to the engine sharing going on in the car industry (the Fiat 1.3MJD is everywhere), where a manufacturer chose to source engines from someone else with the edge in engine design.
That being said, I appreciate that AL has invested in developing their own engine, I think although it might not make too much business sense, it is indeed praiseworthy.
I would say that Tata doesn't really need to change too much in their R&D setup, I don't know enough about AL though.
Old 1st July 2010, 04:30   #127
Thanked: 12 Times
could you tell me as to which particular volvo model uses cummins engine and in which country?
also which navistar models use paccar engines?
conjon is offline   Reply With Quote
Old 1st July 2010, 05:58   #128
Amartya's Avatar
Thanked: 439 Times
I hope your post was meant purely for information and you weren't doubting teemveevee's claim, because it was fairly easy to find out and confirm.
Volvo Cummins - This link below talks about the venture between Volvo and Cummins - Cummins Every Time - In The News - U.S. Press Releases - Press Release
Navistar Paccar - They both source engines from Caterpillar (not all but certain engines) - The 2010 US Diesel Engine Landscape - Paccar?s Approach Will Be Most Changed Without Cat - GLG News
The US Diesel Engine Landscape Is Clearer - Navistar?s / Caterpillar?s ?Star? Looks Brighter - GLG News
Most of the news is from North America.
Old 1st July 2010, 09:20   #129
Thanked: 12 Times
I knew navistar group company MWM was supplying engines to Volvo, VW HCV's in Brazil.I had a doubt as to whether teamvee had misquoted this as cummins. Also the Volvo group is using the Detriot Diesel mill in their Prevost coaches, the volvo engine is optional.
Always thought that paccar was depending solely on their own and DAF engines which they had procured in late 90's.
looks like engine development is a very expensive affair hence outsourced to majors like cummins and caterpillar.
Old 1st July 2010, 11:59   #130
Thanked: 154 Times
Conjon, You may be right, my bad memory. I typed paccar, what i wanted to say was caterpiller. This is mostly in North / Latin American markets.
[ie Volvo uses Cummins, Navistar uses Caterpiller in certain models] I think you got the point i was trying to make.
Old 1st July 2010, 16:37   #131
Thanked: 81 Times
AFAIK, the B7RLE8400 CNG bus launched by Volvo India during Autoexpo2010 is having a Cummins Gas engine (not the B series used in Tata CNG buses)
Transsenger is offline   Reply With Quote
Old 1st July 2010, 17:08   #132
fifthwheel's Avatar
I was at Delhi last week and was able to make a few observations about the AL low floor city buses introduced by DTC alongside the Marcopolos.
They are better in terms of pick up and drivability.
The driver ergonomics though, I feel, is better on Marcopolos.
The AL buses have/seem to have more floor space.
The fit and finish of the ALs is better on the inside and the Marcopolos on the outside.
The AL buses use real big rub rails on their sides.
Drivers told me that the AL buses give them around 3.5kmpl compared to 2.75-3kmpl given by the Marcopolos.
Dev might be right. The DTC buses are fully built at AL's Alwar plant compared to the other bus bodies built all over the country (but for AL facilities)
fifthwheel is offline   Reply With Quote
Old 1st July 2010, 19:02   #133
swifteenik's Avatar
Agreed marketing is a fact or where TATA apex's its self, but its more of terrain oriented market like in northern region TATAs are more preferable to southern LEYLAND being dominater as much of the industry and common man knows...but modernasiation and JVs like NAVISTAR with m&M, Leyland with HINO, TATA with daewoo may share good market when its standard is understood by masses....mean while Volvo, AMW, MAN, Eicher & to some extent Force have understood this deep nerve and therfore gaining pace between these two giants...
Its like an era where Fiats and Ambassadors are to be repalce by Suzukis, Daewoo,Opel
As the sector is highly dependent on after sales maintainence...
The quintessential question: Which is better and on what counts?
The 2 biggest CV makers in India have been at loggerheads with each other for the M &HCV commercial market share ever since they begun production.
Tata rules the roost when it comes to sheer numbers but Ashok Leyland has a permanent and steadily growing clientèle.
But all that is marketing terminology. Lets discuss why do some customers choose a Tata Bus/Truck Chassis over an Ashok Leyland Bus/Truck chassis of a comparable capacity and vice versa?
Reasons could be:
Performance,operating terrain, Fuel Efficiency, Reliability, NVH, Price, After sales support, Resale...the list is long.
This thread is an attempt to know the positives and negatives of both the brands when it comes to the most commonly purchased bus and truck chassis by the vanilla transporter/tourist operator in India.
Let's shift into overdrive....
swifteenik is offline   Reply With Quote
Old 15th September 2010, 11:34   #134
DWind's Avatar
Thanked: 170 Times
Adding a new point of contention here, Gradeability.
This is based on Ashley's post on Raj's Thread for new AC Bus (did not want to hijack that thread). In the brochure attachment for comparison between TATA 1616 and ALPSV 4/86 that TATA has better gradability than AL despite better power and torque ratings. How is this possibile? Is it due to longer stroke on the cummins engine?
Has TATA always provided better Gradeability than AL?
DWind is online now   Reply With Quote
Old 15th September 2010, 11:50   #135
n.devdath's Avatar
Thanked: 2,087 Times
Not sure about the tech specs but having stayed in a terrain where grad-ability is tested on a daily basis, I have seen AL buses exhibiting it far better than TATAs.
Gearing also might play a role here.
Mahindra Truck & Bus division rolls out 15,000th HCV from Chakan plant Aditya Commercial Vehicles 1 27th August 2015 21:55
NGT issues notices to DTC, Tata & Ashok Leyland for plying empty buses embee Commercial Vehicles 14 27th August 2015 17:52
How Bajaj Auto, Tata Motors, M&M and Ashok Leyland gave birth to auto MNCs darklord The Indian Car Scene 0 17th October 2013 13:06
Tata Marco Polo vs Ashok Leyland Rear Engine on DTC Fleet MileCruncher Commercial Vehicles 28 4th December 2011 09:51
Ashok Leyland to be renamed as Hinduja Leyland? Ashley2 Commercial Vehicles 8 15th April 2011 13:14
